Old 10-19-2000, 11:02 PM   #1
subisrule
Member#: 2001
Question Air conditioning for more power?
My friend has an '87 Firebird. There was a switch hooked up to the air conditioning compressor thing. When he flipped the switch, it turned off the a/c and gave the car more power. I want to know if anybody has heard of this or has done this. thanx
subisrule is offline   Reply With Quote
Old 10-19-2000, 11:05 PM   #2
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Post
well, All you have to do is turn the A/C off manually and the it will turn off. Don't really need any special switch.
It will free up some horsepower.
Eric
Eric SS is offline   Reply With Quote
Old 10-19-2000, 11:22 PM   #3
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Post
...And if you really want to get psycho, remove it altogether, so the engine doesn't have to deal with the the weight of the compressor and turning the pulley....
Brian
http://members.nbci.com/_XMCM/northu...reza/index.htm
Old 10-19-2000, 11:23 PM   #4
subisrule
Member#: 2001
Post
No. What I mean is that when the a/c is off, he flipped a switch and got more power.
Old 10-19-2000, 11:45 PM   #5
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Post
He's got a supercharger right? I vaguely remember hearing something like what you described for domestic musclecars that are blown.
Keiho is offline   Reply With Quote
Old 10-19-2000, 11:46 PM   #6
Digital_Boy
Member#: 730
Post
Does he have a nitrous kit? That's what it sounds like. How much more power are we talking about here?
Digital_Boy is offline   Reply With Quote
Old 10-19-2000, 11:54 PM   #7
subisrule
Member#: 2001
Post
There was no nitros or a supercharger. just some switch that was hooked up to the a/c compressor thing. it didnt add much power. Possibly 4 to 6 hp
Old 10-20-2000, 12:09 AM   #8
Digital_Boy
Member#: 730
Post
Sounds like he was pulling your leg. 4-6HP is pretty much unnoticable to a "seat of the pants dynamometer"... I.e, you're not likely to feel 4HP difference without a real dyno.
Old 10-20-2000, 12:16 AM   #9
subisrule
Member#: 2001
Post
I was sitting in the car when he flipped the switch. The power gain was comparible to when you turn off the a/c.
Old 10-20-2000, 12:19 AM   #10
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
Post
I was thinking about taking the belt off the A/c compressor for the winter time. But youll need to run the A/C for 5 hours after you hook it back up. The freon will need to recirculate. I don't think there would be anygains by doing that anyway. Kinetic energy from the rotating mass would be nominal
WRXwannbe is offline   Reply With Quote
Old 10-20-2000, 12:57 AM   #11
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
Post
Even if you have our air conditioners on high... as soon as you depress the gas pedal all the way and go to wide open throttle, our air conditioner shuts off. It's a built in feature.
Fitz
Fitz is offline   Reply With Quote
Old 10-20-2000, 09:13 AM   #12
Willis
Member#: 424
2005 WRX STI
Post
I've done this test in my RS before just to see if I can notice any change in hp from the AC:
1) Ride in 1st gear at a constant high rpm (say 5000rpm) while the AC is on.
2) Turn the AC off.
3) The car will lurch forward. This is because the AC compressor is being shut off, and its no longer eating any hp.
That is what your friend was doing. He wasn't adding power by turning off the AC. He removing power consumption.
Willis is offline   Reply With Quote
Old 10-20-2000, 02:37 PM   #13
Turk
Member#: 1888
Post
Fitz is right it is in the manual
Turk
Turk is offline   Reply With Quote
New UTEC maps! No more knock, now for more power.... bpwatts UTEC 52 03-23-2007 02:05 PM
What is the best thing for more power in my 97 OBS? FlooredSubaru Newbies & FAQs 3 09-16-2001 11:55 AM
What can I do to my engine for more power? 95SubLegacy Legacy Forum 19 09-12-2001 04:00 PM
What is the safest set up for more power with out spending too much $$ Hanzo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-26-2001 02:11 PM
OK, NOW I'm hungry for more power! GooseMan Normally Aspirated Powertrain 5 05-23-2001 10:42 AM
