Welcome to the North American Subaru Impreza Owners Club Friday October 28, 2016
Old 07-20-2004, 08:33 PM   #1
Member#: 65678
Default car leaking fluid?
so i live in southern california and i always have the AC going in this summer heat. I noticed a couple times when I park my car in the garage, the car leaks fluid coming from around the front. I know its not oil cause it doesnt feel like it, my guess is water...is this condensation from the AC or something more serious?
awdaddict172 is offline   Reply With Quote
Old 07-20-2004, 08:50 PM   #2
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If you park after the AC has been running there will be water draining from the evaporator drain hose that exits through the lower passenger side of the firewall. This is completely normal.
It's actually a good idea to turn off the AC at least a few blocks before you reach your final destination (but leave the vent fan running). This allows the condensed water to drain out before you park so there won't be standing water left in the evaporator core to promote mildew growth.
Old 07-25-2004, 03:17 PM   #3
Member#: 40248
2003 WRX
Midnight Pearl (black)
AS long as liquid is not brown (oil or tranny fluid), red (Automatic Tranny Fluid), yellowish-clear and slimy (brake or PS Fluid), or Chartreuse (Antifreeze), you're probably OK.
billzebub is offline   Reply With Quote
Old 07-25-2004, 03:42 PM   #4
Member#: 36765
2007 WRX wagon
yup just condensation don't worry
bucklidl is offline   Reply With Quote
2008 STI AC pulley, smoking and leaking fluid. Alfaneggio Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 10-06-2009 07:26 PM
installed springs, now the car is leaking fluid DanmanWRX Brakes, Steering & Suspension 3 10-29-2006 11:44 PM
wastgate leaking fluid? raglan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 07-03-2005 02:44 AM
Leaking Fluid? worried. 2.5RSMatt Normally Aspirated Powertrain 8 04-17-2004 08:13 AM
Leaking fluids Jiz311 Newbies & FAQs 3 05-31-2002 09:36 PM
