Old 07-15-2004, 08:46 PM   #1
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Default AP: Changing to real time map on the fly
Is there a way to change real map without connecting wire connectors and supplied connector?
I would like to just connect the AP and change map on the fly. Is this possible?
Old 07-15-2004, 08:52 PM   #2
Eskram
Member#: 16697
2004 2.5 Hybrid 18g
Wagon + LGT 1-4 g00dness!
Yes, you can change realtime maps on the fly.
The only time you need to connect the green plugs, etc is when you change the base map, or uninstall the AP.
Eskram is offline   Reply With Quote
Old 07-15-2004, 08:58 PM   #3
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
when you changed to the real map, how did you know what map you have? on AP, it tells you what type of map my car currently has, but this is BASE map, right? if I change to real time map, how do I know which map I have?
I changed to "economy map" from stage 2 on the fly, but it doesn't appear to have changed. ??
Old 07-15-2004, 09:10 PM   #4
SAL-23
Member#: 3474
2013 WRX
It only shows your base map. You have to remember what realtime you chose. If you forgot you can just select which one you want again just to make sure.
SAL-23 is offline   Reply With Quote
Old 07-15-2004, 09:12 PM   #5
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Cobb better explain that in the manual. Without asking around there is no way you can find it out...
Old 07-15-2004, 09:57 PM   #6
SAL-23
Member#: 3474
2013 WRX
You should check out www.wrxforum.com for more answers to any AP related questions. There's a few more issues people have had that is covered on the boards but not in the manual. The base map only displaying on the AP is covered in the manual though.
Old 07-16-2004, 10:16 AM   #7
TreyS
Member#: 42478
2004 WRX STi
White/Gold
The manual is very easy to understand. I didn't have any problems with my setup.
TreyS is offline   Reply With Quote
Old 07-17-2004, 03:20 AM   #8
supermarkus
Member#: 6971
2008 WRX STi
SSM
Cobb does expain it in the manual.
supermarkus is offline   Reply With Quote
Old 08-09-2004, 05:41 AM   #9
JWerty1
Member#: 49215
2004 WRX Sedan
you can change maps on the fly, as well as read cel codes on the fly, or boost, obviously
the green connectors, only need be when changing base maps
real time maps are not shown in the current map section, only base map
JWerty1 is offline   Reply With Quote
real time maps on AP1 exrage AccessPort 3 11-28-2008 12:06 AM
whats the cheapest way to switch btw maps on the fly?? BoGWAgon Engine Management & Tuning 6 05-20-2007 12:01 PM
Switching Maps on the Fly scubyslacker UTEC 4 07-28-2006 01:52 AM
Switching between real-time maps on Accessport bigwrxguy Engine Management & Tuning 18 04-09-2005 07:47 PM
regarding anti thef maps and real time maps for the accessport bubba03wrx Engine Management & Tuning 2 05-24-2004 11:01 PM
