Old 07-12-2004, 04:53 PM   #1
maxler3
Member#: 41513
Default if u lowered ur rack for steering rack bushing insta...
if u lowered ur rack for the bushing install, how did u get it back up to the original mark, i am about 1/4" away but it just seems to have locked up and the lip is now in the way of getting the screw in.
PLEASE HELP THIS IS URGENT!!!
maxler3 is offline   Reply With Quote
Old 07-12-2004, 07:02 PM   #2
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
What year is your car? What "lip" are you talking about?
Old 07-12-2004, 07:28 PM   #3
Rev1
Member#: 51240
08 Lexus IS350
How much did you unscrew it?
The instructions clearly say to unscrew it a little so that you can pull the rack down. If you unbolted it completely and the rack fell, then you're toast.
I pushed hard up, with my left hand, and with my right hand and a socket wrench I tightened it up.
PUSH!!
Rev1 is offline   Reply With Quote
Old 07-12-2004, 08:08 PM   #4
tdxflex
Member#: 13634
Make sure your steering wheel isn't locked. Put your key into the ignition and make sure your steering wheel is free to turn, the steering knuckle only goes on one way.
tdxflex is offline   Reply With Quote
Old 07-13-2004, 09:52 AM   #5
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
I did it without a problem. The round bushing seemed a bit bigger and when I tightened it down, it kinda squished in the areas where the clamp meets the crossmember. It's nice and tight and the diameter arround the rack was tight on, just the outside was a wee bigger.
Any thoughts?
And no, no problem with the square one.
Leonardo is offline   Reply With Quote
Old 07-13-2004, 11:19 AM   #6
epoth
Member#: 49667
2004 WRX 2.5 Hybrid
8cm18G - PPG Helical
Mine did that too Leonardo. I'm going to have the guy at the alignment shop today give me his thoughts on if it makes any difference.
epoth is offline   Reply With Quote
Old 07-13-2004, 12:41 PM   #7
maxler3
Member#: 41513
i got it, theres only one way to put the knuckle back onto the column, theres an alignment groove that was on the other side of the coulmn that i couldn't see and i was trying to force it together while it was aligned improperly, i used whiteout to mark the aligngnment groove and got it up just fine in about 30 seconds, so all is well. also, my passenger side is also a little too long, doesnt' look like its gonna have any ill effects though. love the bushings though, exactly what i was looking for , INCREASED STEERING RESPONSE!!!!! yay
Old 07-13-2004, 04:36 PM   #8
epoth
Member#: 49667
2004 WRX 2.5 Hybrid
I asked the guy at the alignment shop, and he said he wouldn't worry about the bushing being squished over a bit since the rack is held in extremely tight by that bracket. There's no play in mine. He said to just check on it every so often and make sure the bushing sitll looks okay.
Old 07-13-2004, 04:47 PM   #9
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
Mine were done with the rack in palce. Rack not actually dropped.
I think the steering response thing is WAY overstated with this mod. Perhaps it is lost with the ALK, solid camber plates, stiff springs and all the chasis braces. I dunno. Doesn't feel much different to me if any. Not like other mods that is for sure.
ebeck is offline   Reply With Quote
Old 07-13-2004, 11:01 PM   #10
2.2gotboost
Member#: 22860
I put mine in without taking the steering linkage loose.
No big improvement here either. Maybe if I had no other suspension mods it would have made a bigger difference.
John
2.2gotboost is offline   Reply With Quote
Old 08-24-2004, 02:41 PM   #11
RobC
Member#: 38137
2002 S2000
I have a question. I had to drop my rack slightly and I was able to get it back to the original mark, but it just seems low to me. How high up on that shaft with the lines on it is it suppossed to go? Mine is close to the bottom and it worries me that maybe it is not high enough.
Thanks.
RobC is offline   Reply With Quote
Old 08-24-2004, 06:21 PM   #12
Rev1
Member#: 51240
08 Lexus IS350
Thanks.
How close to the end? Did you make a mark prior to loosening it up? Push hard up on the steering rack nd try to lock it up where it was
Old 08-24-2004, 07:00 PM   #13
RobC
Member#: 38137
2002 S2000
I did mark it, I guess just not that well. It seems pretty close to the end to me, although I think I have it back to the place that I marked off. I guess the best way to explain it is that I can't see or even feel the splined part coming through the hole in the bottom, if that makes any sense. It did move up a bit when I got the rack torqued up. I think I will climb back under there tonight and try to get it on a little further. I just don't want it to bind or something if it is too tight.
Old 08-25-2004, 05:55 AM   #14
zacek
Member#: 19467
04 WRX STi
WR Blue - original owner
I need more info on these hardened bushing, where exactly does it go and what vendors/brands are available? What's the main benefit?
zacek is offline   Reply With Quote
Old 08-25-2004, 05:52 PM   #15
RobC
Member#: 38137
2002 S2000
You can try this thread to get you started in your research. http://forums.nasioc.com/forums/show...ering+bushings
It has links to two very detailed sites with pictures detailing installation. The stiffer bushings replace your steering rack bushings and hold it in place much better than the rubber, which increases response. I bought the Whiteline ones for about $30.00 and they were well worth the cost and effort. The car turns in quicker now and has much better self-centering tendencies. I am still amazed at the difference this cheap mod makes.
Old 08-26-2004, 09:40 AM   #16
LyveWRX
Member#: 19057
& Blue Ford & '72 CB350
did mine last week and I noticed better overall steering feel. It seems to me that this is a very similar mod ot dooing the diff locks and bushings in back. Gives a bit of NVH in exchange for a bit better feel and alignment stability.
LyveWRX is offline   Reply With Quote
Old 08-27-2004, 08:29 AM   #17
GravelRash
Member#: 16318
2002 WRX Franknwagen
Grime over Sedona Red
There seems to be quite a variation among cars in terms of how tightly the rack is held with the stock bushings, so ymmv. Some of the previous threads describe cars where the rack moved enough side to side that the steering wheel would actually change its orientation in the straight ahead position when turned full lock one way or the other, or even under quick normal turns. Mine never did that at all.
I noticed an immediate difference with the Whiteline bushings, but it wasn't huge. Primarily more precision around the center zone. But for me, definitely worth the effort.
GravelRash is offline   Reply With Quote
Old 09-13-2004, 09:11 AM   #18
volkl23
Member#: 39092
2004 WRX STi
Java Black Pearl
Do the hardened bushings make the steering more twitchy? I like better response, but if it's annoyingly twitchy on the road, I think I'll pass.
volkl23 is offline   Reply With Quote
Old 09-13-2004, 12:48 PM   #19
maxler3
Member#: 41513
not at all twitchy. if anything, the steering is easier to control.
Old 09-13-2004, 03:11 PM   #20
volkl23
Member#: 39092
2004 WRX STi
Java Black Pearl
Hmmm, if that's the case, I might be more inclined to do it now.
shop recommendations for steering rack install? gregr01 South West Impreza Club Forum -- SWIC 14 08-14-2008 07:08 PM
[WTB] Front Lower bar Steering Rack Rod, Steering Rack Gaskets... Zak Shaker Private 'Wanted' Classifieds 0 02-12-2008 07:10 AM
grease for steering rack bushings? dorifto88 Brakes, Steering & Suspension 12 03-13-2005 02:13 AM
is it bad if you did your cousin if you didnt know she was your cousin? Johnny Knoxville Off-Topic 36 07-10-2003 07:54 PM
Need Your guys' help! If you have a rear diff protector, please post omahasubaru Mid West Subaru Owners Club Forum -- MWSOC 0 01-11-2001 09:44 AM
