#1 |
Member#: 37576
Vehicle:2008 EVO X, '09 WRX Wicked White, SWP |
I have Check Engine light w/ flashing Cruise Light, what does this mean?
my mods are as follows: Invidia Cat-back Invidia Downpipe Zero/sports intake pipe Blitz SUS HKS up-pipe HKS Header HKS BOV Greddy FMIC
#2 |
Member#: 44639
Vehicle:STi the 35 awaits you... |
could be a few different things, especially with that front mount on there with stock turbo. when did it happen? most common with the STi is fuel cut from boost creep from your exhaust... don't forget the search button
chris |
#3 |
Member#: 36303
TXIC
Vehicle:06 Evo IX silver |
on WRX's that usually meant that the green connectros under the driver's side dash were connected (and shouldn't be). They are used only for diagnostics.
Check to see if that might be the problem. They should not be connected. |
#4 | |
Member#: 23717
NESIC
Vehicle:2005 Big red |
Have the code pulled at an autozone. Or buy a code scanner at sears(~$100) with those mods I have a feeling that you will need it often. TMS |
#5 |
Member#: 22321
sounds like emmision codes popping from the exhaust
#6 |
Member#: 46277
SCIC
Vehicle:** Ring Time of 7:43.5 |
Rear 02 sensor. I have almost the same set up FMIC, header, up, down, cat back, utec, and mine keeps goin off for the rear 02. Gruppe-S sells cel fix's for $15. Get one and your CEL should go away.
For the flashing cruise thing. 1. It pisses me off 2. It is a way for Subaru to make cash when the car gets old. Because not being able to use cruise will drive you nuts, then you have to take it in to get it fixed. Nick |
#7 |
Member#: 51054
Vehicle:2004 subaru black |
try to disconnect the battery to reset the ecm...
#8 |
Member#: 26529
Vehicle:04 STi White |
Get the code pulled, otherwise, all the response are just guesses...
#9 |
Member#: 19467
Vehicle:02 WRX WR Blue |
I'm 90% sure is your Invidia Downpipe.
My friend has it on a STi and has the exact same symptom. I have the APS Turbo-Back and not porblems at all. There seems to be something funny about the position of the rear O2 sensor on the Invidia downpipe. |
#10 |
Member#: 45158
Vehicle:2004 STi WRB |
Most popular/simple reason for throwing a cell and the flashing cruise: something amiss with the fuel/EC system. Loose/cross-threaded gas cap, EC hoses accidentally knocked off when crawling underneath the rear of the car (exhaust/suspension install).
YMMV |
#11 | |
Member#: 9090
Vehicle:09 Forester Gump 02WRX->04STi->09Gump |
![]() ~v6 |
#12 |
Member#: 22321
get the mechanical fix.. i have it works like a charm
| Thread Tools | |
| Display Modes | |
| Check Engine Light and Flashing Cruise Control Light | moose00015 | Newbies & FAQs | 17 | 05-29-2011 09:16 PM |
| check engine light and flashing cruise? | 04wrexsti | Tri-State Area Forum | 11 | 12-29-2009 07:06 PM |
| Check Engine light W/ flashing cruise control? | parad0x | Newbies & FAQs | 6 | 05-24-2008 01:18 AM |
| Check Engine light W/ flashing cruise control? | LiDrummer | Newbies & FAQs | 39 | 07-09-2007 12:56 PM |
| check engine light w/ flashing cruise control | STi in ur face | Factory 2.5L Turbo Powertrain | 7 | 08-22-2006 09:34 PM |
