Welcome to the North American Subaru Impreza Owners Club Friday February 5, 2016
Old 07-15-2004, 09:56 PM   #1
makofoto
Member#: 25243
2006 Legacy Outback
Unhappy HELP! How do I get the DEEP REACH Adpt. out of engine!
I bought a ACTRON Compression Tester @ Sears today ... since we have deeply seated spark plugs ... I used the Deep Seat Adapter ... well of course after doing the first cylinder ... the adapter stayed in the spark plug well !
I tried reattaching the house ... and pulling while unscrewing ... I tried pulling the hose Up as I unscrewed ... it doesn't want to come out.
I called the company ... but no one is in at the moment ... hopefully they will call me back tomorrow morning ... I'll certainly call them as soon as I'm up.
Any suggestions ? The end of the hose that screws into the adapter, is the same diameter of a plug. I was able to check the other cylinder pressures just using the hose ...w/o the Deep Adapter ...
makofoto is offline   Reply With Quote
Old 07-16-2004, 05:03 AM   #2
GravelRash
Member#: 16318
2002 WRX Franknwagen
Grime over Sedona Red
If all else fails, take an old spark plug, put a bit of blue Loctite on the threads and screw it into the adapter. Wait 'til the Loctite cures...use your fingers or a plug socket to unscrew the whole mess.
If you have trouble getting the plug out of the adapter afterwards, e.g. can't clamp it in a vise for whatever reason, heat the joint to 300F, which will liquify the Loctite and you can unscrew the plug. You may want to NOT clean out the threads; the remaining residue may provide enough additional thread friction that the adapter will come out with the tester next time...
GravelRash is offline   Reply With Quote
Help! How do U get the romraider logger to log the LC1 AFR? bertune Open Source Reflashes 19 06-16-2013 03:52 PM
how do u get the most battery life out of a cell phone? djcttb Off-Topic 14 12-26-2005 03:12 PM
Please help, how do you get rid of moisture in the car? BrysImpreza Interior & Exterior Modification 13 12-30-2004 04:33 PM
How do I get the silencer out of the Espiler muffler (it's stuck in too far) ImportVenom Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-30-2004 02:17 AM
how do I get the warning signs off of the visors???` custom_impreza Interior & Exterior Modification 3 05-17-2001 08:59 AM
