Old 07-13-2004, 05:44 AM   #1
PhreeZe
Member#: 11676
2003 350Z
Super Black
Default Pics of Hella FF1000
Anyone have some pics of ther Hella FF1000 on here WRX? If you have any with the lights on, that would be great. Also is it possible for those lights to match a 6000K HID? Doesnt have to be a perfect match but if they look pretty close, that would be cool. Anyways let me know and lets see those pics
Jason
PhreeZe is offline   Reply With Quote
Old 07-13-2004, 12:32 PM   #2
dithergizzard
Member#: 58232
The halogen versions of the FF1000s will not match 6000K HIDin colour. The HID version will come closer. However, since the FF1000 HIDs are rally lamps, they are most likely optimised for maximum light output, meaning they will be about 4100K-4300K; this light will be very white as opposed to the blueish-white of 6000K bulbs.
For pics, do a search under FF1000.
dithergizzard is offline   Reply With Quote
Old 07-13-2004, 07:45 PM   #3
well_armed
Member#: 15204
J-
why didn't you just ask me?
http://www.pbase.com/image/25069273
http://www.pbase.com/image/25069248
note: I am running 100 watt bulbs in them
well_armed is offline   Reply With Quote
Old 07-13-2004, 08:44 PM   #4
PhreeZe
Member#: 11676
2003 350Z
Super Black
D,
I didnt know you had them! Man those look great... I may pick up a set
Jason
Old 07-13-2004, 11:36 PM   #5
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
Sorry for hijacking, but is that a Hella bi-xenon? Looks a bit large for the 90mm module.
satrya is offline   Reply With Quote
Old 07-14-2004, 10:39 AM   #6
bleuquila
Member#: 31922
03 wrx wagon
fastAr than sound
I can't seem to find the ones with all the lights lit up, though sorry. Also 100 w bulbs in there
bleuquila is offline   Reply With Quote
Old 07-14-2004, 08:18 PM   #7
well_armed
Member#: 15204
Yep, Hella bi-xenon's retrofitted into the stock MY03 headlights....
Let's just say I have probably one of the best lit roads in front of me...
Here is a pic of just the low's in action...http://www.pbase.com/image/25069160
Old 07-15-2004, 02:05 AM   #8
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
Thanks. I saw that picture from the link you provided on a previous post.
It still seems larger than a 90mm unit (which the bi-xenon should be afaik).
Old 07-15-2004, 11:43 AM   #9
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
Do those FF1000's work with the Kartboy lamp brackets? Or do you need to use the Hella brackets?
Old 07-15-2004, 12:37 PM   #10
well_armed
Member#: 15204
They look a little bigger because they have a shroud from a Mercedes around the projector unit...to give a finished look.
I believe they would. Have you purchased the lights an/or bracket yet?
If not, just buy this kit from rallylights.com: HL74539W ($152 for the lights and brackets for our WRX's)
Old 07-15-2004, 01:15 PM   #11
Psydotek
Member#: 44168
2003 Yellow WRX
I haven't bought anything yet, still doing my research, and still trying to convince myself to buy them (need to wait a little bit too, just bought a rear anti-sway bar)
Old 07-15-2004, 03:11 PM   #12
well_armed
Member#: 15204
Starsky: "Do it...no....do it!"
Old 07-15-2004, 03:33 PM   #13
Psydotek
Member#: 44168
2003 Yellow WRX
You're not helping...
Originally said by Big Earl
"Now TWO dragons..."
Old 02-25-2005, 12:57 AM   #14
GlenCastleberry
Member#: 63067
2002 Impreza WRX
World Rally Blue
This is a bit of thread digup, but are you guys who are running the 100W bulbs in your Hella 500s running them with the stock wiring harnesses? Got any melts yet?
GlenCastleberry is offline   Reply With Quote
Old 02-25-2005, 01:04 AM   #15
Psydotek
Member#: 44168
2003 Yellow WRX
Don't run anything over 55w with the stock wiring... Guaranteed you'll melt something. Maybe not right away, but something will go kaput sooner or later.
[casual observation: my previous posts in this thread were made before my current lighting addiction...]
Old 02-25-2005, 09:40 AM   #16
aura781
Member#: 26287
2002 Impreza 1.6
your install is way cool. how was the whole process? painful?
how much did it cost, and hows the aim of light etc?
cost?
sorry for the barrage of questions, but will be quite keen to do
something for myself if possible.
aura781 is offline   Reply With Quote
Old 02-25-2005, 09:49 AM   #17
ibsailn
Member#: 79295
Better yet, save 20 bucks and buy the two parts separate (at least while they have the lights on sale). I just installed Tuesday night. Even in the dark it only took a bit over an hour. Lighting is awesome.
ibsailn is offline   Reply With Quote
Old 03-03-2005, 06:01 PM   #18
Cheveyboy
Member#: 34773
2013 WRX STi
wich 100 watt bulb would be used in the ff1000s. I would like to order both at the same time. I see that they sell hallogen H1's and Xenon H1's. Would either work?
Thanks !
Cheveyboy is offline   Reply With Quote
Old 03-03-2005, 06:05 PM   #19
Psydotek
Member#: 44168
2003 Yellow WRX
^^^H1 bulbs
Old 03-03-2005, 06:05 PM   #20
Cheveyboy
Member#: 34773
2013 WRX STi
LoL sorry, just eddited my post, Halogen or Xenon?
Old 03-03-2005, 06:18 PM   #21
Psydotek
Member#: 44168
2003 Yellow WRX
Oh, unless you have the HID specific FF1000 lamps, get the Halogen bulbs.
Old 03-09-2005, 10:10 AM   #22
Cheveyboy
Member#: 34773
2013 WRX STi
I have two questions, the first one is about the ground wire supplied with the lights. It doesnt look long enough to go from one light to the other. So was woundering if any one just used a seperate ground for both lights? Or did you make the supplied one work.
Sec question is about the bracket supplied. It doesnt look like it alows for much adjustment down. When its as far down as it will go, the globe is still posistioned a degree up or two. Has anyone else had problems with the lights aimed too high? I guess i could shim the braket against the bumper to point it down some more.
Old 03-09-2005, 10:32 AM   #23
Psydotek
Member#: 44168
2003 Yellow WRX
Well, i have a custom wiring harness so everything's grounded back to the battery. If you're putting the lamps in the OEM foglamp wells, and you're not using bulbs higher than 55w, then you can just plug them into the OEM wiring.
As for the bracket, i have no idea...
Old 03-09-2005, 10:54 AM   #24
Cheveyboy
Member#: 34773
2013 WRX STi
Nope, 100watters. Ill just have to make my own ground harness. Still in question about the brakets though. The workmanship is beautiful, but they dont give any room for adjustment other then up.
Old 03-09-2005, 11:47 AM   #25
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
I'm not sure what you mean. My Prodrive lamps (rebranded FF1000s) had all the adjustment I needed. You could just bend the bracket down if there isn't enough high adjustment though.
mbiker97 is offline   Reply With Quote
Post pics of what you consider good/real mexican food edkwon Off-Topic 156 08-09-2010 11:27 AM
pics of bugeye c-west lip + solid fog covers? trueno92 Member's Car Gallery 9 06-03-2010 06:34 PM
Need pair of Hella FF1000 in bay area ASAP! dchou Bay Area Impreza Club Forum -- BAIC 2 08-11-2007 06:41 PM
NJ: Hella FF1000 driving lights with 2 sets of covers InfamousDX Private 'For Sale' Classifieds 6 09-15-2005 12:03 AM
need pics of hella 550's piker28 Electrical & Lighting 0 02-07-2004 06:48 PM
