Old 07-14-2004, 06:35 PM   #1
Cole
Member#: 64219
2011 Outbackness
2008 Legacy NA Hellastock
Have a Nice Day? slooooooow leak question
Setup = 17" OZ SuperLG (2 months old & PERFECT) w/Kumho Ecstas
Problem = I'm losing about 10-15psi per week from one tire. Nothing visually detectable, and I have not yet taken the wheel off to put it in water to search for the leak.
Question = If I use some fix-a-flat spray nonsense, do you think that would to the trick for me?
Cole is offline   Reply With Quote
Old 07-14-2004, 06:41 PM   #2
poison
Member#: 37678
Yes it probably will, but you are better off having it patched/fixed at a good tire shop. Especially since theyre new....
poison is offline   Reply With Quote
Old 07-14-2004, 08:22 PM   #3
bobsrex
Member#: 42872
MY02 Impreza WRX
yea ntb patched mine up for like 10 bucks...definitely worth it
bobsrex is offline   Reply With Quote
Old 07-14-2004, 09:35 PM   #4
Clavo
Member#: 22303
2002 WRX Wagon WRB
2006 W211 e55 AMG White
Default Valve stems ?
Check your valve stems also. Sometimes the metal ones aren't tightened enough. A little spit'll do fine.
Clavo
Clavo is offline   Reply With Quote
Oil leak question, WRX Tex-WReX2 Service & Maintenance 14 07-11-2002 09:03 PM
Vacuum Leak Questions forced4 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-03-2002 03:13 PM
exhaust leak question GimpWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-21-2001 02:36 PM
Boost leak question Blugin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-26-2001 12:45 PM
exhaust leak question montgog Normally Aspirated Powertrain 1 08-02-2001 12:05 AM
