Old 07-17-2004, 07:38 AM   #1
singsing
Member#: 36991
2003 Liberty B4
blue
Default what does this jj mean
i have a set of wheels
17 x 7J off set 47
pcd 100
what does that 'j' mean
another set i have is 17x7JJ
what does 2 'j's mean
help
singsing is offline   Reply With Quote
Old 07-17-2004, 08:18 AM   #2
Tire Rack Moderator
Member#: 1215
ext. 4362
it is a designation about the bead area of the wheel and the size of the retention bump the tire has to be forced over during the mounting process
Old 07-17-2004, 09:37 AM   #3
singsing
Member#: 36991
2003 Liberty B4
blue
i see
i have a set of work emotion CR wheels.
they are 17x7J and offset 47
pcd100 5 bolt
my old wheels were 17x7JJ (extra J!) and everything else the same
it seems the centre bore doesnt quite fit my car.... (it is a legacy B4) the wheels are supposed to be for impreza??
anyway... it seems i require a centre bore locating ring or somesuch as there is some space aorund the thing which comes out the centre
anyhoo...myquestion is this
if the wheel is not perfectly centred... what is the major problem with this? any long term damage potential.... my wheel man reckons possible increased vibration but is otherwise safe
what are your thoughts on this issue... as it is bothering me enough to want a machine shop to make me some rings...
David
Old 07-19-2004, 11:45 AM   #4
benyl
Member#: 48833
'05 Dirty STi
'08 E92 335,'03 E46 M3C
Go to a tire shop or a tuner shop and buy the plastic ones for $10.
benyl is offline   Reply With Quote
What does this picture mean to you? rex_ruthor Off-Topic 25 10-15-2003 08:46 PM
What does this pic mean? Hyper Off-Topic 8 09-25-2003 08:23 PM
What does this gesture mean? rspoel64 Off-Topic 20 07-25-2003 11:47 PM
P170 What does this code mean? adamsrs Normally Aspirated with bolt-on Forced Induction Powertrain 10 07-04-2002 04:56 PM
what does this noise mean? IMPREZAmike Normally Aspirated Powertrain 6 01-28-2001 12:31 AM
