Old 07-12-2004, 01:44 PM   #1
mpower22
Member#: 58352
04 20G STI(SOLD)
08 z51C6 (growing mullet)
Default whats a good front to rear psi for sti tires for less understear?
The owners manual recommends 36 front and 30 rear but this would really promote understeer right? whats a good psi for less understeer? 36/36?
mpower22 is offline   Reply With Quote
Old 07-12-2004, 03:55 PM   #2
kenchan
Member#: 15106
Less psi will promote squirm on the shoulders and sidewall
enabeling the tire to loose lateral grip on high g turns...so
you'll want more PSI up front than the rear.
36/30 sounds pretty good to me.
kenchan is offline   Reply With Quote
Old 07-12-2004, 06:46 PM   #3
BHawk
Member#: 61860
2004 WRX STi
Actually a lower pressure will increase grip so really you might want to try 30/36 instead.
BHawk is offline   Reply With Quote
Old 07-12-2004, 06:52 PM   #4
KmanRuffian
Member#: 48360
2011 WRX 5-door
For oversteer you want more pressure in the fronts. Try it for yourself and you'll notice it right away. It gives the front more "bite" and reduces the tendency to plough. Try 40 in the fronts and 35 in the rear just for fun... You'll notice it. 40 can be a bit much for driving on every day though. But you want more pressure in the front and less in the rear. I used to think it was the other way around too until I came across a good write up on it. If I can find it on the net I'll post a link later... Goodluck, have fun!
KmanRuffian is offline   Reply With Quote
Old 07-12-2004, 06:57 PM   #5
KmanRuffian
Member#: 48360
2011 WRX 5-door
First 2 things that came up on google:
http://www.club4ag.com/faq%20and%20t...mendations.htm
http://www.susquehanna.com/susq/other/stuning.htm
I think I read the article in a magazine. 40psi might be oo much but you'll have to decide. If you go too hard you will indeed reduce grip due to a reduced contact patch with the road. But so long as you don't go past that point increasing the pressure up front gives you a "stiffer" tire with better "bite" and steering feel.
wtb: front and rear brake rotors, sti. new or good condition used. dfw paulmofyourhand TXIC Private Classifieds 0 12-15-2009 04:51 PM
WTB: Stock struts Blown or good 04 WRX Rear 05/06 STI fronts medamullet RMIC Private Classifieds 8 07-29-2008 05:08 PM
Slightly more worn tires front to rear, ok for track day? xcdhridr Tire & Wheel 1 05-31-2007 10:11 PM
Increasing front to rear tire pressure differential = difficulty shifting? Evil STI Transmission (AT/MT) & Driveline 0 05-06-2006 12:56 PM
front to rear tire size tollerances BIGHONKEY Tire & Wheel 4 02-22-2006 12:18 PM
