Old 02-07-2001, 01:28 AM   #1
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
Post Need whiteline part numbers
need numbers for:
Whiteline Rear Heavy Duty Swaybar Link Kit
Whiteline Front Heavy Duty Swaybar Link Kit
Whiteline 20-24mm Adjustable Rear, Impreza
Whiteline 20mm Front, Impreza
Whiteline anti-lift kit
Whitline heavy duty rear swaybar mounting kit
Whiteline REAR ADJUSTABLE CONTROL ARMS
thats it!
thanx
WRXwannbe is offline   Reply With Quote
Old 02-07-2001, 04:27 AM   #2
sen
Member#: 1216
2007 WRX
WR Blue
Post
You can find most of the part numbers from Teague's Auto. www.teaguesauto.com. I would not get the fron or rear links from Whiteline they are not high quality. The sets i bought had inferior bolts and were not as good as the stock links. Both front and rear links have very thin bushing linings which do not hold up. I would consider the 18-22 rear bar it works like a dream and does give you some flexability.
Scott
sen is offline   Reply With Quote
Old 02-07-2001, 06:16 PM   #3
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
Post
I want to get some real good front endlinks, it makes the steering pointy, but if whitline makes them out of crap, then I don't want them
Old 02-07-2001, 10:09 PM   #4
markus
Member#: 438
2004 STi
White on Gold
Post
Whiteline sertainly does not make their end links out of crap. They are spring grade steel and are so much better than stock its frightening.
If you're looking for part numbers, look here and click on the 94-2000 Impreza/WRX suspension kit file (it's in pdf format)...
http://www.whiteline.com.au/kits.htm
Hope this helps!
[edit] speeling
[This message has been edited by markus (edited February 07, 2001).]
markus is offline   Reply With Quote
Old 02-08-2001, 01:00 AM   #5
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
Post
minust the rear control arms, the price is amazingly cheap if bought directly from whiteline even with shipping included. about 200 less than what we get it here! I'll straight from whiteline
WRX Heated Seats? Need Some Part Numbers! wrx182 Interior & Exterior Modification 50 12-06-2001 10:18 PM
Need B4 Parts Numbers....... Yellow_turbo Legacy Forum 4 10-17-2001 09:21 AM
Help! I need a part number! Dre2932 Brakes, Steering & Suspension 2 09-26-2001 01:27 AM
('93-'01) Need Aftermarket Part Numbers... You KNOW You Have Them North Ursalia Impreza Forum 3 05-13-2001 07:59 PM
Who's got the service manuals? I need a part number for... Yotsuya Mid West Subaru Owners Club Forum -- MWSOC 5 02-16-2001 11:22 AM
