Old 07-14-2004, 03:19 PM   #1
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Default Stock Alt + Underdrive is bad, but what about HO + Underdrive?
It's known that our alternators can be maxed out just by turning on every accessory our car's come with. Adding a stereo just adds to that drain and in some cases maxes out the alternator.
Underdriving the above setup is not a good idea if you have an aftermarket stereo setup.
I'm wondering what you could do once you've upgraded to a HO alternator.
I'm moving from the stock 70a to a 160a alt. This is giving me 90 more amps to play with and my system probably only draws 40 at peak.
If this HO alt can push over 60a just at idle...and over 120a at 1500rpm...I wonder how it would handle being slightly underdriven..
120a at 1500 is 40a over stock's max and all I'd need as a peak drain.
Thoughts?
-- Dave
AcquaCow is offline   Reply With Quote
Old 07-14-2004, 04:59 PM   #2
nqwan
Member#: 2916
02 duburu arr exu
The GFB underdrive pulleys come with a smaller alternator pulley to keep it spinning at the same speed.
nqwan is offline   Reply With Quote
Old 07-14-2004, 06:58 PM   #3
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
wouldn't you need a larger alternator pulley if you go with a smaller main pulley?
Old 07-14-2004, 07:47 PM   #4
JT Clark
Member#: 38112
2003 Impreza TS
You may also experience (more) voltage drops at the lower RPMs as well.
JT Clark is offline   Reply With Quote
Old 07-14-2004, 10:11 PM   #5
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
I'm not really planning on underdriving anything...if I swap the pulleys, it'll be for lighter weight ones...
My engine already hits revlimit in 1 sec flat when not in gear. If I under drive it the rev's will drop faster than I can shift. I need big pulleys spinning =)
Old 07-14-2004, 11:07 PM   #6
JT Clark
Member#: 38112
2003 Impreza TS
Be careful of overreving the alt if you get overdrive pulleys.
1 different tire is bad, but what if you run 2 pairs of tires?? Hazdaz Tire & Wheel 6 03-06-2007 12:53 PM
New Alt, battery is fine but no charge??? scoobydorift Electrical & Lighting 1 02-09-2006 12:46 AM
Crossposting is bad, but this is a poll... Handsdown Off-Topic 11 02-07-2005 04:15 PM
So there is pic hosting...... But what about file hosting? The_Triton Off-Topic 7 07-20-2004 10:12 AM
Debadgeing is common. But what about Re-Badgeing? Snoopy General Forum Archive 10 02-20-2001 12:23 AM
