Old 08-22-2004, 03:58 PM   #1
csacom
Member#: 27441
2003 WRX
Sonic Yellow
Question springs to get rid of front gap and not ride rough?
Forgive me if this question has been asked a hundred times already.
I have a 2003 WRX Sedan. I am not happy with the extra gap above the front wheels. I am running 225/45-17 Pole Positions. I am looking for suggestions on springs that will get rid of most of the front gap without making the ride too hard. I ride a lot of rough roads and would rather not have them throw me and the car around. I would also rather not have to any other suspension modifications. I have looked at the SPT Performance springs, but I am not really about what else is available or better. Any help with this matter is greatly appreciated!!
csacom is offline   Reply With Quote
Old 08-22-2004, 09:17 PM   #2
NWWagon
Member#: 66769
05 Focus "ST"
'80 Honda CM400T
With lowering the ride height you're alomst always going to have a higer spring rate so the car won't bottom out on bumps. But a vey good mild springs sets are made by Prodrive, Eibach, Perrin, and Espelir. Me personaly have the Espelir Active Super Down spring sets and can't complain about the ride quality at all. Infact it enjoy it more since I can take corners at speed that would make most others shutter in fear. Except other Subaru owners of course. But heres a few pics of the effect of that espelir set.
BEFORE
AFTER
NWWagon is offline   Reply With Quote
Old 08-22-2004, 10:26 PM   #3
csacom
Member#: 27441
2003 WRX
Sonic Yellow
Looks good! I have not heard of Espelir. Did you have them professionally installed?
Old 08-23-2004, 08:27 AM   #4
RADON
Member#: 46325
2005 Legacy GT Sedan
Prodrives here for comparison.
RADON is offline   Reply With Quote
Old 08-24-2004, 12:59 AM   #5
csacom
Member#: 27441
2003 WRX
Sonic Yellow
Looks good RADON, I like the rims. How does it ride?
Old 08-24-2004, 08:00 AM   #6
RADON
Member#: 46325
They ride very well. Much more firm yet very comfortable for my daily driver. Much less brake dive and quicker recovery from cornering. I've been happy with my choice and am looking forward to getting some inserts in about a year along with some new top hats. The only negative is that I have to slow down more than I did with the stock springs for speed bumps.
Hope that helps.
Old 08-24-2004, 11:42 AM   #7
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
well, i can say dont get the Eibach ones, as mine have a larger front gap then the rear, its sort of crapy looing. the rears almost look like they are too low, and the front look too high.
Shane
PARANOID56 is offline   Reply With Quote
Old 08-24-2004, 03:20 PM   #8
soso3
Member#: 36794
89 T I T A N
Shane
I have the Eibach pro kit and it lowers 1.3" front and 1.0" rear - which evens out the wheel gap from the factory springs.
soso3 is offline   Reply With Quote
Old 08-24-2004, 04:22 PM   #9
AttaQ
Member#: 20301
2004 BMW M3
lightweight optioned
If all you want is springs, I would say the Prodrives are a pretty good option. If you can spend a few more $$$, some low mile JDM take-offs would be a better all around suspension choice. I have JDM STI Spec-C take offs on my car and it lowers nicely, firms the ride up, but doesn't punish you.
AttaQ is offline   Reply With Quote
Old 08-25-2004, 12:49 PM   #10
csacom
Member#: 27441
2003 WRX
Sonic Yellow
I assume that Subaru does not sell any type of JDM spring here in the US? Since you purchased used springs, should I also assume that no one sells these new? Or are they very expensive?
NEEDS SPRING HELP!
Old 08-25-2004, 03:13 PM   #11
NWWagon
Member#: 66769
05 Focus "ST"
'80 Honda CM400T
Yeah Espelir just started showing up here in the US. They're a Japan tuner company that makes mostly suspension and exhaust. I got mine from World One. But no I did the install myself pretty simple suiff if you have all the right tools. Since I'm military we have access to a auto hobby shop that has all the tools you will need for just about anythign inlcuding lifts and such. But you can do this on jack stands with hand tools. But you you would have to get a spring compressor form a autoparts store which most have loaners that you can use for a day. I've never done a spring change before and it took me about 2 1/2 hours to do cause I got hung up on the rears a bit since you have to line up the top hats with the bottom of the strut. Fronts were super easy since the top hats rotate for steering. The main thing is to get teh car aligned after you lower it or you'll wear the tires funny and not get the full benifits of lowering. Hope everythign wroks out ok for you and good luck!!
Old 08-26-2004, 02:35 AM   #12
bboy
Member#: 56468
04 Improved STI
Dirty White
I too vote Espelir. I got the ASD springs. They are very close to the STi Pinks with at little higher spring rate. The ride improved, springs seem to work better with the struts. Overall roll and handling is tighter. I really like'm and you can't beat the price from World One (especially compared to Pinks).
I'm told the Espelir GT springs are very nice too, but alot stiffer. For a daily driver they may not be your cup o tea, but for track work they look very nice.
The Espelir exhausts are a work of art. To me the only thing with nicer welds and heavier hardware is Perrin. I'm sure there is other stuff, but not in that price range.
bboy is offline   Reply With Quote
Old 08-26-2004, 02:39 PM   #13
PARANOID56
Member#: 22035
2003 Brocoma DCab
Do you ahve a pic of your car? i would like to compair
Shane
Old 08-26-2004, 02:51 PM   #14
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Shane
I wonder if it has anything to do with the fact you have an RS, i.e. lighter engine, etc. Hence, the front is weighted as much compared to a WRX, leading to more fender gap up front.
Arnie is offline   Reply With Quote
Old 08-26-2004, 05:44 PM   #15
PARANOID56
Member#: 22035
2003 Brocoma DCab
could be, did not really think of that. but i though it was only a little bit of weight.
oh well, i wonder if i could make a rear spacer to raise up the rear
Shane
Old 08-26-2004, 06:55 PM   #16
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Or you could just cut a coil up front!
Old 08-26-2004, 07:10 PM   #17
Rich10
Member#: 14934
Just heat the front springs with a blow torch.
Rich10 is offline   Reply With Quote
Old 08-26-2004, 07:53 PM   #18
PARANOID56
Member#: 22035
2003 Brocoma DCab
yea, then we are getting getto and i already hit curbs so i dont want to be any lower, my rear tires are inside the fenders, and looks crappy. so, i want the rear raised.
oh well
Shane
Old 08-26-2004, 08:55 PM   #19
PARANOID56
Member#: 22035
2003 Brocoma DCab
here are the Eibach ones. sorry, for the bad pic
Old 08-26-2004, 09:01 PM   #20
CalcVictim
Member#: 57056
2006 Miata
Copper Red
I have Tein-S, and they ride firmer then stock so on crappy roads it's bumpy but otherwise great improvement in handling and looks. If I was choosing again I would get them again.
CalcVictim is offline   Reply With Quote
Old 08-27-2004, 12:02 AM   #21
StevesGT
Member#: 68193
Espelir is produced by the same company that make Volk wheels.
StevesGT is offline   Reply With Quote
Old 08-27-2004, 09:20 AM   #22
soso3
Member#: 36794
89 T I T A N
Take the dead bodies out of the trunk
j/k--that's weird.
I like your wheels-what type/size?
Old 08-27-2004, 11:08 AM   #23
PARANOID56
Member#: 22035
2003 Brocoma DCab
they are just some cheap 17" wheels that i got off of www.wheelmax.com. and sorry dont remember the size, but they are the same outside diam as the stock set.
yea, nothing in the trunk too. its looked like that since i have installed it, oh, it got a bit lower after they broke in
Shane
Old 08-28-2004, 12:48 AM   #24
csacom
Member#: 27441
2003 WRX
Sonic Yellow
Shane
I like the way the silver ring offsets the black centers. Sometimes black rims dissapear in the blackness of the tire and wheel well.
Old 09-13-2004, 12:54 AM   #25
csacom
Member#: 27441
2003 WRX
Sonic Yellow
Ok, the Prodrive springs were installed on Friday. So far I am very happy with them. I like the way the car sits, nice even well gaps. I also am very pleased with the handling. Honestly, I noticed a greater degredation in ride when I went from 16's to 17's. I think the car rides awesome, in fact I think it handles some bumps better than the stock setup. I like the way I can feel the road more, and the tightness of the suspension. Below are a few new pics. Thanks again everyone!
How to get rid of dust/pollen and not swirl paint after detail. tacomaprime Car Care & Detailing 19 05-28-2010 02:05 PM
Trying to pick springs to get rid of wheel gap cmac23 Brakes, Steering & Suspension 2 09-18-2007 10:06 PM
NJ to get rid of front license plates? trailertravis13 Tri-State Area Forum 62 08-07-2007 02:19 AM
petition to get rid of front plates requirement vile Southern California Impreza Club Forum -- SCIC 50 08-18-2006 05:51 PM
to get rid of my cats or not dynoguy Mid West Subaru Owners Club Forum -- MWSOC 8 05-01-2003 03:33 AM
