Welcome to the North American Subaru Impreza Owners Club Wednesday May 27, 2015
Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 07-20-2004, 11:51 PM   #1
Aethyrial
Member#: 21247
1999 BG (Outback)
1989 GL 4WD Coupe
Cool Picking up an 89 Loyale
My boss is basically giving his 89 loyale to me for free since he doesn't want/need it anymore. Apparently it only has 105k on it, is in good condition, is the 4wd model, and is a manual. I haven't found out if it is the turbo yet or not, I'll find that out tomorrow when I check it out. He said it just needs some work on the brakes and some other TLC. Figure it would be great for tinkering with, winter weather, and a start on running rallies. I wanted to see what anyone else has to say about this opportunity. (Also any information about fixing it up would be appreciated)
Aethyrial is offline   Reply With Quote
Old 07-21-2004, 04:52 AM   #2
MilesFox
Member#: 64965
87 87 RX 95 Legacy
duplicolor, aluminum
good deal, go ahead and take it. since the car runs and drives now dont worry too much about it.
ask when the timing belts were last serviced to give you an idea how soon it may need the work. subaru recommends changing them every 60 thousand miles, but i have seen original sets go beyond 100 thousand miles.
good luck!
MilesFox is offline   Reply With Quote
Old 07-22-2004, 02:05 AM   #3
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
If the car is non turbo and the brake issues happen to involve the rears, consider converting to rear disk brakes from a 4WD turbo model... they are a direct bolt on and will drastically improve braking performance
Flowmastered87GL is offline   Reply With Quote
Old 07-22-2004, 08:47 PM   #4
kevinsUBARU
Member#: 2263
2012 Impreza Sport
You're in PA huh? RUST RUST RUST!!!!! Before driving it hard I would be absolutley sure that cancer hasn't taken over!
Cool score though!
Kevin
kevinsUBARU is offline   Reply With Quote
Old 07-22-2004, 09:59 PM   #5
Aethyrial
Member#: 21247
1999 BG (Outback)
1989 GL 4WD Coupe
I got a chance to check the car out today. The thing is in great shape. It had been sitting for a year and a half and started right up (with a jump of course). Rust doesn't look to bad, nothing a little bondo can't handle. Front brakes are going to need some attention and the radiator apparently has a small leak. Rear brakes will be a nice project once I get the mandatory things out of the way.
Is there an easy way to take car of the radiator leak?
Old 07-23-2004, 12:01 AM   #6
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
Ya, get a new radiator!
If you replace the radiator, you dont NEED a double row unit, but they do offer more efficient cooling... They are like $130 new from radiators.com
Old 07-27-2004, 12:32 PM   #7
MilesFox
Member#: 64965
87 87 RX 95 Legacy
you can use bars leaks or alumaseal for the radiator. be careful that it may clock passages, if one application doesnt fix it then consider other options.
the radiator can be soldered with acid core solder, take the radiator out and use a propane torch, be careful not to burn it up!
Old 07-27-2004, 03:52 PM   #8
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
I hear that those drop in sealers tend to clog the subaru heater cores. Am I right? (personally I wouldnt recommend it unless you are stranded)
Old 07-29-2004, 12:48 AM   #9
Aethyrial
Member#: 21247
1999 BG (Outback)
1989 GL 4WD Coupe
Got the title transfer taken care of this evening...the car is mine now. Regarding the radiator...I'll try leak stop of some sort...if that causes problems I'll just replace the radiator. The buddies garage I'm going to be fixing this car up at is technically a dealership...so I'm not really worried about part prices.
Old 07-29-2004, 01:38 AM   #10
Calebz
Member#: 54398
1980 CB400 Hawk
1996 GrandCherokeeLimited
Subaru Banner
DON"T USE THE STOP LEAK!!
thats bad in these cars.. you will soon find your self replacing more parts..)IE heater core as mentioned above)
Calebz is offline   Reply With Quote
Old 07-29-2004, 01:41 AM   #11
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
Ok good I have confirmation... so the verdict is use it only if you are stranded and there is no other option.
As another note.. I dont think heater cores are fun to change
Old 07-29-2004, 03:38 PM   #12
Aethyrial
Member#: 21247
1999 BG (Outback)
1989 GL 4WD Coupe
guess I'll heed the advice
just picked up a 92 loyale!! :) Ser91 'Old School' Subaru Forum 4 11-19-2009 10:54 PM
Picked up an old friend today, Sports Car....Driving by Paul Frere. Mandatory reading gtguy General Community 6 03-12-2002 06:16 PM
Picked up an issue of Car toady. Yotsuya General Forum Archive 1 12-09-2000 12:33 AM
Pick up an extra 100hp...Cheap v6scoobie General Forum Archive 18 11-06-2000 09:06 PM
