Old 07-15-2004, 07:49 AM   #1
Rainierez
Member#: 66332
2000 Impreza RS
Question Engine build up questions
Ok I'm kinda new in the scooby world but it seems I have alot of options for turboing my 2.5 and I wanna throw up a "pros and cons" thread. As it stands now I have the SOHC EJ25 in my car. I don't want that turboed cause of the hih compression rate. I have a spare EJ25 DOHC engine in my shop. So I Suppose my question is what would go better, the STI short block with the SOHC heads or DOHC? Or even the EJ22T shortblock with either set of heads. I have follow up questions based on all 4 answers E-mail me if you have pics of a certian setup or would like to buy the one of the two spare EJ25 blocks off of me.
Chris C.
Rainierez is offline   Reply With Quote
Old 07-15-2004, 08:02 AM   #2
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
If you have any ej22 questions this should help... http://forums.nasioc.com/forums/show...highlight=ej22
SOHC would flow better down low and DOHC up top, but either would work...
Old 07-15-2004, 01:39 PM   #3
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
Default turbo
Personaly I'm going with the ej22t on my stock 98 DOHC heads, basicly NO wiring
the sti shortblock, even though semi closed deck, is still VERRY open. The cylinder walls are verry thin compared to the ej22t. If you someday want to upgrade past 400HP, then I would stay away from the ej257.
as far as heads go, duel overhead cams are always better than single. But if you have the SOHC mounted up on the car already then it would be pretty much plug and play. in the end it all comes down to how much total power you are looking for and just how involved you want to become in your project.
IllNastyImpreza is offline   Reply With Quote
Old 07-15-2004, 07:49 PM   #4
Rainierez
Member#: 66332
2000 Impreza RS
Well i was thinking the ej22t as well I have the DOHC sitting around and would probly put them on the EJ22t block. A few questions there what do i have to do to make the EJ25 DOHC fit and work eff. witht he 22t block? Also what kinda wiring will i have to change, I'm an electronic repair tech so no of that scares me just want to know before i jump head long into it. Side question would finding a EJ22T ECU be a good thing for the engine esp. once it is turboed or will a stand alone or piggy back work better??
Old 07-15-2004, 08:28 PM   #5
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
I have an ej22T swap in my car and I am looking at putting some 98 DOHC heads onto my block. The only thing I am woried about is the fact that the DOHCs blow head gaskets all the time.
subiekid is offline   Reply With Quote
Old 07-15-2004, 09:22 PM   #6
kaos200
Member#: 2692
there are plenty of people pushing past 400 hp on the 257, so I dont see the basis for that statement
kaos200 is offline   Reply With Quote
Old 07-15-2004, 09:23 PM   #7
totoherbs
Member#: 7321
.... 122 IggPoints
Well one persons 400 is anothers 300 so... I think what he means is if your looking for 400 and over go with a built block. A sock subaru block will hold 400-450 but not for very long.
Old 07-16-2004, 06:58 PM   #8
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
this has been discussed before when people questioned the ej25's open deck nature. It doesnt come down to how much peak horsepower and boost it can hold at one time, But rather for how long you can punish the relitavely weakly reinforced walls of the block.
If I could figure out how to post picstures I could post the ej25 vs ej22t vs ej257. can someone help me out?
It seems that the STI block, as well as the ej25 have ALOT of unreinforced area behind the cylinder walls. All this space is the reason you can only run so much boost for so long before those nice circular cylinder walls become nice oval cylinder walls. Note that the ej22t is almost completly closed in...thats a real block right there
Old 07-16-2004, 09:34 PM   #9
Rainierez
Member#: 66332
2000 Impreza RS
I have been leaning that way (for the ej22) but what to do about the heads??? Should i have them machined at all. I hear in the stock formt hey push the compresion rate even lower under 8:1??? is this true and what can i do about that???
Old 07-16-2004, 10:38 PM   #10
totoherbs
Member#: 7321
.... 122 IggPoints
Ya, but you putting way to much on the closed deck aspect of the block. Its not that important. The problem with the 257 is its a lose motor(no very well balance from the factory), pistons are heavy, and the walls are thiner then most subaru blocks. http://forums.nasioc.com/forums/show...hreadid=536442
But its like any stock subaru block will be fine in the 350-400 whp range on the right turbo with out problem. The 2.5L is just for people who like low end pull and mid 20 boost levels where as the 2.0 is for people who like to rev and boost high. The 2.2 is a great half and half more low end pull and it will hold the boost.
engine build up questions 03 RS Built Motor Discussion 0 08-22-2006 07:08 PM
engine build up idodsick Newbies & FAQs 1 04-05-2004 01:54 AM
Project WRX Engine Build Up vividracing Member's Car Gallery 9 06-18-2003 07:06 PM
Is cobb a good choice for an engine build-up? Szm426 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-30-2002 12:32 AM
anyone have one of those dyno or engine build up software kits? funscooby Motorsports 0 01-17-2002 01:44 AM
