Old 07-19-2004, 11:12 PM   #1
Geoffman72
Member#: 27891
2001 Impreza 2.5 RS
Blue Ridge Pearl - R.I.P.
Default What octane do you use in your stock 2.5 engine?
I've always run 87 in my 2.5 RS and always noticed a bit of pinging at certain points and times and switched to 93 a few weeks back. The car runs smoother, pulls harder, and the pinging is gone.
The confusing part is, I know Subaru rated this thing for 87. I guess its just a case of using what your car runs best on.
Geoffman72 is offline   Reply With Quote
Old 07-19-2004, 11:33 PM   #2
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
I've tried higher octane only to find my mpg plummet. I may try 91/93 again soon to see if anything has changed.
Tim Sanderson is offline   Reply With Quote
Old 07-19-2004, 11:39 PM   #3
elijah25rs
Member#: 59711
2005 WRX
Crystal Grey Metallic
Though your car will run much smoother and with less noise. You are actually losing power because your car is designed to burn 87. 92/93 octane fuel burns much slower and is ideal in force fed engines (turbo, supercharger, etc.) So basically, all that extra pull is in your head. Don't waste your money. Just fill up with a bottle of techron every 5-6 tanks to clean your system and stick with the 87.
elijah25rs is offline   Reply With Quote
Old 07-20-2004, 12:05 AM   #4
NC2.5RS
Member#: 19313
2007 Scion tC
Black Sand Pearl
Just stick with 87.
NC2.5RS is offline   Reply With Quote
Old 07-20-2004, 02:34 AM   #5
HeyChris
Member#: 2234
2013 F-XT
Obsidian Black Pearl
I use teh best 87 my rubles can buy... And since I'm in wunderful Calif... Its probably 85 octane... since the 91 octane is a joke... lol
If I'm hitting any canyon's my car seems to appreciate 89 octane.. only because I really push my car...
Plus I'm a gas snob... I'll drive outta the way to find a Chevron. lol
Chris.
HeyChris is offline   Reply With Quote
Old 07-20-2004, 02:35 AM   #6
ruskiyab
Member#: 55128
2007 Impreza WRX
93 b/c i got advanced timing
ruskiyab is offline   Reply With Quote
Old 07-20-2004, 08:39 AM   #7
Geoffman72
Member#: 27891
2001 Impreza 2.5 RS
I guess I need to do a good check up on the engine. As for 93 being ideal for forced induction engines, this is definitely true, but its also a pretty good idea in engines where the compression ratio starts in the double digits.
I've always thought Subaru really conservatively tuned the NA 2.5 from the factory to be able to run on 87 with the compression ratio it has. Maybe I'll look more into ECU reflashing...
Old 07-20-2004, 09:21 AM   #8
orndog
Member#: 34670
2013 No gears!
Saltine American
Some cars will advance their own timing a bit until they hear knock, I don't know if Subies do this or not. Your pinging is due to carbon build-up in the combustion chamber area most likely. It gets hot enough to cause pre-detonation. Clean her out real good and switch back to 87, or run 89.
orndog is offline   Reply With Quote
Old 07-20-2004, 10:43 AM   #9
bheinz57
Member#: 37870
2012 ISM WRX
'16 Forester XT
Anything under 89 without ethanol, anything above that is a waste of $$$. Brian
bheinz57 is offline   Reply With Quote
Old 07-20-2004, 11:28 AM   #10
D-Speed 2.5
Member#: 29516
2005 WRX Wagon
Former GC O.G.
I run 91 out here in Colorado because of my Torque II Chip. I still get around 325-400 miles on a tank of gas with mostly highway but a lot of mountain driving. I also honestly believe that the 91 out here is not 91 is probably closer to 88-90 like California.
D-Speed 2.5 is offline   Reply With Quote
Old 07-20-2004, 12:33 PM   #11
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
87 and I just deal with the detonation during the warm days. It's just tip-in anyways, so it's not a real big deal since the motor is under little load at that point.
Old 07-20-2004, 02:53 PM   #12
Geoffman72
Member#: 27891
2001 Impreza 2.5 RS
I ruled out carbon deposits as I run Redline fuel system cleaner every 5,000 miles. I dont believe we have any station that has no ethanol fuel here in Western NY.
Car also has had a plug change with perfect gap like 4k ago and a new fuel filter about 7k ago. I've been meaning to do wires, perhaps those will help by some marginal amount.
Old 07-20-2004, 03:04 PM   #13
orndog
Member#: 34670
2013 No gears!
Saltine American
Not to sound like an a$$, but what do you mean by perfect gap? I have found varying numbers, with Subaru recommending a range, while the auto parts stores for some reason say 44 (Subaru lists .39 to .43). Ethanol is the devil.
Old 07-20-2004, 03:28 PM   #14
projectrally
Member#: 53916
2015 FFR 818S
Red Gel Coat
There's nothing scientific about the tests, but I've casually observed that 93 yields the best performance/MPG when I'm on a long trip and the miles are all highway. Around town, though, there doesn't seem to be much difference between grades, so I just get the cheap shtuff.
projectrally is offline   Reply With Quote
Old 07-20-2004, 09:06 PM   #15
3BadHabbits
Member#: 38011
2005 05FXT-RICE!!!
Silver RICE!!!
I get the same MPG on whatever i use...i drive about 35000 miles per year.
I do notice pinging with the lower octane though, but i dont care, let it blow i have 4 more blocks waiting..
Nick
3BadHabbits is offline   Reply With Quote
Old 07-20-2004, 09:09 PM   #16
obyone
Member#: 16523
But does the better gas mileage ofset the added cost of the more expensive fuel?
obyone is offline   Reply With Quote
Old 07-20-2004, 09:21 PM   #17
Geoffman72
Member#: 27891
2001 Impreza 2.5 RS
Perfect gap meaning I tripled checked to make sure each was within subaru specs and equal to each other.
Jeez 3BadHabbits, are they just RS blocks or?
Old 07-20-2004, 09:29 PM   #18
3BadHabbits
Member#: 38011
2005 05FXT-RICE!!!
Silver RICE!!!
4 rs blocks with 45000 on all of them and an wrx block with 11000
Old 07-20-2004, 10:50 PM   #19
Geoffman72
Member#: 27891
2001 Impreza 2.5 RS
niiiiice!
Old 07-21-2004, 02:18 AM   #20
projectrally
Member#: 53916
2015 FFR 818S
Red Gel Coat
Well, the price difference in grades equals out to about the cost of one extra gallon of fuel if filling the tank from empty. If I'm on a long trip, the 93 probably gets me pretty close to a free gallon over the span of a whole tank. So, it pretty much balances out, or gets so close that the cost savings are negligible.
Old 07-21-2004, 05:39 AM   #21
imprez_kyoso
Member#: 2369
2003 Cooper S
Chilli Red
I use 91...
Art
imprez_kyoso is offline   Reply With Quote
Old 07-21-2004, 11:55 AM   #22
D-Speed 2.5
Member#: 29516
2005 WRX Wagon
Former GC O.G.
My dad bought a used Kia Sportage up here that was running like hell after only 25k miles. We put it on a 91 octane diet and put some, fuel system cleaner in the tank and after a few weeks the Kia was running great?! It currently sees 89 octane.. keeping in mind that its a Kia. At 87, it pings like hell, worse than any car I have ever heard.
Old 07-21-2004, 12:35 PM   #23
2.5RSMatt
Member#: 30497
00 RSTi
FUK HDR
odd, I get better mailage on higher octane but the offset in price evens it all out.
87 + cheap price + low mileage = 89 + higher price + high mileage
I'm back to 87 octane now.
2.5RSMatt is offline   Reply With Quote
Old 07-21-2004, 07:07 PM   #24
obyone
Member#: 16523
Well then there really is no point, unless you're pinging. Still, I'll remain skeptical till an actual scientific test is done by another member.
Old 07-22-2004, 09:10 AM   #25
Ziggyrama
Member#: 53665
2011 STI Stg2 w/EBCS
Focal Active Setup
The rule of thumb is to run the lowest octane that you can get away with without pinging, if you're looking for best performance. Because higher octane gas is more expensive, general public assumes it must be better and that is not true. From the responses, I see you guys got more brains then that so it's all good, he he Gas quality is very important. Crappy stations have old gas and the additivies used in the gas are not very good, hence when I gased up at Getty, my car was pissed. I found best results with Mobil or Exon which are pretty much the same thing. Here are my observations from the past (I spent way too much time investigating this before):
1. I used to use 93 and driving was ok. Decent milage 25m/g, performance was not that great.
2. Later on, switched to 87 and the car ran great. Much better performance, I did not generate more knock with lower octane gas and my economy went down by about half a gallon to 24.5g/m.
3. I experimented with a mod where I would bypass the crankshaft vents away from the intake. 87 became a problem and my performance sucked. I switched to 89 and the car liked that a lot more. The economy remained around the same, 24.5g/m.
4. I removed the mod and I am back to 87 with an improved intake and right now the setup gives me the best performance. Even on a hot day, the car pulls very well.
After all of this time, one thing I have noticed is that every time I switched from 87 to higher octane, the first gas tank would produce a great economy rating, 26g/m or more but after that, the ecu adapts and the economy goes back to around 24.5m/g. I just want to throw this out there, but when you experiment, go at least 2 gas tanks before making the call. One is not enough to get a good judgment. By the way, I measured my ignition through an OBD2 scanner so I got real numbers to support my conclusions.
Ziggyrama is offline   Reply With Quote
What engine oil do you use in your subies Sacramento? MAJRMSA Bay Area Impreza Club Forum -- BAIC 1 12-03-2005 08:01 PM
What fluid do you use in your rear differential? Bobert540 Transmission (AT/MT) & Driveline 1 10-10-2005 04:26 PM
What Solution do you use in your IC sprayer!? Sisqocqk Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 28 10-29-2003 03:38 PM
What kind of paint do you use for your stock headlights? IMPEXRALLY Interior & Exterior Modification 1 12-31-2002 11:00 PM
What suspension do you use in your rally car? Looking for PGT setup for an Impreza L. Sean Motorsports 43 08-08-2002 09:32 PM
