Old 10-19-2000, 08:21 PM   #1
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post Anyone try this with the stock knock sensor?
Anyone try wiring in a relay so that it lights up an LED or a small bulb when it reacts? I imagine it'd be like the poor man's J&S, somewhat, but it might help...
Old 10-19-2000, 08:26 PM   #2
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
Question
Where does the stock knock sensor live on the engine?
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 10-20-2000, 03:22 AM   #3
Jay_UK
Member#: 296
Post
You wont be able too.
The sensor is a high impedance device...
You will throw a check light if u connect a low impedance device onto it...
Either get a new knock sensor (cheap).. or fit a isolating/buffer circuit between the sensor and your output device.
Or just be a cheap knock sensor unit (knocklink) that is adjuatble
J.
Jay_UK is offline   Reply With Quote
Old 10-20-2000, 05:49 AM   #4
Scooter
Member#: 75
Post
The knock sensor is always picking up noise, so the LED would be flickering or on most of the time. Knock has a characteristic sound and occurs during a specific window of time relative to TDC. Unless you have all of the same knock detection circuitry as the the stock ECU wired up to the LED, then the LED will light up for more than just knock. If you want to monitor the knock signal to determine what's knock and what's not for yourself, then you would probably need a scope and you would have to know what to look for.
You would probably be better off getting an OBD II scan tool and watching to see if the ignition timing is being retarded. Or finding some other method of tapping into the ECU after the processed knock signal has been compared to the knock threshold.
Buying something else like the J&S Safeguard or Knocklink (as Jay suggested) can be quite useful, but since the have their own knock dectection circuitry (and are adjustable) they may not indicate knock at the same point as the stock ECU. Thus, such a device may not indicate knock, yet the ECU's knock theshold has been exceeded and timing is being dailed back. Unless you know the stock knock threshold and and the type of detection circuitry being used, it would be pretty tough (if at all possible) to get such a device to detect knock at the same point as the stock ECU.
In a way, the term "knock sensor" is misleading. It doesn't sense knock and knock alone. It's a piezoelectric microphone that picks up all kinds of engine noise. Maybe they should call it the "Engine block noise sensor". It just so happens that the signal from this noise sensor is used by the ECU for the sole purpose of knock detection.
[This message has been edited by Scooter (edited October 20, 2000).]
Scooter is offline   Reply With Quote
Tapping the stock knock sensor, will this work? Ziggyrama Commercial ECU Reflashes 9 06-12-2007 07:02 PM
Reading the Stock Knock Sensor subachad Normally Aspirated with bolt-on Forced Induction Powertrain 5 01-22-2004 02:12 AM
Essay on the stock knock sensor, DeltaDash, and engine management ... wayoutwest Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-24-2003 12:40 PM
need help with the J&S knock sensor ChAi Normally Aspirated Powertrain 7 10-20-2000 10:32 PM
Has anyone removed the stock Knock sensor?? TMR Impreza Technical Forum Archive 7 05-19-2000 06:52 PM
