Old 07-12-2004, 04:16 PM   #1
Jaredm83
Member#: 65816
2014 Forester XT
Default 215/50 on RS Rims?
I got some 01 RS 16" 6 Spoke wheels, will a 215/50/16 be a good choice for tie size?
Jaredm83 is offline   Reply With Quote
Old 07-12-2004, 04:19 PM   #2
driggity
Member#: 7453
2014 Scion FR-S
Hot Lava
If you want slightly lower than stock gearing it will work ok. 225/50 16 will be the same diameter as stock and will keep your speedometer/odometer accurate. Assuming that your car had 205/55 16 tires on it stock.
driggity is offline   Reply With Quote
Old 07-12-2004, 04:25 PM   #3
Jaredm83
Member#: 65816
2014 Forester XT
how will that tire look on the rim tho? will it buldge out? By the way how wide are my rims? And whats the offset? How about the fact that my car will be lowered with the eibach pro kit, 1" front 1.2" rear?
Old 07-12-2004, 04:53 PM   #4
driggity
Member#: 7453
2014 Scion FR-S
Hot Lava
It will look fine. The rims are 16x7 with a +53 offset. Assuming you have an Impreza of some sort you should be ok with that size tire and that amount of lowering. You really should fill in what kind of car you have if you are going to ask questions about what will fit on it.
Old 07-12-2004, 05:13 PM   #5
rexpdx
Member#: 34729
06 WRX Wagon CGM
01 2.5RS coupe white
225/50/16's will not fit on an 01 RS, lowered or not. The inside edge of the rear tires will rub the struts.
The fronts will fit fine but the only way to make that size fit the rears is to use a hub spacer and roll the rear fenders a little.
edit: Oops, should have read a little closer. I assumed that because he said he had 01 RS 6 spoke wheels, that he had an 01 RS. If not, then 225/50/16's will fit perfectly on any GD.
rexpdx is offline   Reply With Quote
Old 07-12-2004, 05:30 PM   #6
Jaredm83
Member#: 65816
2014 Forester XT
oh crap, I forgot to mention, I have a 98 L sedan.
Stock wrx tires on rs rims Tombo Interior & Exterior Modification 3 10-26-2007 02:46 PM
225/50 on WRX Rims? Sub25RSDTown Tire & Wheel 3 05-24-2004 10:30 AM
225/50 On Stock Rims simoniac Tire & Wheel 2 07-21-2003 04:28 PM
205/55-16; 215/50-16; or 225/50-16 on stock rims? WRXNE1 Brakes, Steering & Suspension 12 07-08-2002 10:45 AM
225 50 16 on RS rims, will they rub with eibach springs and kyb? WRxednEffect Brakes, Steering & Suspension 2 04-13-2002 05:16 PM
