Welcome to the North American Subaru Impreza Owners Club Monday October 24, 2016
Old 07-21-2004, 06:22 PM   #1
Member#: 63330
2008 Subaru WRX 5dr
dark n' mean grey/black
Default bald tires
I am buying a set of used rims and tires. However the tires are pretty bald. About 1 to 5 mm of tread left. will running more people in the car increase the chance of a blowout?
sc00byr3x is offline   Reply With Quote
Old 07-22-2004, 12:28 PM   #2
Member#: 47769
As long as the belts are not showing oyu should be ok, but you'll want to change them asap.
subieworx is offline   Reply With Quote
Old 07-23-2004, 08:15 PM   #3
Member#: 36712
2003 WRX Wagon
The direct answer to your question: Yes. With everything else equal, increasing the load makes it more likely to fail. How much more likely? That's a tougher question.
You can improve your chances with air pressure. Make sure it's well inflated. The worst thing you can do to a tire is put a bunch of weight in the car and then run it without enough air.
2Stroke is offline   Reply With Quote
Steel wheels 5x100 bald tires are ok! DohcVtec NESIC Private Classifieds 3 06-02-2010 07:50 PM
Bald tires wongvi Tire & Wheel 22 02-08-2006 10:30 AM
FS: 3 and a half 18x7.5 Arospeed RS-GTs w/ bald tires (cheap!) Capt Crunch Mid Atlantic Impreza Club -- MAIC 1 12-03-2005 06:00 PM
SoCal: stock rims and bald tires WRXskeet Private 'For Sale' Classifieds 2 06-27-2005 09:53 PM
Bald tires in 3 months! Camber/ suspension help please? powerlabs Brakes, Steering & Suspension 10 09-09-2004 04:47 PM
