Old 10-18-2000, 07:41 PM   #1
Ben
Member#: 423
2002 WRX wagon
Post What kind of brake fluid?
I have to replace my rotor brake pads and SS brake line,since the rotor is all wone out, and I would like to change the brake fluid when I replace the new SS brake line. I would like to use Dot.4 fluid to the new system, but which one is best?
I'm using a EBC green stuff brake and a aftermarket sloted Bermbo disc!!
Ben is offline   Reply With Quote
Old 10-18-2000, 07:55 PM   #2
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
Best for what?
Best at any price? Castrol SRF. AP Racing 600 is pretty darned good too.
Best for an extremely low price? Valvoline Synpower.
There's lots of good fluids in between. Low budget racers use Ford Super Duty Blue, it has a great dry boiling point but very low wet boiling point, so you have to bleed and change it often.
ColinL is offline   Reply With Quote
Old 10-18-2000, 11:53 PM   #3
Ben
Member#: 423
2002 WRX wagon
Post
Thanks Colin, but how about Motul 600?
Old 10-19-2000, 10:27 AM   #4
Big Tee
Member#: 1802
1998 Impreza RS2.5
Post
I have a question but its brake fluid related and thought it would be seen here quickly. I was buying brake fluid and saw some DOT6 (I think) synthetic that said it was 'not for use with ABS' what about ABS would make it care about Brake fluid??
edit for creative spelling of brake
[This message has been edited by Big Tee (edited October 19, 2000).]
Big Tee is offline   Reply With Quote
Old 10-19-2000, 10:49 AM   #5
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
Ben-- never used it personally (or Castrol SRF for that matter ) but by all reports it is good stuff.
Big Tee-- Silicone-based fluids may erode seals used in ABS braking systems. If it's a synthetic glycol-based fluid that won't be a problem though.
Old 10-19-2000, 09:19 PM   #6
gaylemd
Member#: 2643
2001 2.5 RS
BRP
Smile
Where have you guys been. The best DOT4 is ATE Superblue or ATE TYP 200 (spelling for TYP is correct). It gives you 50 degrees more that than standard DOT4. Used it in my M3 for years. The Superblue has blue dye and the TYP 200 is gold, like regular brake fluid. The two colors make flushing easy and it runs between $10-$15 per liter. It's also ABS safe.
gaylemd is offline   Reply With Quote
Old 10-19-2000, 09:54 PM   #7
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Post
Super Blue Racing is the best fluid on the market except for the Castrol SRF. However the Castrol is wwaayyyyy overpriced.
Eric
Eric SS is offline   Reply With Quote
Old 10-19-2000, 10:41 PM   #8
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Post
Ok, I'm an idiot when it comes to this topic. What are the advantages of going to a better brake fluid?
Keiho is offline   Reply With Quote
Old 10-20-2000, 12:35 AM   #9
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
Cool
Totally Agree with ColinL....Ford SuperDuty Dot 3 for F350 trucks...Basically it is MOTUL repackaged...The reason you ask??? Ford Designed their older F350 Trucks with their Brake Lines near the exhaust...therefore heating up the brakefluid...Ford had a Recall and instead of Changing out the lines..(which would have cost more) they got Better fluid..Just FYI...
Circa 1996/7 F350...wow..I knew something...LOL...
Scooby South is offline   Reply With Quote
Old 10-20-2000, 07:28 AM   #10
Travis R
Member#: 153
'07 Mazda CX-7, '91
BMW 535i & '06 Ninja 650R
Post
Better fluids generally have better wet and dry boiling points. Meaning, that after it's been in your car for 3 years, and absorbed a little moisture, it won't boil after hard use. I putting the Valvoline mentioned above in this weekend. Very good dry boiling point for the money.
Travis R is offline   Reply With Quote
Old 10-20-2000, 10:28 AM   #11
anerd
Member#: 2631
2001 2.5 RS Sedan
Post
special on superblue (someone sent to me) http://www.thepartsconnection.com/specials.htm
$7.95 a litre
I did not buy any yet, so buy at own risk, have no idea if company any good.
anerd is offline   Reply With Quote
Old 10-20-2000, 10:37 AM   #12
Jay_UK
Member#: 296
Post
DOT 4 baby
DOT 5.1 for everyday use.
J.
Jay_UK is offline   Reply With Quote
Old 10-20-2000, 01:51 PM   #13
awu
Member#: 544
Question
I couldnt find it in our owners manual.
How much fluid is needed for 99 RS brake systems?
Im putting in new rotors,pads,and lines mine as well change the fluids.
awu is offline   Reply With Quote
Old 10-21-2000, 12:37 AM   #14
gaylemd
Member#: 2643
2001 2.5 RS
BRP
Post
Folks, ATE is a major maker of brake components, as well as fluid. Their stuff is leggit. BMW uses it as an OEM fill, but not the higher boiling version. BTW, the price of $7 and some change is excellent.
Old 10-21-2000, 11:53 AM   #15
Joe Hogan
Member#: 699
2002 golf TDI
Post
Interesting that no one posted NEO Super Dot 4 fluid. I've used this for the last year in the RS. Good wet boil point and is reasonably priced.
Though ATE and Ford have better price points.
Joe
Joe Hogan is offline   Reply With Quote
What kind of brake fluid? C Dust Brakes, Steering & Suspension 3 09-22-2004 08:37 PM
A little OT, but what kind of tranny fluid for a 1st Gen SHO blue-sun Transmission (AT/MT) & Driveline 1 02-11-2003 10:51 PM
What kind of tranny fluid does the MT WRX use? Night Kid Transmission (AT/MT) & Driveline 8 11-24-2002 02:58 AM
What kind of diff. fluid should be use? Nanase Transmission (AT/MT) & Driveline 3 10-30-2001 11:08 AM
What kind of brake fluid is good? STi-Nismo Dood Brakes, Steering & Suspension 15 02-16-2001 12:54 AM
