![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#1 |
Member#: 1418
Vehicle:MY00 2.5RS Aspen White |
I have ordered a set of H&R springs and am about to get a set of STi Ver. V struts. I want to make a complete second setup of springs and shocks so that all i have to do is remove the entire stock setup and install the other set and vice versa if needed without having to make a trips to a shop each time to have the springs removed and replaced. what I need is a list of parts and numbers needed to do this minus the nuts and bolts. thanks in advance....
Andy
#2 |
Member#: 274
You'll most likely just need a set of pillow ball mounts, as most setups don't seem to include them.
you'll also probably want a re-alignment (I would at least) after doing this, it's not quite like just changing wheelsets........ RP |
#3 |
GC84Ever
Super Moderator Member#: 301
NWIC
Vehicle:2001 2.5 RS/70 Van 02 WRX Rally Stud |
why would you need trips to a shop??
can you remove them yourself?? rent a spring compressor $5 change them out?? ![]() |
#4 |
Member#: 216
Well... it's not *that* easy Subie Gal. I say that because quite a few people have killed themselves with a spring compressor.
But changing the suspension on an Impreza isn't the most difficult job. Even a moderately skilled mechanic can complete this job in a few hours. |
#5 |
Member#: 2338
Vehicle:1988 323 GTX black |
I just did the swap to KYB's and when I was doing the front ones, the bolt on the top shot across the room. I got one back together by myself, but asked for help on the second one and it went much faster.
#6 |
Member#: 1418
SubieGal -- I plan on doing the work myself (maybe) what I want is two complete independent spring/strut setups 1 being the stock setup and 2 being the my H&R/STi setup. Sothat all I have to do is completely remove one or the other without having to use a compressor more then once.
#7 |
Member#: 2348
Vehicle:2006 WRX TR Steel Grey Metallic |
If you use a spring compressor, never get above it or in front of it! Be careful! Those springs have a lot of energy stored up in them......Always wear safety glasses too. I had the cheapo rental compressor break and shoot a VW spring into the side of my jetta, dented the **** out of my car....scared the **** out of me.
#8 |
Moderator Member#: 922
Vehicle:04 FXT Red |
People... the springs on the Impreza aren't THAT compressed. Even taking them off stock struts or even a v5 setup it barely pops up. it's not a big deal. Putting springs onto AGX struts takes nearly no compression at all. If you're working with a big guy, he can compress everything you need by hand to do it.
*Note: if you happen to kill yourself this way, I'm not responsible, but this is just to cover my arse here. ![]() |
| Thread Tools | |
| Display Modes | |
| What is needed to go from 235whp to 285whp | Twenty36_1 | Proven Power Bragging | 26 | 03-17-2006 12:24 PM |
| JDM STi pinks on a bugeyes. What is needed to make them work? | Dizmal | Brakes, Steering & Suspension | 4 | 01-29-2006 10:07 PM |
| These TomTom commercials are what is going to make me finally break my TV. | eurojax | Off-Topic | 11 | 10-21-2005 03:40 PM |
| I just thought of what Subaru needs to make... | Corn-Picker | News & Rumors | 6 | 05-01-2003 05:06 PM |
| What is used to make a front grill? | IMPREZA GUY | Interior & Exterior Modification | 5 | 07-14-2001 07:16 PM |
