Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 07-21-2004, 04:06 PM   #1
Kenny T.
Member#: 38054
2000 Impreza L
Blue Ridge
Default H6 Swap
Has anyone tried to put the new ez30-r into a GC8. I know over at Lina Racing the put the ez30 in their 95 impreza. But i haven't been able to find hardly any info about the ez30-r, a swap with this motor, or anyplace you could get an ez30-r crate motor.
I really want to know if this is feasible because I just love the sound and low end pull of an NA motor.
Thanks,
Kenny T. is offline   Reply With Quote
Old 07-21-2004, 04:58 PM   #2
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
Nobody has tried, that is why there is no info. You will have to get the EZ30R via Subaru probably.
Old 07-23-2004, 12:47 PM   #3
atchernyshev
Member#: 51140
2001 Outback
I try ... not possible ..
atchernyshev is offline   Reply With Quote
Old 07-23-2004, 06:54 PM   #4
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
Really? What was wrong?
Old 07-24-2004, 12:52 AM   #5
sidewayz
Member#: 5810
2001 S366 2.5RS
remember waayyy back when Cobb was still in Texas, they had a small meet there with a GC8 with an H6 swap..
sidewayz is offline   Reply With Quote
Old 07-24-2004, 05:11 AM   #6
mprezuhguy
Member#: 39921
'00 RS Sedan
STM
Hey Kenny, I too am very interested in doing a swap to a new H6. Not only that but attempting to supercharge it also. Where is walnut creek? Weshould collaborate. :-)
mprezuhguy is offline   Reply With Quote
Old 07-24-2004, 03:17 PM   #7
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
Contact a vender that imports motors, ask for the JDM H6 that has 250hp N/A. That would be amazing....and with a super charger, talk about low end torque.
RS_to_WRX_swap is offline   Reply With Quote
Old 07-25-2004, 02:42 PM   #8
chip4761
Member#: 55867
2005 Saabaru
AS
Let's hear it for broken axles and melted syncros!!
chip4761 is offline   Reply With Quote
Old 07-25-2004, 03:52 PM   #9
jetfan8178
Member#: 15669
2009 Cadillac
STS-vvvvvvvvvv
jetfan8178 is offline   Reply With Quote
Old 07-25-2004, 05:31 PM   #10
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
EZ30 does not = EZ30-R. Nobody has done an EZ30-R swap yet. atchernyshev said he tried, but we need more info.
Old 07-25-2004, 09:16 PM   #11
jetfan8178
Member#: 15669
2009 Cadillac
STS-vvvvvvvvvv
Sorry, I didn't realize that anders had no mention of the 3.0R being the same dimentions and configuration as the regular EZ30. However, The new legacy outbacks that are now available in the US are using the 3.0r motor with the AVCS and all.
Previous failures at swapping in the 30R were not due to engine size ot configuration, but more attributed to wiring and lack of aftermarket support for EMS as well as other parts needed to make the swap work. Anders pioneered all his own parts which made it work, Someone would need to do the same to allow for the 30r to work as well but would experience more problems due to teh AVCS I would imagine.
Old 08-03-2004, 12:26 AM   #12
Kenny T.
Member#: 38054
2000 Impreza L
Blue Ridge
Well so far I have heard that the ez30-r will at least fit in a GC8. This is very good news to me because the rest is a matter of custom work and a whole lot of time. Electrically, anything is possible as long as I can weed throught that nightmare of a wiring harness. And fortunately I have access to a dyno and a really good engine management tuner.
If any of you happen to catch updates about this swap being performed, or you have any other advice then lets keep this thread going. If Subaru is producing a 250 hp NA motor then I can assume that I am not the only one who wants to put it in their 2800lb. Impreza.
I look forward to hearing more input.
Thanks,
Kenny T.
P.S. Walnut Creek is located 45 minutes east of San Francisco.
Old 08-03-2004, 12:05 PM   #13
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
the wiring would be just as hard as doing a 02 wrx engine into a older impreza...none of the systems are suppose to work together....lol
I'm sure it could be done though...the only issue I could see would be the tach signal on the gauge cluster itself...
Old 08-03-2004, 04:50 PM   #14
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
Yes, you are the only one. Personally, I want it in my 2600lbs Impreza
Old 08-03-2004, 06:55 PM   #15
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
Acually Kenny is right, he has a 2000 impreza, that weights about 2800lbs. your 95 impreza is about 2600lbs.
Old 08-03-2004, 07:39 PM   #16
Homemade WRX
Member#: 33782
96 bastard child
yeah...in 97 they gained about 200 lbs...and even more if you got the extra stuff like moon roof
Old 08-03-2004, 07:57 PM   #17
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Why? There's so little support for the H6 motors, from the aftermarket. It'd be a nightmare - every little piece would need to be facbricated. Good luck finding management for that motor, headers, cams, etc.
Wouldn't a good N/A build on an EJ25 make more sense?
jamesfacts is offline   Reply With Quote
Old 08-03-2004, 11:06 PM   #18
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
I know that. I think I just phrased that wrong... I was trying to make a funny.
Old 08-03-2004, 11:10 PM   #19
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
No. Because it would cost more for the N/A build, and you would only end up with ~230-240hp at most. Meanwhile, with the STOCK EZ30-R will have 250hp out of the box, not including bolt ons (intake, exhaust, flywheel/clutch) or ECU management (a reflash, or even a stand alone would equate to more HP without touching the motors internals... AVCS is actually quite useful) which will probably get you close to 300hp without doing any internal work.
Old 08-04-2004, 10:57 AM   #20
jamesfacts
Member#: 51282
98 RS
Yeah, but the ez30 is heavier and unwieldy. Welp, if it is what your heart desires, I suppose...
Old 08-04-2004, 11:52 AM   #21
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
i have this strange desire to be unique, which seems to cost me lots of money and frusteration, LOL.
heck if i had the money i would do a EZ30R turbo
anything is possible if you have the resources and time, or can afford to pay someone else to do the work.
that swap is totally possible, i really think the issues will be the wiring and actually sourcing parts since it is so new.
good luck
Ben
Old 08-04-2004, 03:39 PM   #22
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
I bet it wiegths close to the usdm sti motor/turbo.
Old 08-04-2004, 05:15 PM   #23
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
It does. Turbo + the piping = alot of extra weight!
I think Anders H6 swap weighed somewhere around 2700lbs if im not mistaken...
H6 swap into bugeye info needed flwrx Subaru Conversions 26 02-06-2006 02:43 PM
H6 swap questions bhall Legacy Forum 35 12-09-2005 02:26 PM
Considering H6 Swap scoobiegt Subaru Conversions 4 01-04-2005 10:55 AM
H6 swap questions wighti Normally Aspirated with bolt-on Forced Induction Powertrain 12 04-20-2002 12:19 AM
H6 swap in an RS, opinions Stavros g Normally Aspirated Powertrain 16 01-27-2001 02:55 AM
