Old 11-14-2000, 04:45 PM   #1
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
Angry One side of my car is higher than the other!
I have a '97 Impreza L
I don't know what caused this or when it happened. But looking from the back of the car, the left rear sits lower than the right rear? I looked at the springs at both sides and they seem ok. The struts seem ok as well but I measure the right and there is about a half in difference. Also visually the tire seems to lean frorm the top inward (negative camber). What the heck is going on?
WRXwannbe is offline   Reply With Quote
Old 11-14-2000, 04:55 PM   #2
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Post
My car does the SAME thing, and I have the Prodrive P1 suspension. I posted a similar reply and most said "it's just the way Subarus are". Of course mine is BARELY noticable, so if you're is REALLY bad you may have a bad strut or spring.
Old 11-14-2000, 05:22 PM   #3
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
Post
Man that sucks if thats the case! I'll take a trip to japan and beat some A$$. Anyhow, no I think its more serious. Because when I take a right 90 degree turn at like 30mph the inner fender rubs on the left side. That shouldn't happen?! I got an RS suspension in my garage that I will put one, but meanwhile I need to figure out why this is so.
Old 11-14-2000, 06:30 PM   #4
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Post
This has been discused many times. They pretty much all do that. Take some measurements with someone sitting in the drivers seat.
Eric
Eric SS is offline   Reply With Quote
Old 11-15-2000, 01:00 AM   #5
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
Post
Ive searched and can't find anything. By the way, I think I have a more serious problem, my fender should not rub when I have like 3 160 lb people in my car! there must be a solution? DO the rs struts do this as well?
Old 11-15-2000, 04:28 AM   #6
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
Post
I had that problem in my old RX-7. I was told it has something to do with the differential, and drivetrain
JGard is offline   Reply With Quote
Old 11-15-2000, 07:40 AM   #7
cvalle-sd
Member#: 420
2001 Cr-V
Post
Mine does too - I have to watch my rear tire pressures - below about 36psi it'll rub the wheel well under hard cornering. Ah, well... Such is Mango.
cvalle-sd is offline   Reply With Quote
one side of my car is higher than the other. refuse Brakes, Steering & Suspension 1 11-11-2006 06:26 PM
WAPCE destroyed one side of my car. shoracer Texas Impreza Club Forum -- TXIC 15 06-28-2004 05:57 PM
Right Rear of my Car is Higher than the left rear ? Lever2ooo Brakes, Steering & Suspension 9 06-09-2004 10:06 AM
Why does one side of my dipstick read so much higher than the other side? dsc Service & Maintenance 6 02-07-2003 07:29 PM
One side of my car sits lower than the other? JGard Brakes, Steering & Suspension 7 05-18-2001 07:58 AM
