Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 07-13-2004, 08:46 PM   #1
jac04
Member#: 49895
09 Forester
06 Legacy 2.5i Wagon
Default Annoying Clutch Pedal Squeak
My 2005 WRX with less than 350 miles developed a very annoying squeak at the bottom of the clutch stroke. It was driving me nuts. I crawled under the dash and finally found that it was the switch for clutch disengagement (the upper switch). I removed the switch, took it apart, greased the plunger, put it all back together and now the squeak is gone.
I thought I would share this in case anyone else has this problem.
-Jeff
jac04 is offline   Reply With Quote
Old 07-13-2004, 09:55 PM   #2
kenchan
Member#: 15106
My car use to squeak when it was new too...but after about
400 miles, it stopped...
kenchan is offline   Reply With Quote
Old 07-14-2004, 04:20 PM   #3
Dale_K
Member#: 42342
Seems to be a pretty common problem. My new 05 squeeks too. Hope they can fix it when I take it in for the first oil change.
Dale_K is offline   Reply With Quote
Old 12-31-2004, 09:17 PM   #4
kool168
Member#: 61006
-Jeff
do you have a step by step instruction to share?
thanks
kool168 is offline   Reply With Quote
Old 01-03-2005, 03:11 PM   #5
jac04
Member#: 49895
09 Forester
thanks
Sure.
1) Locate the offending plunger type swith. Push the driver's seat back as far as it will go, and lay on your back looking up at the clutch pedal pivot area. Using a flashlight, look up as you depress the clutch pedal with your hand - you will see the switch that is activated by the clutch pedal when the clutch is fully dis-engaged.
2) Unplug the switch.
3) Using a 14mm open end wrench, loosen one of the nuts holding the switch in place (there are 2 nuts that jam against a bracket to hold the switch in place). This step is a PITA, but you will eventually get it.
4) After removing the switch, take it apart. You will need to VERY carefully release the clip on each side of the end of the switch. Be careful not to loose the spring inside the switch.
5) Lube the inside of the switch, staying away from the electrical contacts. I used some brake caliper synthetic grease since it has a hig drop point and it does not tend to liquify like some conventional greases.
6) Reverse the above process for re-assembly.
I hope this help.
-Jeff
Old 01-15-2005, 04:32 PM   #6
kool168
Member#: 61006
Sure.
I hope this help.
-Jeff
thanks
Old 10-20-2006, 05:20 PM   #7
STIdrivr
Member#: 103261
Is what your talking about shown in the picture on this thread?
http://forums.nasioc.com/forums/showthread.php?t=932614
STIdrivr is offline   Reply With Quote
Old 06-24-2009, 09:34 PM   #8
lhessenauerl
Member#: 178139
2004 WRX
had this same problem and fixed it after reading this thanks!
lhessenauerl is offline   Reply With Quote
Old 06-26-2009, 11:58 AM   #9
RallyIt07
Member#: 158498
07 WRX w/ JDM 6spd
that or you can get it replaced at the dealership. SOA released it as a faulty switch. I got mine replaced and hasn't done it since.
RallyIt07 is offline   Reply With Quote
my clutch pedal squeak story (lube pics inside) Dendrobium Service & Maintenance 10 09-14-2008 01:55 AM
Clutch pedal squeak file_id Transmission (AT/MT) & Driveline 2 06-11-2003 03:02 PM
Annoying Clutch Pedal Squeak balrog Transmission (AT/MT) & Driveline 8 02-17-2003 10:55 AM
How do you get rid of clutch pedal squeak FatCatTurbo Transmission (AT/MT) & Driveline 6 12-11-2001 10:45 AM
Clutch pedal squeak Texas25RS Texas Impreza Club Forum -- TXIC 2 08-14-2001 10:30 AM
