Old 07-21-2004, 12:05 PM   #1
CtGT
Member#: 2127
09 STi
dgm Cobb Stage 2
Default 17x9 Front/17x8.5 Rear?
Has anyone seen the new Super Street with the Cusco WRX? It is running 17x9 Racing Hart CP035's in the front and 17x8.5 Racing Hart CP035's in the rear. I forgot the exact tire size but the fronts are a little wider than the rears.
Can you do this on a WRX with no problems down the road? How would this affect handling, etc.?
CtGT is offline   Reply With Quote
Old 07-21-2004, 12:20 PM   #2
NTP WRX
Member#: 19200
2006 LGT Wagon
Unless the tires are very close to the same height front-to-back (I think Subaru says within 0.25" ), I would guess this would be ill-advised for a street WRX. You don't want to have a significant difference in speed between the front wheels and rear wheels as you'll cook your center differential.
Neil.
NTP WRX is offline   Reply With Quote
Old 07-21-2004, 12:26 PM   #3
CtGT
Member#: 2127
09 STi
dgm Cobb Stage 2
True. I didn't even think of that. I will have to check the tire sizes again.
Old 07-21-2004, 12:51 PM   #4
subieworx
Member#: 47769
Doesn't make very much sense.
subieworx is offline   Reply With Quote
Old 07-21-2004, 01:00 PM   #5
jsalicru
Member#: 58031
It makes sense to me... if you notice, in the same article, the Civic has the same thing.
The reason that this is done is to cut down on any understeer or maybe to get even tire wear...
I ran a 555R in the front of my Celica with stock rears for a long time... the reason I did it was to completely eliminate understeer. It worked wonderfully.
People that race FWD cars do it too..
jsalicru is offline   Reply With Quote
Old 07-21-2004, 01:28 PM   #6
CtGT
Member#: 2127
09 STi
dgm Cobb Stage 2
Yeah but on an AWD car it doesn't make sense to me. I would think that upgrading your suspension would be a better route to cut down on understeer. On an AWD I would think you would want the same size tire wheel combo front/rear.
Old 07-21-2004, 01:32 PM   #7
mrazntre
Member#: 30156
2003 WRX Sportwagon
MBP
AWD + stagger = no no.
That's weird that they would run a WRX with a slight stagger.
Perhaps they mounted a wider tire on the smaller width rim ? (to eliminate stagger and equalize the tread path on all wheels) ?
Anybody know the real reason?
mrazntre is offline   Reply With Quote
Old 07-21-2004, 01:37 PM   #8
SLKWrx
Member#: 8247
2016 Outback
2005 Lotus Elise
AWD is not true 50/50 split.. WRX is still FWD biased therefore having a larger contact patch on the front will allow better use of the available torque, and I'd imagine less understeer.
SLKWrx is online now   Reply With Quote
Old 07-21-2004, 01:44 PM   #9
CtGT
Member#: 2127
09 STi
dgm Cobb Stage 2
Most AWD subbies aren't 50/50 but isn't the WRX 50/50 split? I know the STi the driver can adjust the center diff ratio.
Old 07-21-2004, 02:07 PM   #10
sotti
Member#: 33474
04 M3
Imola Red
The WRX is suppose to be a 50/50 split, but it deffinetly displays more FWD characteristics than RWD.
sotti is offline   Reply With Quote
Old 07-21-2004, 02:09 PM   #11
CtGT
Member#: 2127
09 STi
dgm Cobb Stage 2
For sure....I totally agree
Old 07-21-2004, 02:21 PM   #12
mrazntre
Member#: 30156
2003 WRX Sportwagon
MBP
any adverse affect on the diff?
Old 07-21-2004, 03:08 PM   #13
subieworx
Member#: 47769
It displays these tendancies due to the extra weight of the AWD being located more over the front wheels than the back. If this car had an even weight distrobution we would have understeeer problems. Running a stagered tires setup though is not the way to get rid of understeer on this car. Buy a frickin sway bar and be done with it. If you get understeer at that point you don't know how to drive correctly. I have coilovers, rear sway and endlinks and rims and tires and I never have understeer except when in the rain.
Old 07-21-2004, 03:09 PM   #14
subieworx
Member#: 47769
It all comes down diamter of the tires. If the fronts have a greater diamter by more than 1/4" the diff will not be happy as the gears will not mesh properly between the back wheels and front. With this setup the front axles will be moving fast than the rears which will cause problems.
Old 07-21-2004, 03:27 PM   #15
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Eh it has nothing to do with any kind of gears it has to do with overheating the viscous lsd unit in the center differential. Anyways, there are guys that run wider wheels/tire in the front than on the rear because you have more weight up front and of course urning the wheels is decreasing the grip you have as well. There are some autocross EVOs that run 275/285 tires in the front and 245s in the rear. Larry Fine autocrosses an STI and runs 275 tires in the front and 245 in the rear as well. As long as the diameter of the tire is close, you are going to be fine.
A WRX has a 50/50 split, it's not biased to one side or the other unless there is wheelspin.
STI is rear-biased 65R/35F or somewhere around there, but the reason they run wider in the front is front end grip, which may cause more oversteer and may cause more understeer depending on how the car is setup.
Old 07-21-2004, 03:45 PM   #16
subrew2
Member#: 2883
2004 STi
Silver/Gold
I ran 245/45-16 and 225/50-16 on my '99 2.5RS for G-stock autocross.
Thinking of a 275/245 setup for my STi for concrete events. Just trying to find some wheels that don't break the bank.
Chris H.
www.subrew.com
subrew2 is offline   Reply With Quote
Old 07-21-2004, 06:13 PM   #17
stratos
Member#: 5583
96' Ver.2 Wagon
How close is close enough?
stratos is offline   Reply With Quote
Old 07-21-2004, 07:14 PM   #18
manimal15611
Member#: 58337
2k2 Impreza WRX
As long as the profile of the tire is the same the different widths of the tire wont have any effect on anything. when you look at a tire say its 225/40/r16 the 225 means its 225mm wide while the profile of the tire is 40 mm high. The widths will not effect anything its all a matter of contact with the concrete. When i had my old camaro i had 285/40/r16 on the rear, and only had 235 on the front.
manimal15611 is offline   Reply With Quote
Old 07-21-2004, 08:39 PM   #19
Red Rocket
Member#: 10507
'04 Ex STi Owner
'97 4Runner
I've been running that wheel size setup for over a year now. 17x9/8.5. Selling it soon though. Tires are 255/40-17.
Kevin
Red Rocket is offline   Reply With Quote
Old 07-21-2004, 10:26 PM   #20
WickedSTI
Member#: 39408
How will a 8 inch wide wheel and a 7.5 inch wheel have any if any change in stagger?It will change section width but very little there also.I have seen many JDM cars with wider fronts and somr road race cars that are AWD and FWD.The thought is for less under steer and more turn in.Its like the reverse of RWD with wider rears to make up for over steer. Brad
WickedSTI is offline   Reply With Quote
Old 07-22-2004, 11:42 AM   #21
NTP WRX
Member#: 19200
2006 LGT Wagon
I think you don't quite understand how tire sizing works. When looking at a tire size, the middle number is called the "Aspect Ratio." It defines the height of the sidewall as a percentage of the width. It is not a constant when varying the width when trying to maintain the same overall tire height. It works like this:
A 225/40 tire has 225*0.4=90 mm of sidewall (multiply by 2 to get the total sidewall)
A 285/40 tire has 285*0.4=114 mm of sidewall (x2 to get total sidewall height)
For a 285/40/16 to have the same side sidewall height as a 235 width tire, the 235 needs an aspect ratio of 50 (making it a 235/50/16). That gives a sidewall height of 4.5" for the 285 and a 4.6" sidewall height for the 235. I used this calculator to figure that. Read more here.
Neil.
Old 07-22-2004, 11:59 AM   #22
CtGT
Member#: 2127
09 STi
dgm Cobb Stage 2
what he said^
Old 07-22-2004, 12:09 PM   #23
CtGT
Member#: 2127
09 STi
dgm Cobb Stage 2
So I am looking at getting Volk CE28N's in a 17x8 with a 225/45. A guy I know had these and they rubbed a little in the rear. What if I got the 17x8 +44 in the front with 225/45 and 17x7.5 +50 in the rear with 225/45. Same tire size? Can anyone see a problem with doing this?
Back to my original post about the Cusco wrx. I checked the tire sizes. They are 17x9 with a 245/40 in the front and 17x8.5 with a 245/40 in the rear. Whay would they do this. Different wheel width, same tire size?
Old 07-22-2004, 12:17 PM   #24
NTP WRX
Member#: 19200
2006 LGT Wagon
The change in stagger is a result of running different width (and thus different aspect ratio) tires front and rear, not the absolute wheel width. You're correct when you say the section width changes, but only when comparing the same tire on 2 different wheel widths.
If you run different tire sizes front to back, the total tire height will be different. Unless you're really careful with how you size the tires this can be very bad for your center differential. How careful you need to be depends on Subaru's built-in tolerance for the diff. Like I said above, I think a ~0.25" difference is the maximum allowable height difference, but I don't know for certain.
As an example, Subrew2 said he was running a 245/45-16 front and 225/50-16 rear. These 2 tires are within 6 revs/mile of each other, with a total sidewall height difference of ~0.2 inch (4.3*2=8.6" in front vs. 4.4*2=8.8 rear - from here) This should be within the diff's tolerance levels and therefore it shouldn't be damaging to it. However, if he had used a 235/50-16 in back (giving us 4.3*2=8.6" in front vs. 4.6*2=9.2") it probably would damage the diff. Note that these measurements are multiplied by 2 to get the difference in total height.
Neil.
Old 07-22-2004, 12:23 PM   #25
CtGT
Member#: 2127
09 STi
dgm Cobb Stage 2
I understand that. What if I was to run same tire sizes front to rear on different width rims (8" & 7.5") for offset purposes. I want the +44 up front because there is plenty of clearance but I don't want the rear fender to rub the outside of the tire so I want to go with a +50 in the rear?
FS: BBS RG-R 17x8.5 +55 60% RE070 Front, 85% NT05 Rear tires $2000 psychoazn Wheels/Tires 2 10-26-2009 11:24 PM
18x8 front 18x8.5 rear DieselClown Tire & Wheel 3 09-25-2006 10:39 AM
WTB: 17x8, 17x8.5, 17x9 wheels (5x100) johnnytran RMIC Private Classifieds 0 06-19-2006 06:04 PM
05 STi Staggarded Fitment, Fronts 17x9, Rears 17x8.5, +48, 5x114.3? 2-quick4u Tire & Wheel 7 02-06-2006 01:25 PM
17X8 front and 17x7.5 rear HiVoltg12 Tire & Wheel 5 09-23-2004 05:14 PM
