Welcome to the North American Subaru Impreza Owners Club Sunday May 26, 2013
Old 10-29-2000, 11:00 PM   #1
fellfrosch7
Member#: 2389
'98 Impreza L Wagon
'90 Talon TSi AWD
Post Converting AWD to FWD
I read somewhere that taking out the AWD fuse will make the car drive with FWD only.. does this have any negative effects on the engine, transmission, etc., especially if you leave the fuse out for a longer period of time? Also, would there be any power gains (since the AWD setup eats up a lot of HP before it gets to the wheels)?
fellfrosch7 is offline   Reply With Quote
Old 10-29-2000, 11:19 PM   #2
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
Post
Only works for automatics -- look in the owners manual.
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 10-30-2000, 06:46 AM   #3
DLC
out back
Member#: 1964
01 BH
Blue/Bronze
Post
Yes it only works on automatics.
My 93 Turbo in FWD is a joke, i spin the tires in every turn. An RS might be less prone as its torque is lower and at higher rpms, but it'd still be very prone to spin.
DLC is offline   Reply With Quote
Old 10-30-2000, 07:00 AM   #4
XT6Wagon
Member#: 524
04 STi
Post
Um its a complete and utter fallacy that AWD eats power. Its simply not the case in modern times with great bearings and U-joints that don't puke. Think about it, you still have to accelerate all that hardware even in FWD mode as the rear tires are still required to move at the same speed. so instead of accelerating the driveshaft by way ot the tranny, you now do it though the ground, and the rear tires.
AWD's do have a much higher rotating mass than a normal FWD, but the fuse trick doesn;t avoid this. AWD's therfore dyno low as they have high rotating mass (a dyno run killer), and AWD dynos have lots of contact losses, as the tires try and deform to the shape of the stupid rollers.
XT6Wagon is offline   Reply With Quote
Old 10-31-2000, 12:37 AM   #5
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
Post
I've seen dyno's where the wheels are removed and the machine is attaches to the lug nuts... this would get rid of the loss through the tires. of course it would just be nice to get an engine dyno to see what power we're really producing
mrbell is offline   Reply With Quote
Old 10-31-2000, 11:24 AM   #6
NateP
Member#: 2414
Post
It can be done with a 5spd car, but it requires the purchasing of another center diff unit for whatever tranny you're using, and welding it. This way, when the tranny is reinstalled, the transfer case can be left off of the car and it will drive as a FWD. Driveshaft needs to be removed in this case, too.
NateP is offline   Reply With Quote
Old 11-01-2000, 06:28 AM   #7
ImprezedRS
Member#: 2771
2003 BMW Z4
Post
When race people on straight roads i do the fuse trick on my auto and it accelerates a lot faster since i lost to a civic si in awd and left him in fwd. But on curvy roads leave it in awd as i almost ended up in a ditch in fwd. And one more thing, in fwd you will burn your tires down easily as of now i got half the tread on the front as i do the back.
ImprezedRS is offline   Reply With Quote
Old 11-01-2000, 07:39 AM   #8
Gambit
Member#: 102
Post
Doesn't make sense as you shud be able to launch much harder and faster in AWD than a FWD.
Gambit is offline   Reply With Quote
Old 11-02-2000, 07:10 AM   #9
ImprezedRS
Member#: 2771
2003 BMW Z4
Post
Thats what i thought but for some reason my auto in fwd will take off faster than in awd at a dead stop but from 20 mph up in awd it will get up and go faster than fwd
Converting AWD to FWD? jaymzz Transmission (AT/MT) & Driveline 18 08-19-2008 05:43 PM
Converting AWD to FWD blueovalz Transmission (AT/MT) & Driveline 11 03-17-2006 05:34 PM
AWD to FWD with a button? RedFLash General Community 14 05-14-2003 07:11 PM
converting 4wd to fwd thng Factory 2.0L Turbo Powertrain 13 07-24-2001 09:27 PM
('93-'01) AWD to FWD/RWD RedDawgg Impreza Forum 4 04-12-2001 09:11 PM
Message Board Statistics All times are GMT -4. The time now is 02:29 AM.
