Old 10-16-2000, 03:03 PM   #1
Frey
Member#: 589
Location: Cincinnati, OH USA -- Silverthorn MY00 2.5RS Coupe
Question Soft Brake Pedal
I hope this is the relevant forum for this question.
My sister has a 96 Corolla. The brake pedal has gotten really soft over the last couple of weeks, especially the last couple of days. She hasn't noticed any strange sounds though.
I checked the pads and they are fine--only about 25% worn. The rotors are okay too. Also, the brake fluid looks good--right in between min and max.
Does anyone have any suggestions for what else could cause this? Thanks in advance.
Frey is offline   Reply With Quote
Old 10-16-2000, 03:06 PM   #2
jackwei
Member#: 233
Post
bleed brakes?
jackwei is offline   Reply With Quote
Old 10-16-2000, 03:30 PM   #3
Frey
Member#: 589
Post
No I did not... Pardon my ignorance on this, but how do you bleed brakes?
Thanks!
Jeff
Old 10-16-2000, 03:32 PM   #4
Joel Gat, 1.8L
Member#: 32
Post
Hello,
Jackwei is right, the fluid you see in the reservoir is not necessarily in the same condition as that in the calipers or drums. And there could be air in the calipers or drums. So bleed all four corners.
Joel
Joel Gat, 1.8L is offline   Reply With Quote
Old 10-16-2000, 04:19 PM   #5
Frey
Member#: 589
Post
Cool, thx guys.
I am just going to take her car into my mechanic tomorrow morning. He said he'll bleed them for free--can't beat that.
Thanks again for the quick replies!
Old 10-16-2000, 07:51 PM   #6
Pilot
Member#: 513
Post
One other thing to check is to make sure the slider pins on the calipers are properly lubed. If they are not the brakes will begin to bind and it will cause a mushy brake pedal. This is a common Toyota problem and I also had the same problem with my RS.
Pilot is offline   Reply With Quote
Old 10-17-2000, 09:51 AM   #7
Frey
Member#: 589
Post
I just wanted to let you guys know that I took her car to my mechanic. It turns out the back brakes (drum) were bad. There was like no shoe left on either wheel, the drums were damaged, and the piston was fully extended. In fact, the piston was so far extended that it looks like air has gotten into the line.
Gonna cost a couple of hundred it looks like.
Soft Brake Pedal YooperBaja Baja Forum 7 06-03-2007 02:41 PM
Soft brake pedal DiscoGsus Brakes, Steering & Suspension 3 10-19-2006 03:20 PM
soft brake pedal tcspeer Brakes, Steering & Suspension 4 07-14-2006 11:36 PM
soft brake pedal scuby Brakes, Steering & Suspension 3 10-26-2004 03:01 PM
soft brake pedal 4x4x4x5 Brakes, Steering & Suspension 7 01-10-2001 10:50 AM
