Old 07-20-2004, 12:03 AM   #1
NorCalEnthu
Member#: 65164
2004 WRX
Default Oil change question - I have no 04 wrx manual
How much oil do i need for an oil change to do it myself. What other important points are included in the owners manual about an oil change?
NorCalEnthu is offline   Reply With Quote
Old 07-20-2004, 12:05 AM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
Post
4.8Qt's. Not much more in the manual.
Calvin
cnk is offline   Reply With Quote
Old 07-20-2004, 12:08 AM   #3
NorCalEnthu
Member#: 65164
2004 WRX
thank you
Old 07-20-2004, 02:13 AM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
OK....here's what I do....warm up the engine a bit....drain the old oil (pull the dipstick up a bit and loosen oil cap so air can get in) and remove the old filter making sure that the old gasket is still on the filter and not stuck to the filter attach flange....go have a beverage of the moment to let oil drain.....come back and re-install pan plug with new gasket...torque to 33ft-lbs(yes I do ) fill the new filter out of a 5qt jug of (insert fav oil here) and install hand tight +1/4 turn....dump, slowly, the remainder of 5qt jug of oil into filler opening...start car and check for leaks....drive around the block and check quantity(spot on in every case so far )...and clean up and done.
Old 07-20-2004, 02:27 AM   #5
mr_yellow
Member#: 39983
2003 WRX Wagon
mr_yellow is offline   Reply With Quote
Old 07-20-2004, 02:27 AM   #6
mr_yellow
Member#: 39983
2003 WRX Wagon
Might as well add this while we're at it:
http://forums.nasioc.com/forums/show...%27s+manifesto
Old 07-20-2004, 07:07 AM   #7
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
If you want a copy of the manual, just sign up for "my subaru" on the subaru website (it's a free site, and you can download the owners manual from there)
Old 07-20-2004, 07:30 AM   #8
f4phantomii
Member#: 58504
2004 STi w/o wing
Aspen White / Silver
You forgot the last step.....
Drive yourself insane over the next week trying to get a decent oil level reading off the $@$%# dipstick.
I just did the first oil change on my STi. I warmed it up to operating temp, and let the oil drain overnight with both the dipstick and fill lid open on level ground in my garage.
I refilled with 4.5 quarts, and I'm pretty sure it's over full....at least I think it is...who can tell with the %$!@!$ dipstick!?!
-Michael
f4phantomii is offline   Reply With Quote
Old 07-20-2004, 09:18 AM   #9
Slowpoke
Member#: 19879
2004 WRX
Java Black
Here's a trick. Pull the dipstick and wait a few minutes before reinserting. When you pull the dipstick you can drag a little bit of oil up the tube. By waiting a few minutes, you let this oil flow back down the tube, enabling you to get a clean reading.
If this still doesn't work, wait longer.
Slowpoke is offline   Reply With Quote
Old 07-20-2004, 09:44 AM   #10
vapore0n
Member#: 21356
2017 Toyota Corolla
Limited, LBP, ABP, TTD, I
my manual says its 4.2, for STI and WRX. My 02 WRX was 4.8. You may need to check if yours is 4.2 for oil too.
vapore0n is online now   Reply With Quote
Old 07-20-2004, 11:28 AM   #11
Malik
Member#: 29272
2002 WRX Wagon
Have you asked your sales person for the missing manual? They would probably give you one if you explained the situation. Perhaps it was an honest mistake.
Malik
Malik is offline   Reply With Quote
Old 07-20-2004, 06:27 PM   #12
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
I think 4.2 is for the NA 2.5L engine
Old 07-20-2004, 09:12 PM   #13
JJL330
Member#: 38672
2009 WRX 5dr
-Michael
Yeah I totally know what you mean. HOw the hell you read that craP? There are two lines, one says its over full, the other says its underfull..
JJL330 is offline   Reply With Quote
Oil Change time, what have you guys found to work best? nwood1976 South West Impreza Club Forum -- SWIC 35 04-26-2009 06:03 PM
07 wrx oil change question 07jayspec Newbies & FAQs 6 12-02-2007 08:44 PM
Fujimoto oil drain valve and oil change questions ps99115 Newbies & FAQs 38 10-14-2005 08:14 AM
wrx oil change question inchoate Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-03-2001 02:39 PM
('93-'01) Stupid Oil Change Question Star*Child Impreza Forum 7 05-19-2001 09:23 PM
