Old 07-20-2004, 10:09 AM   #1
DanBelford
Member#: 30516
2003 WRX
Default Wheels 17x8
I would like to buy a new set of rims and tires for the ride. Not 100% sure what to get but this is what I am thincking.
17x7 OZ Superleggra but they dont fit big brake kits
SO
17x8 Rota Torques with 235/40/17 tires
Just some questions?
1) 17x8 Rota Torques weight 18.1 lbs(silver) 18.5 lbs(otherwise)?
2) Will the tire size fit under a 03 WRX with Eibach's without fender rolling?
3) Is there a better option in regards to weight, without braking the bank(VOLKS)?
4) Will the +48mm ofset clear everything just fine?
Thanks for all the imput. With your helpo I should be able to make the correct decision for the long term.
DanBelford is offline   Reply With Quote
Old 07-20-2004, 01:55 PM   #2
ripvw
Member#: 27790
good idea - what tires?
don't think you're going to notice that .4lb difference - or whatever it really is - get the color you want
if you have a wagon, you'll need to roll the fenders no matter what. if you have a sedan that isn't ridiculously low, the ET45 Eibach RPF-1's will work fine with 235/40x17 - search for RPF1 under screen name Cosworth for more info
the 15.5lb. 17x8 Eibach RPF-1 is your answer at about $250 each
if you have a sedan, both the ET48 Rota's or the ET45 Eibach's will work fine - many have already fitted one or the other combo with good results
buying rear camber bolts would be a good idea too and then get a performance alignment if you are still running on factory alignment specs
ripvw is offline   Reply With Quote
Old 07-20-2004, 08:59 PM   #3
DanBelford
Member#: 30516
2003 WRX
ripvw,
I was thincking of going with the BFG KDW 235/40/17 on a 03WRX sedan. You mentioned the 15.5lb. 17x8 Eibach RPF-1. Is that actually made be Eibach(like the spring people)? Can someone get me a linck to a picture or website? I am just questioning the actual value of the Rota Torque17x8. Maybe there is a lighter rim out there that I should be considering? As the stock WRX rim is 16.5lbs, I would lke to go lighter or about the same weight. It is also important that the rim choice can acomidate big Brembo brakes!!!! I installed camber bolts both fornt and rear, so it shouldnt be a problem to get it all setup. And what kinda performance alignment are you talking about? I only street drive the car, somtimes hjarder than I should. I would like something sporty. Again thanks for all the help people!!!!!!!
Regards
Old 07-20-2004, 09:47 PM   #4
ConeMasher
Member#: 2135
ENKEI RPF-1
For example
-- Gary
ConeMasher is offline   Reply With Quote
Old 07-20-2004, 10:40 PM   #5
ripvw
Member#: 27790
Originally Posted by ConeMasher
ENKEI RPF-1
For example
-- Gary
thanks, I went totally brain dead - ENKEI
no idea why I wrote Eibach once, much less multiple times...
Old 07-20-2004, 11:05 PM   #6
esteve
Member#: 28716
2006 STI
I'm saving up for the Enkei RPF1s myself. They're an awesome bargain considering what you get, nothing against Rota. I was really considering Rotas myself, but I'd rather spend a little more for what I really want.
esteve is offline   Reply With Quote
Old 07-20-2004, 11:12 PM   #7
daveyboy
Member#: 35419
FWIW, I have an '03 sedan with 17x8 torques and falken azenis in 225/40/17 along with Prodrive springs. I autocross the car and have had no rubbing issues. I know you were thinking of running 235s, but falken azenis tend to run a little wide and might be comparable,
daveyboy is offline   Reply With Quote
Old 07-21-2004, 12:41 AM   #8
Blitzkrieg
Member#: 14913
2003 Lock Stock and
2 Smoking Barrels "wrx"
I know of a few people that are reading a bit higher on scales like a 1.5 lbs more for different colors.
BlitZ
Blitzkrieg is offline   Reply With Quote
Old 07-21-2004, 11:02 AM   #9
CtGT
Member#: 2127
09 STi
dgm Cobb Stage 2
So a 17x8 +45 (enkei) would work with no rubbing. My friend had volks 17x8 +44 with 225/45 and he rubbed in the rear with people in the car.
CtGT is offline   Reply With Quote
Old 07-21-2004, 10:17 PM   #10
rommel
Member#: 32662
black
Default enkei RPF-1
I have the enkei RPF-1s with 235/40/17 yoks avs100
these things are very light weight & very strong!
worth ever penny!
thanx
rommel
rommel is offline   Reply With Quote
Old 07-22-2004, 12:32 AM   #11
DanBelford
Member#: 30516
2003 WRX
I agree with everyone the Enkei RPF-1 is a god wheel, Ijust dont love the style. I was origonaly iterested in the OZ Superlegra's until I found out they dint fit Big Brake Kits BBK. I would like a wheel that will be able to acomidate STI Brembos. So I was looking at the Rota Torques. This is the kinda style I am after no ofense anyone!!! But I still want a good quility light weight wheel. Thats the major delema!! So what doi you thinck, can you guys help me out????
Thanks
Old 07-22-2004, 11:12 AM   #12
CtGT
Member#: 2127
09 STi
dgm Cobb Stage 2
where did you get the RPF-1's?
Old 07-22-2004, 04:39 PM   #13
DanBelford
Member#: 30516
2003 WRX
Can Anyone recomend a nice wide light rims that will fit big brakes? I kinda need some help on this one. I dont realy like the Enkei RPF-1, personal taste!
Thanks for the help!!!
Old 07-22-2004, 10:58 PM   #14
Cosworth
Member#: 3887
08 Taco, 98 M3/4/5
'00 RC51, '08 KTM
There is also the new Enkei RP03 that is now available in 17x8", et48 fitment. About a pound or so heavier than the RPF1 and a simple 5-spoke design. Also used the Enkei MAT semi-forging process that the RPF1 uses for strength in the wheel where its needed. They fit the STi big brakes and the Stoptech's. Both verified. Available from Nino's here on the board.
Cosworth is offline   Reply With Quote
Old 07-23-2004, 12:41 AM   #15
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
If my car would fit them, I'd get the RP03s. I like that wheel. Kinda vaguely remnds me of one of my favorite wheels. Volk Racing Challenge F-Zeros:
ss
subysouth is offline   Reply With Quote
FL: autoX wheel 17x8.5 5x100 fit 275 easy!! aceking66 Wheels/Tires 3 11-06-2006 12:28 PM
WTB: 05 STI wheels / 17x8 Rotas RyanC Private 'Wanted' Classifieds 2 03-15-2005 07:29 PM
(help) Wheel ? 17x8 EIMPREZARS Brakes, Steering & Suspension 1 05-23-2002 07:00 PM
