Old 07-12-2004, 06:28 PM   #1
animosity
Member#: 59395
2007 2.5 RS Wagon
Crystal Gray Metallic
Default rubbing sound taking corners or swirving
had my car 3 months loving and hating it (more love though :>) since ive had it there has been a rubbing sound coming from the left side of the car
dealership said ah bearings so they replaced them
its still making the noise
dealership said ah rotors and break pads
1k$ later its still making the noise and no one so far can tell me whats making it but they can sure tell me what else needs to be fixed ;p
basically the sound is coming from the back left side its a metal on metal rubbing sound that always happens when i take a right turn or right swerve harder than i should and occasionally when i take a right turn at a slow speed (10mph or so)
ive taken off the back left wheel (thats where i assume the noise is coming from) its the only wheel on the car where the inside of it is filled with rust and it looks like a new caliper was put on there before i bought it so im assuming there were problems with this before anyways i didnt see anything wrong from what i could see but i didnt take anything else apart
i dont see any break dust build up or any grooves/wear in the rotor although the pads seem to be touching it i dont have a problem at all with breaking and the car doesnt seem to slow down faster than it should when im not giving it gas
so far 2 dealerships 1 mechanic and a few friends havnt figured it out so any suggestions at all are welcome im goin broke ;p
-animosity
member of the no punctuation army
animosity is offline   Reply With Quote
Old 07-13-2004, 01:53 PM   #2
Makalu24
Member#: 66089
2002 RS
ive got an 02 RS and was experiencing similar noises on hard right corners i also have an aftermarket exhaust which i found to be causing the noise. the exhaust was loose and would knock on corners, i fixed the problem by securing the exhaust tighter with a metal clamp
Makalu24 is offline   Reply With Quote
Old 07-13-2004, 04:55 PM   #3
Pat L.I.
Member#: 20498
2006 WRX TR
i get a similar clunking taking right corners due to my exhaust aswell. at first i thought it was my tires rubbing.
Pat L.I. is offline   Reply With Quote
Old 07-13-2004, 06:06 PM   #4
jamesfacts
Member#: 51282
98 RS
black & blue from parking
What do you drive?
jamesfacts is offline   Reply With Quote
Old 07-13-2004, 06:11 PM   #5
animosity
Member#: 59395
2007 2.5 RS Wagon
thanks guys ill check it out tonight
i drive an 00 2.5rs
Old 07-13-2004, 06:28 PM   #6
saar
Member#: 43770
2013 Impreza WRX
RNN14 GTiR
are you running an OE 13mm RSB? i had rubbing issues going through hard corners before upgrading to a 20mm RSB...now with the 20mm ..i have never heard the rubbing ....
saar is offline   Reply With Quote
Old 07-15-2004, 10:51 AM   #7
t3hWIT
Member#: 58779
95 STi RA (rhd)
98 Tacoma (300k Club)
i used to get a weird noise when cornering hard. turns out my aftermarket wheels were rubbing in the fender. :-/
t3hWIT is offline   Reply With Quote
Old 07-15-2004, 05:13 PM   #8
suby25
Member#: 52822
2015 WRX
I have the same problem, but its on all 4 fenders... not sure if its the tires or wheels, but they rub like WHOA!
suby25 is offline   Reply With Quote
Old 07-15-2004, 06:08 PM   #9
animosity
Member#: 59395
2007 2.5 RS Wagon
havnt had time to check it yet ;x
its oe bar and if i upgrade it i cant be in GS anymore
Old 07-26-2004, 03:16 PM   #10
animosity
Member#: 59395
2007 2.5 RS Wagon
messed around with the exhaust im not sure how loose it is compared to other subarus but compared to my friends celica there is some major play in it and if i shake it slightly it moves back and forth all the way up to the engine but from what i saw there was nothing for it to rub against
but i ordered 4 kartboy hangers anyways its worth a try ;p
i took some different pics of the back end underneath since thats where the grinding sound is coming from not sure if theyre going to be any help
click <--
Old 07-26-2004, 03:22 PM   #11
Pat L.I.
Member#: 20498
2006 WRX TR
yeah my exhaust has major play aswell.. i can bounce it off the diff by hand
Rubbing sound when banking to the right, rattling sound when making hard left! Help! OhmZoned Transmission (AT/MT) & Driveline 0 06-27-2007 05:52 PM
tire rubbing under hard cornering (left turn only) jlam86 Brakes, Steering & Suspension 11 05-23-2007 02:56 AM
Rubbing sound from rear of car Ryan24 North West Impreza Club Forum -- NWIC 7 07-10-2001 10:59 PM
Rubbing sound from rear Ryan24 Brakes, Steering & Suspension 0 07-08-2001 10:46 AM
Rubbing sounds . . . Please help ANW Brakes, Steering & Suspension 18 05-09-2001 06:22 PM
