Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
Old 07-17-2004, 12:03 AM   #1
LatentWagen
Member#: 50315
0508 Saabaru / specB
MBP / DGM
Default son of a!!! (busted bolt help)
so i finish putting on my aps tmic (again, after having y-hose leak issue)... im wrapping things up, and putting on my bypass valve again... and the damned ****ing bolt breaks. its the left one for the bypass valve, a 12mm. i still have a quarter inch sticking out of the i/c. since it was the first bolt i was easliy able to take the bypass valve off...
does anyone have ANY suggestions as to how im going to get this damned thing out? it seems too tough to torque with a pair of needle nose... and i dont want to strip the thing of all its thread. what do i do?!
-ed
LatentWagen is offline   Reply With Quote
Old 07-17-2004, 12:05 AM   #2
LatentWagen
Member#: 50315
MBP / DGM
Old 07-17-2004, 12:12 AM   #3
Costas
Member#: 13760
1999 Impreza WRX
Rally Blue
can you get a pair of needlenose vise grips on it?
Costas is offline   Reply With Quote
Old 07-17-2004, 12:15 AM   #4
LatentWagen
Member#: 50315
MBP / DGM
see youd think that would be a tool worth having in my garage...
Old 07-17-2004, 12:15 AM   #5
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Get a stud/screw/bolt extractor thing from Sears or elsewhere. You will drill a small hole in the center of the bolt, set the extractor in place and reverse it out.
And then in the future clean out crud from all areas a bolt is going to be put into and the bolt threads themselves and use a torque wrench to specs. <- not saying these were the cause, however they frequently can be and following this advice in the future can prevent this from happening again
Most locking plier sets of three include a needle nose in the set - the entire set would be worth having around. Kinda like BFH's never know when you will need it but when you do need brute force it is always nice to have.
turboICE is offline   Reply With Quote
Old 07-17-2004, 12:21 AM   #6
Prime Mover
Member#: 19988
05 Saabaru,
08 Big American Diesel
That's pretty much my thought too... I know they sell vice grips in sets, one of them is usually small enough to grip what it sounds like you have.
I was gonna say also, see if you can drill through the center of the piece that's left (obviously not too big to get all of it out), and see if you can get a set of needle-nose or regular pliers to latch on and twist it back out.
-Gary
Prime Mover is offline   Reply With Quote
Old 07-17-2004, 12:28 AM   #7
Costas
Member#: 13760
1999 Impreza WRX
Rally Blue
if he can get a needlenose on it, then he should be fine..you should have vice grips in your tool box if you tinker...they are worth it.
If you cant then your only other alternative is to use the bolt extractor (you can get it any auto supply store)
Worse come to worse, hack a line right through the diameter with a hacksaw, and use a big flathead screwdriver
Old 07-17-2004, 12:34 AM   #8
LatentWagen
Member#: 50315
MBP / DGM
i hope i can deal with it tomorrow... hey so how well does the car run with no bypass valve im guessing it just wont make any boost.
Old 07-17-2004, 12:35 AM   #9
LatentWagen
Member#: 50315
MBP / DGM
thanks for all the responses, by the way!!!
Old 07-17-2004, 12:42 AM   #10
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Agree and agree, most people who have encountered this situation have done both at one point or another. Just was putting up an alternative since the non-locking needle nose weren't working and in case it was due to insufficient material outside the hole.
Old 07-17-2004, 01:43 AM   #11
LatentWagen
Member#: 50315
MBP / DGM
well i found a vise grip... didnt work. that thing is in there pretty good. does anybody have a stud/screw/bolt extractor that i might borrow?
-ed
Old 07-17-2004, 02:03 AM   #12
Costas
Member#: 13760
1999 Impreza WRX
Rally Blue
Pep boys/Autozone/Straus/ has single pieces for like $8.99+
Hack it lightly, try the big screw driver trick...dont make the cut too big. just enough to get the screw driver in there.
Old 07-17-2004, 02:07 AM   #13
LatentWagen
Member#: 50315
MBP / DGM
i really doubt the screw driver will work... i really jacked this thing in there tight. im such an ass
Old 07-17-2004, 02:09 AM   #14
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
Haha, i'd ask you if that solved your other not making boost problem, but one step at a time huh. Good luck man. Let me know what happens.
Soon2Bgreat is offline   Reply With Quote
Old 07-17-2004, 02:13 AM   #15
LatentWagen
Member#: 50315
MBP / DGM
i think i fixed that... the main intercooler hose to the motor was loose. now this.
Old 07-17-2004, 03:12 AM   #16
Costas
Member#: 13760
1999 Impreza WRX
Rally Blue
TITYWOP
Old 07-17-2004, 03:32 AM   #17
ERaab212
Member#: 18466
2003 GT35r Evo VIII
11.033@132
not cool.
I hope you get this fixed.
ERIK
ERaab212 is offline   Reply With Quote
Old 07-17-2004, 06:21 AM   #18
Edvig
Member#: 16147
no more turbo
05 Legacy, 11 Outback
Ed,
Call me, I have a stud/screw/bolt extractor you can borrow. I'll pm you my number.
Edvig
Edvig is offline   Reply With Quote
Old 07-19-2004, 04:00 PM   #19
LatentWagen
Member#: 50315
MBP / DGM
edwin saves the day! thanks man... now that everythings together, the car runs okay. i seem to be loosing some power somewhere tho, and the turbo whistle is much louder. i think i have a leak, but boost pressure isnt down.
-ed
Old 07-19-2004, 05:06 PM   #20
MikeWRX-NJ
Member#: 33410
08 wrx
dgm
haha edwin is seriously the westchester savior!
MikeWRX-NJ is offline   Reply With Quote
Old 07-19-2004, 05:17 PM   #21
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Glad it worked out - how did you eventually get it out?
Old 07-19-2004, 09:33 PM   #22
Edvig
Member#: 16147
no more turbo
Bolt Extractor!
Old 07-19-2004, 10:41 PM   #23
LatentWagen
Member#: 50315
MBP / DGM
and super edwin power
Old 07-20-2004, 06:42 AM   #24
Edvig
Member#: 16147
no more turbo
Old 07-20-2004, 10:29 AM   #25
ERaab212
Member#: 18466
2003 GT35r Evo VIII
11.033@132
Busted bolt on intercooler where it connects to turbo.. idmantis Factory 2.5L Turbo Powertrain 5 04-16-2010 12:06 PM
Busted Bolt...? On Removal STI 2 NV Newbies & FAQs 6 01-15-2005 03:54 PM
Busted bolt...Any ideas? dreaminsubys Service & Maintenance 6 10-18-2004 11:42 PM
need suspension help. busted bolt tonight! drifterx Brakes, Steering & Suspension 2 05-19-2003 12:16 AM
Message Board Statistics All times are GMT -4. The time now is 05:58 AM.
