Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 07-13-2004, 08:58 PM   #1
jimtesla
Member#: 64765
2005 Want a Baja
Red or Silver
Subaru Banner Baja Warranty Issues
Hey
I wanted to start a thread where all could post any issues you needed looked at while your Baja was and is under Warranty....
This should give a heads up for all the rest of us........and assist others to have things looked at before the warranty runs out.
Maybe they could make this a sticky...........always on top.......
For all to see......
jimtesla is offline   Reply With Quote
Old 07-13-2004, 10:32 PM   #2
Mike Franke
Member#: 61518
2003 Baja
Black/Silver
O.K. First and only problem with the car; nearing 13K miles:
Twice into the dealer for loss of refrigerant. Second time around, they found a leaky schrader valve, and replaced the line.
So far, so good, a loaner each time (no ****, a WRX the first time)
Thank you, Reeves Motorcars!
Mike Franke is offline   Reply With Quote
Old 07-14-2004, 06:11 PM   #3
Peloquin
Member#: 41307
2003 Baja
Regatta Red/Silver Stone
I've only had two problems in the year that I've had mine.
First was right after I bought it, I even noticed it on the way home. The left turn signal wouldn't work, but only after the car had been in the Texas sun for a few hours. Turned out to be a bad fuse and they replaced it for free.
Second was after my latest oil change, the Skid Plate on the passenger side was ripped off, but I didn't do anything that would cause it to be damaged. Turns out, the bolt that holds the skid plate on is often not tightened after an oil change. They replaced that for free, too.,
Both times were quick and painless. The first time I was even given a rental car for free, but it was painful because it wasn't my Baja.
Peloquin is offline   Reply With Quote
Old 07-15-2004, 09:43 AM   #4
braveit1
Member#: 44810
2003 Baja w/Snuglid
Black & Silver
When I first pick up my Baja it pulled to the right. Deal had an alignment done under warrenty. I also had the tim around the top drivers door replaced because it was bent from the way they glued it in. It took them three times to repair it correctly but it's fine now.
braveit1 is offline   Reply With Quote
Old 07-15-2004, 09:47 AM   #5
hatake
Member#: 34811
04 Baja T
For whatever it's worth, the back passenger side weather strip came loose (twice) and the driver side window washer nozzle popped out and flew away on the highway. The dealer replaced all for free. Other than that, so far so good (9500 miles).
hatake is offline   Reply With Quote
Old 07-15-2004, 12:36 PM   #6
roomfr2
Member#: 53969
2003 Baja
Baja Yellow
The A/C stoped working at 7,500 miles ! They replaced the compressor . I hope this isnt a sign of things to come
roomfr2 is offline   Reply With Quote
Old 07-15-2004, 11:42 PM   #7
Mike Franke
Member#: 61518
2003 Baja
Black/Silver
Has anyone experienced any sort of front door misalignment? I have noticed a strange "dropping" sensation immediately upon unlatching the driver's door. Not the same at all on the other side.
I'm sure the dealer can check it out; just wanna hear if anyone has had this happen...
thx
Old 07-23-2004, 02:20 PM   #8
cyphergirl
Member#: 66816
2003 Baja Sport
Black / Silver
I've only had one warranty issue, and that was the Tonneau cover. I had purchased the Subaru cover and had it installed the first week that I owned the car (Approx Nov 1, 2003). By the first week of June (that's what, 6 - 7 months?) it was looking ratty, had seams coming out, holes in seams, the rib wouldn't stay in place to keep water off of it.
I'm not pleased with the quality of the cover compared to the price paid, but the dealer did replace it when I had the car serviced a couple of weeks ago.
cyphergirl is offline   Reply With Quote
Old 08-17-2004, 03:47 PM   #9
beams53
Member#: 67615
2005 baja turbo
black
the door issue is a simple re-adjustment; I had the same problem with my 05. But now the door rattles everytime I close it. Sounds like something loose in the door.
beams53 is offline   Reply With Quote
Old 08-26-2004, 10:38 AM   #10
roomfr2
Member#: 53969
2003 Baja
Baja Yellow
A/C out again !! 2nd time . This time the replaced the valve & a line . I hope this solves the problem .
Old 08-26-2004, 01:07 PM   #11
Pursuit
Member#: 38370
The little rubber, triangular boot at the front of my front windows has ripped at the top where the window pushes it up when it's rolled all the way up.. whew what a sentence! Anyone else have this problem? Haven't talked to the dealer about it yet.
Pursuit is offline   Reply With Quote
Old 08-26-2004, 03:05 PM   #12
aross
Member#: 831
11 Blurple WRX
03 BH MBP
That is a "Gusset" in Subaru Speak..
aross is offline   Reply With Quote
'05 Baja Turbo Issue tbone256 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 09-03-2009 04:52 PM
Warranty Issues - Everyone Pls Read gavin Normally Aspirated Powertrain 15 05-03-2001 08:21 AM
Dealers and the Warranty Issue Danny5 South West Impreza Club Forum -- SWIC 9 03-24-2001 08:57 PM
Dealer Warranty Issue GTMAN General Forum Archive 2 10-21-2000 11:27 PM
Warranty Issue ??? Please read... MKULTRA General Forum Archive 15 05-24-2000 01:06 AM
