Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 07-16-2004, 08:38 AM   #1
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
Default fuel stink on RSt = check valve?
Ok so I wish I could search.... grrr
My car stinks like gas on boost.
Are there some check valves I need upon adding boost?
Todd
Hitokiri is offline   Reply With Quote
Old 07-16-2004, 08:40 AM   #2
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
yeah
I am an idiot
just answered my own question. Sorry all.
http://www.sportcompactcarweb.com/pr...sccprojsubaru/
Todd
edit: quote from Shiv in article
"Could positive manifold pressure (something a stock 2.5RS was never designed for) be pressurizing the canister, causing it to leak gasoline fumes into the cabin? To test our theory, we installed a one-way check valve into the manifold vacuum purge line just behind the intake manifold. Simply put, this little trinket keeps the boost from blowing into the charcoal canister while still allowing the purge system to function as designed. Eureka! With the check valve installed, we're happy to announce that the fuel stink is gone. Our remaining brain cells couldn't be happier."
Old 07-16-2004, 12:09 PM   #3
Elliot
Member#: 12732
2000 2.5RS-T
Titanium silver
where odes the check valve goes?
pictures please!!
Elliot
Elliot is offline   Reply With Quote
Old 07-16-2004, 12:21 PM   #4
maxiav
Member#: 40413
2001 BRP RS-T EJ257
Link'd - 252WHP 274WTQ
If you are standing in front of the car... to your right, there should be a small tube coming out of the intake manifold..... I think this is it......
So I guess you install the check valve, so that air only flows in to the intake manifold.... right?
maxiav is offline   Reply With Quote
Old 07-16-2004, 12:25 PM   #5
Elliot
Member#: 12732
2000 2.5RS-T
Titanium silver
Ok I'll look for it today!!
Elliot
Old 07-16-2004, 01:13 PM   #6
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
I don't think so, the manifold vacuum purge line is located behind the manifold, underneath to the left.
-Vic
Wedge is offline   Reply With Quote
Old 07-16-2004, 01:19 PM   #7
maxiav
Member#: 40413
2001 BRP RS-T EJ257
Guess I was wrong.... OOPS..... I have to look at my car once I get home... but go with what he ^ says....
Vic, when you say to the left, do you mean "YOU" looking at the car left... or the left of the car (driver's side)....?
Old 07-16-2004, 01:30 PM   #8
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Sorry, I hate it when left and right gets mixed up on cars.
But I meant left when looking at the car, so passenger side.
Old 07-16-2004, 01:40 PM   #9
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
ok i bought a check valve over lunch.
ok.. the lines comes out from under the passanger side of the intake manifold.
Where does it go to after that? for the sake of making it easier to locate. What ID is the tube? 1/4? Cause the check valve I got is pretty small.
Todd
edit: pic + caption
and the caption by Shiv:
"Who would have thought that a $2 check valve from Monument Auto Parts would solve our fuel stench problem? It should be noted that OEM turbo Imprezas already come equipped with such a valve from the factory."
Old 07-16-2004, 01:54 PM   #10
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
In between the purge solenoid and the intake manifold. That vacuum line that comes out of the top of the manifold.
-Brett
ExecNav is offline   Reply With Quote
Old 07-16-2004, 02:02 PM   #11
maxiav
Member#: 40413
2001 BRP RS-T EJ257
I'm confused.. I was reading a reply from ScoobaruRS and now it changed....
Old 07-16-2004, 06:21 PM   #12
crash
Member#: 1440
05 LGT Wgn; 04 FXT
BDSM -- Birmingham, AL
I'm confused too...
The vacuum line that comes out of the top of my manifold goes to my TEC MAP sensor...
-Nate
crash is offline   Reply With Quote
Old 07-16-2004, 07:33 PM   #13
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Hope this helps....
So, the check valve would go from the line that comes out of the manifold, correct?
Old 07-16-2004, 07:51 PM   #14
Bobalouy
Member#: 827
99 2.5rs,BDP,
02 WRX wagon WRB
The JC sports instructions explaines it
Page 25 - #91,92
http://www.imprezars.com/images/turb...rboinstall.pdf
Anthony C
Bobalouy is offline   Reply With Quote
Old 07-17-2004, 07:35 AM   #15
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
Because I'm too quick...
Actually the first thing I wrote was basically that you would put the check valve in between the purge solenoid and the charcoal canister. All though that would probably work, it would make a little more sense to put it in between the PCS and the manifold.
-Brett
Old 07-17-2004, 08:59 AM   #16
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
!!! I did it and I don't notice the stink nearly as much!!!!
although backing up will never not stink with no cats....
Old 07-17-2004, 09:44 AM   #17
Avenger
Member#: 1234
Is this just a MY99 problem? I don't seem to have this problem on my MY00.
Avenger is offline   Reply With Quote
Old 07-19-2004, 12:59 PM   #18
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
YES!!!!!!! It worked!!!! I'm going outside to take a pic of the install right now!
Old 07-19-2004, 02:27 PM   #19
asusimpreza
Member#: 4416
1989 Escort
Same questions as above. Does this apply only to MY98-99? I have a MY01RST and I haven't smelled gas yet. I do smell something, but its probably from the exhausts...burning lots of unnecessary fuel.
Ben
asusimpreza is offline   Reply With Quote
Old 07-19-2004, 03:41 PM   #20
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Well, it's possible since I'm running 18psi that might have something to do with it.
Old 07-19-2004, 05:26 PM   #21
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
this only matters on MAF driven cars I beleive...
HOK is offline   Reply With Quote
Old 07-19-2004, 05:29 PM   #22
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Negative, mine is MAP, and there is NO more fuel stink in the cabin while under high boost.
Old 07-19-2004, 05:43 PM   #23
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
whats odd is that i've never had a check valve on that hose and I have never had fuel smell even with 20 psi.... ????
Old 07-19-2004, 07:01 PM   #24
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Yeah, it's strange. Friend has another RS-T just like mine, except with a 2.5STi shortblock, and he is also running 18psi. Never has his smelled.
I'm thinking perhaps the charcoal canisters go bad?
Either way, I'm so glad the smell is gone.
Old 07-19-2004, 07:25 PM   #25
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
how does that vacuum line stay on w/o a clamp?
it sees positive manifold pressure correct?
thanks
alex
checking valves on hybrid? supernick77 Built Motor Discussion 10 01-05-2010 03:16 AM
Hitting fuel cut at 80..Check engine light comes on Dubya R Ex Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 50 10-11-2007 03:06 AM
Fuel Stink. . . Revisited 2fst4u2c Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-14-2005 02:45 PM
Fuel Canister Check valve thingy Scooby South Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-17-2001 09:06 PM
Check valve location for MAP on MY99. SKiDaZZLe Technical Forum Archive 0 07-06-2000 09:17 AM
