Old 07-20-2004, 02:14 PM   #1
harmonevan
Member#: 63160
2005 STi
Rally Blue
Impreza WRX STi 2005 STi Kartboy Short Throw Installed
This weekend I installed my kartboy short throw + bushings.
This is just some additional notes on MY05 changes - subscribe/support to scoobymods for the full install instructions!
here are pics from the install:
My STi Page
1. The console is now all one piece on MY05, and has two more screws at the top. 04 was two pieces with only screws towards the 'back' of the console.
2. Before the console is removed, you have to remove the 'silver' clutch area, THEN you can get to the screws on the top of the one-piece console to remove it.
3. On my stock bushing - the bolt was stuck in the bearing, the threads would *not* fit through it. Spent like 15 min. hammering it out.
Review:
Very different feel than stock. I *love* the new feel of the clutch, smooth, shorter throws. To use one phrase: solid precise shifting
If any info is wrong, or if you have anything to add feel free - i wonder if i'm the only one who had trouble with their stock bushing and bolt.
harmonevan is offline   Reply With Quote
Old 07-20-2004, 08:41 PM   #2
T-WRX
Member#: 2468
08 RS4
05 STi - Gone
Funny - I did mine this weekend as well.
I had an '02 WRX with a KB SS + bushing, and it was awesome. The STi version is just as good, but takes 10x longer to install. Not hard, just time consuming.
One tip that I picked up from www.imprezawrxsti.com ... (no pun intended)
Use the naked end of a Q-tip to align the the reverse lock out cable within the handle. Then knock the roll-pin in from the other side. Saves a great deal of pain.
One note on the ScoobyMods description... The installer owned a car that had a turboback exhaust, without the cat. If you have a cat, there is not nearly so much room as in the pictures on the website.
T-WRX is offline   Reply With Quote
Old 07-20-2004, 08:51 PM   #3
Member#: 67
1999 Outlasting
the competition.
Is there anything a Q-Tip cant do?
tom
Old 07-21-2004, 03:34 PM   #4
Saunders
Member#: 34480
2003 WRX Wagon
I though that the STi came with a short throw shifter. It seems like that KB SS and the STi SS cant be that much different?
Saunders
Saunders is offline   Reply With Quote
Old 07-21-2004, 06:05 PM   #5
Member#: 67
1999 Outlasting
the competition.
were about 40% shorter than the stock STi shifter and 30% more than the "shorter" STi shifter. that one is only 10%
Tom
Old 07-22-2004, 10:05 AM   #6
Silver-Bolt
Member#: 40189
2004 STi
Silver/Silver
I have had both (all three if you include the stocker) and the Kart-Boy is by far the best.
Silver-Bolt is offline   Reply With Quote
Old 07-22-2004, 03:17 PM   #7
STIgeorge
Member#: 22040
12 FJ Cruiser
Rent-a-car White
The shifter+ bushings are amazing. They totally redefine the shift characteristics of the car. The best that I can describe it is that the shift stroke is smooth and it presses into gear with a nice "click". Its amazing how much the shifter shortens the travel as well. I think it makes it feel more like a sports car should. The way shifting feels in my car right now, will be what I compare every manual car that I drive to.
Kartboy SS + Bushings = A++ (I can easily see this as being my favorite modification)
On a side note, I also had Whiteline Steering bushings installed, and while I can't put into words what they do, I can tell you that the difference is very noticeable and very good.
-George
STIgeorge is offline   Reply With Quote
Old 07-22-2004, 06:32 PM   #8
Member#: 67
1999 Outlasting
the competition.
-George
your making me want to go out and buy a STi
Old 07-22-2004, 09:14 PM   #9
harmonevan
Member#: 63160
2005 STi
Rally Blue
Impreza WRX STi
each day I am more and more happy with the kartboy st shifter. I honestly think the STi should have come with a shifter of this quality.
I'm going to look into the whiteline steering bushings.
also for the install and lock out cable - i used a toothpick which i found was *not* a good idea. It broke and i had to get the pieces out - instead i used a small jewelers screwdriver which was probably smaller than a 3/32 punch.
I'm not sure i tightened the shifter bolt enough though - on the highway down into the city i was noticing some rattling when shifting between 5th/6th gear at about 70mph.
also as my engine is finishing its break in (1.4k miles now) - i'm noticing in 4th gear at around 4500 rpm i'm getting a lot of a low frequency resonating hum sound. I'm also sure this isn't the spoiler as that hits/passes its weird hum at 105.
any ideas/advice?
Old 07-23-2004, 12:23 AM   #10
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Serves you right for getting that other car
Leonardo is offline   Reply With Quote
Kartboy Short Throw shifter * factory short throw ONLY * 05ASPINREX Drivetrain 6 08-15-2009 08:31 PM
Kartboy Short Throw shifter * factory short throw ONLY * 05ASPINREX Drivetrain 0 07-23-2009 04:19 PM
Kartboy short throw install question KRL Transmission (AT/MT) & Driveline 14 04-16-2007 09:39 PM
Instructions for STi/SPT short throw install 4 STi? criz Transmission (AT/MT) & Driveline 0 10-12-2004 10:32 AM
Kartboy short throw shifter install LinuxGuy New England Impreza Club Forum -- NESIC 34 05-12-2003 01:09 AM
