Old 01-07-2001, 11:26 PM   #1
bruno
Member#: 2903
1999 Impreza 2.5rs
bmw steel greay
Post will this work on NA engines
i was wondering if a fuel pressure riser or regulator will add any horsepower, or what is its purpose and will it work on na engines and which ones are good
bruno is offline   Reply With Quote
Old 01-08-2001, 01:42 AM   #2
spunky
Member#: 851
Post
I'm wondering how that will work myself. I have MRT headers/exhaust and cobb intake. herad that weapon R FPR sucks. any advice
thanks
bret
spunky is offline   Reply With Quote
Old 01-08-2001, 01:59 AM   #3
Die Civic
Member#: 3301
2001 RS
Post
A fuel pressurizer, won't ADD HP, all it does it, supply more fuel into the fuel rail/injectors. It would help on a turbo, but it could help on a N/A car if you have an AFR reading that you're too lean, which I highly doubt would happen unless you over gapped the spark plugs.
Die Civic is offline   Reply With Quote
Old 01-08-2001, 10:36 AM   #4
Aspen
Member#: 145
Banned to
Housework for Summer
Post
See my other post.
Fuel pressure risers will only work if you're car is sucking in a good amount more of air and your fuel system for some reason can't handle the extra air with more fuel. The trick is to maintain a good fuel/air ratio around 14.7:1 for NA motors. If you have some drastic cams and headwork done to a point where your a/f is low, then yes, increasing fuel pressure can help you out.
On MAF systems, the ecu is able to compensate the additional fuel for mostly mild mods. In Subarus case on the '99 models, adding an intake will let your motor run lean above 4.5K but you should get an electronic device for that since a Fuel pressure riser adds fuel across the whole rpm range and you only want fuel in the rpm range where it is needed. Too much fuel will make your engine bog, not to mention fail emmissions.
Aspen is offline   Reply With Quote
??? will this work on a wrx impreza wagon 04 wchan55888 Interior & Exterior Modification 4 07-15-2010 06:55 PM
Will this work between NA ej25/22 hybrid and my OBS trany? opious Transmission (AT/MT) & Driveline 0 04-24-2006 11:29 PM
Will this work on my car? WRX_Mike Factory 2.0L Turbo Powertrain 11 10-13-2005 03:39 PM
Will this work on my car!! Sharmin7 Normally Aspirated Powertrain 5 04-01-2005 07:07 PM
will this works on Forester ?? PKduck Forester Forum 0 09-01-2001 11:30 AM
Message Board Statistics All times are GMT -4. The time now is 08:34 AM.
