![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 59816
Vehicle:2004 WRX World Rally Blue |
If you want to know, the wheel is the Enkei RS7 in Anthracite. Heres a link for the specs.
http://www.enkei.com/PerfSpecPAGES/rs7Specs.html ???
#2 |
Member#: 47769
THey would be close to the fender, but should clear. Those 18x7.5 ET 45 would fit fine.
#3 |
Member#: 10279
Vehicle:2005 Lotus Elise Yellow, #94 SS |
They should fit, but the offset is far from ideal. Unless you really need to have them for their looks, I would look for a wider wheel with a better offset. 17x7.5" or 17x8" with an offset in the 45-48mm range.
#4 |
Member#: 47769
Enkei has wheels that are very similar to those that are wider and in a more Subaru friendly offset.
#5 |
Member#: 59816
I haven't seen anything similar to those, I really like them. Would those 18x17.5 45 offset really fit fine? I would probably go with those if they do.
What would happen in the long run if someone was to put a bad offset on? |
#6 |
Member#: 47769
The 18x7.5would fit fine. In the long run the wheel bearing may die prematurely, but that is it. That probably would not happen with a 45 mm offset on the 18x7.5. I wouldn't worry about problems with that size.
#7 |
Member#: 59816
Do 18" wheels look good on a WRX? Am I going to have to drop the car? Any pics?
#8 |
Member#: 47769
THey looks good, but will slightly hinder performance. I think with any wheel the car needs to be dropped. Remember, the purpose of upsizing your wheels is to give you the right look, but you want to keep the diameter correct.
| Thread Tools | |
| Display Modes | |
| Will 215/60-16 work on oem WRX Wheels? | Takashi | Tire & Wheel | 2 | 01-15-2004 01:03 PM |
| will a 17x7 with 40mm offset work on a wagon?? | red acr | Tire & Wheel | 4 | 12-19-2003 08:30 PM |
| Will 42 offset work? | sumo | Brakes, Steering & Suspension | 0 | 04-14-2002 10:47 PM |
| will 235/45 17's fit on a 17x7.5 w/50mm offset? | couldnthinkaone | Brakes, Steering & Suspension | 2 | 04-30-2001 04:20 PM |
| will a +45 offset work on an 18X7.5 wheel? | scootr | Brakes, Steering & Suspension | 13 | 03-17-2001 07:37 AM |
