Old 07-20-2004, 02:12 AM   #1
hippy
Member#: 36528
2002 Impreza Wrx
Default N2O Questions
I was wondering if anyone out there has an opinion on fuel being recycled through the turbo and/or blowing out of the bov into the engine compartment. After getting a single nozzle wet kit(basically), I smell fuel after every shift. I was wondering if this is really bad, or if it's better then recirculating the fuel/n2o. I have a 50/50 bov, so either way I'm pretty screwed . I've been thinkin about gettin a 100% atmostpheric bov and trying to vent it somewhere a little less obvious(to me, the smell kills me). Any suggestions would be great. Thanks,
hippy
Old 07-20-2004, 02:33 AM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
you need to shut your nitrous down before your shift venting any kind of fuel vapor into the engine bay is a bad idea. You really should consider getting a direct port kit
Jeremy
Old 07-20-2004, 05:22 AM   #3
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
Raw fuel is also hell on turbo oil seals and bearings.
no-coast-punk is offline   Reply With Quote
Old 07-20-2004, 09:13 PM   #4
kaos200
Member#: 2692
the fogger should be after the blow off valve to begin with.....
kaos200 is offline   Reply With Quote
Old 07-20-2004, 09:36 PM   #5
hippy
Member#: 36528
2002 Impreza Wrx
That's easy when you have a front mount, but when you have a top mount............ The problem was more my stupidity then anything(go figure). I wanted to try out the fuel solenoid an make sure that worked b4 I put n2o through to see the a/f ratio change of the fuel jet. I guess the fogger isn't ment to just jet fuel. I started getting the n2o worked out and have had no more smell. I also upped the tps on/off switch to 100% where it was 95% before(my tps hits about 103 at full throttle). Thanks for all the help.
hippy
ATF fluid level fluctuation question Subyroo2.5 Transmission (AT/MT) & Driveline 2 06-02-2010 08:01 PM
N2O Question Mechkiller31st Normally Aspirated Powertrain 2 03-22-2006 12:19 PM
general nitrous questions, since N/A is closest to n2o Handsdown Normally Aspirated Powertrain 29 01-07-2005 11:25 AM
N2O install questions, mounting bottle in wagon, running line roybfr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-29-2003 11:31 AM
N2O and an auto 02rs questions DoctorNick Normally Aspirated Powertrain 0 07-30-2001 12:35 PM
