Old 07-21-2004, 11:53 PM   #1
Inprogress
Member#: 65166
2008 EVO X
Default 17x7 +40 Offset wheel work on 05 STI?
I have ADR Fuels that are 17x7 with a +40 offset, and i was wondering if they will clear the brembo's?
Inprogress is offline   Reply With Quote
Old 07-22-2004, 12:26 PM   #2
subieworx
Member#: 47769
Since you have the rims, put them on there and see.
subieworx is offline   Reply With Quote
Old 07-22-2004, 02:28 PM   #3
G-shock
Member#: 36545
Check the bolt pattern!
The larger hubs on the 05's bumped the bolt pattern from 100 to 114.5 mm!
Also, offset and size alone will not garantee a fit, since not all have the same inside clearance. You will have to test fit to be sure.
G-shock is offline   Reply With Quote
Old 07-22-2004, 03:22 PM   #4
Inprogress
Member#: 65166
2008 EVO X
the bolt pattern is 5/100-5/114
i guess ill try and see what happens
Old 07-22-2004, 04:13 PM   #5
wm07
Member#: 26529
04 STi
but why would you want to put a 17x7 on your '05? '05 comes with 17x8, so it's a major downgrade just fyi...
wm07 is offline   Reply With Quote
Old 07-22-2004, 08:18 PM   #6
Inprogress
Member#: 65166
2008 EVO X
well not necessarily, because the tire size is still the same...its still 225/45/17, it might be a little right, not to much right?
Old 07-22-2004, 08:56 PM   #7
hph
Member#: 40624
07 OBXTL
The other factor is the hub diameter -- if the wheels were on a Subaru, they're probably OK, but with that stretch bolt pattern you cited you'll want the right hub fit for sure. HPH
hph is offline   Reply With Quote
Old 07-23-2004, 12:59 AM   #8
Inprogress
Member#: 65166
2008 EVO X
what is the right hub fit?...im going to try tomorrow anyways i guess it'll be worth it if they fit...
Old 07-23-2004, 03:45 AM   #9
wm07
Member#: 26529
04 STi
No... 1 inch is a BIG difference. I wouldn't put 7" on my '04 that came with 7.5" stock. but hey, if you like it, then do whatever you want.
Old 07-23-2004, 08:00 AM   #10
subieworx
Member#: 47769
IF he's just useing them for street rims and tires, then it won't matter. I wouldn't do it either, but I am a very aggressive driver and want all my car's handling ability at all times.
Old 07-23-2004, 09:09 AM   #11
Templar
Member#: 483
2010 RSV4
Aprilia Racing Black
Don't forget that the offset is HORRIBLY off from recommended spec. You will suffer torque steering issues as well as shortening the life of your wheel bearings.
Templar is offline   Reply With Quote
FS (PA) : Azul 17x7 40 offset wheels, LIKE NEW scoobysnk MAIC Private Classifieds 12 05-10-2009 10:12 PM
Will 02 WRX Sedan rear door work on 05 STi ? ProdriveRex Interior & Exterior Modification 1 07-17-2006 01:26 PM
JDM v8 STI pink springs work on 05 sti? Thran Brakes, Steering & Suspension 1 01-21-2006 05:04 AM
Would 18x8.5 5x114.3 with +15mm offset work on 05 STI? Inprogress Tire & Wheel 4 09-20-2005 11:05 AM
Darn Blitz TT not working on 05 STI HELP! MrTransAm Electrical & Lighting 2 02-02-2005 12:03 AM
