Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 10-19-2000, 09:09 PM   #1
brivalen
Member#: 2381
Have a Nice Day? Please please help me!!!!!!
I have an OBS and just installed a MY00 RS front bumper with all the goodies including subaru fog lights, new bumper beam, clear turn signals, it look great. I had driven the car later that day and no probs. Tonight i was coming homw on the highway and all of a sudden the car was acceleraating by itself!!! The first thing i though was that the floor mat was stuck but i check it and it wasnt. I was really pressing on the brake and i was barly slowing down. I shifted into neutral and the RPM went WAY up past 7000!! I love my car and i decided not to blow up my enging and pulled over. I poped the hood and there was no kind of hangup on the gas cable thingy and i decided to try again. Same frekin thing, i barly made to the dealership and am leaving it overnight, any suggentions?, I think that they are going to tell me that i did some thing while installing the bumper and of fog lights? (i didnt use the factory wiring harness, i bought one a an autoparts and used it so that i could run higher watt bulbs) Thanks, Brian Valen
brivalen is offline   Reply With Quote
Old 10-19-2000, 09:19 PM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
Well I think throttle position is purely mechanical (cable) so you really should search that well. I know you said you checked it but look at the accelerator pedal where it attaches to the cable as well. Also look and make sure the throttle itself (butterfly and/or the pulley the cable attaches to) isn't sticking. I don't think it can be anything but that... or a malfunctioning cruise control unit... that might do it too...
Old 10-19-2000, 10:06 PM   #3
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Post
Sounds posesed to me
Eric
Eric SS is offline   Reply With Quote
Old 10-19-2000, 10:09 PM   #4
Imprezer
Dynamic Uno
Member#: 1
2011 Impreza WRX STi
Post
What year is your OBS?
Imprezer is offline   Reply With Quote
Old 10-19-2000, 11:23 PM   #5
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Post
My BRAT did that... the throttle cable was getting hung up somewhere right near the firewall. They removed it and the casing, greased it up, never happened again. I don't know how the OBS works, but it's an idea...
Brian
http://members.nbci.com/_XMCM/northu...reza/index.htm
Old 10-20-2000, 01:30 AM   #6
inzomniak
Member#: 953
Post
Do you have an auto or manual... I think if you have an auto you can turn your idle up way high hehe... that way the "speed" when you go at D is pretty fast... and it makes your car change gears at higher RPMs... and it's harder to stop too of course...
inzomniak is offline   Reply With Quote
Old 10-20-2000, 05:00 AM   #7
Corey
Member#: 618
2000 2.5 RS #89 STS
MODERacing / Bridgestone
Post
Was the pedal down near the floor or all the way up?
Corey is offline   Reply With Quote
Old 10-20-2000, 06:18 AM   #8
brivalen
Member#: 2381
Post
Its a OBS MY00 auto. I just spoke to the dealership and they dont know if they will be able to look at the car today!!! Does anyone know how the cruise control actually makes the car accelerate? I know that the actual gas pedal uses a cable so how does the cruise coutrol interact with the cable? Under the hood there are 2 cable that are attached to the same butterfly assebbly, i know that one is the gas?, what is the other one?
Old 10-20-2000, 08:56 AM   #9
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
The other cable is the cruise control cable. The cruise is based off of a vacuum level when you activate it and I believe it uses a servo to put tension on the line to the throttle assembly. Basically just like having a servo pull on your accelerator pedal cable.
Old 10-20-2000, 11:41 AM   #10
Gambit
Member#: 102
Post
Must be TB cable. Put in some WD40. Unless with your new bumper, it must've added like 50 more ponies in that 2.2l of yours!
Gambit is offline   Reply With Quote
Please to help me recover my HDD! Lachlan Off-Topic 7 06-24-2005 08:55 AM
Please someone help me sell this quick!!! Flyn'Rex Texas Impreza Club Forum -- TXIC 5 10-07-2004 11:35 PM
Pretty pretty please someone help me find the WoW Stress Test Client for download... Asinine Off-Topic 2 09-01-2004 02:01 PM
Please God help me with insulation advice! BrysImpreza Interior & Exterior Modification 9 01-02-2002 02:52 AM
Please someone help me! nikkicalves Canada Region Forum 0 08-11-2001 12:51 PM
