Welcome to the North American Subaru Impreza Owners Club Tuesday July 7, 2015
Old 07-22-2004, 10:25 AM   #1
tomturkey
Member#: 66731
Default 235/45 17 tires on a wrx wagon?
Does anyone have experience with 235/45 17 tires on the wrx wagon?
I want to use the stock take offs from my evo on the wifes wrx wagon but the largest tire on the discount tire fitment guide is a 235/40 17. What do the guys at tirerack say? Where and when will they rub? Any other problems?
Thanks for the help.
tomturkey is offline   Reply With Quote
Old 07-22-2004, 10:39 AM   #2
mav1c
Hoodbridge!
Member#: 560
2006 STi, '11 A4
Crystal Gray, Silver
Is your wagon lowered? Even if it's not, you'll probably get rubbing in the rear. What wheels are you putting the tires on? Plus the 235/45-17 size is a larger diameter than stock so your speedo will show slower than what you actually travelling.
Old 07-22-2004, 10:46 AM   #3
tomturkey
Member#: 66731
I am currently using 225/45 17's on the wagon. I don't know the width of the plus 1 Technomagnesio rims.
Old 07-22-2004, 10:47 AM   #4
tomturkey
Member#: 66731
Oh and the wagon is not lowered.
Old 07-22-2004, 12:24 PM   #5
subieworx
Member#: 47769
If the wagon is not lowered it would work. I have a friend with a non lowered wagon that has run 235 45 17 at autox before with no rubbing. It would work. He was running these on the stock STI rims.
subieworx is offline   Reply With Quote
Old 07-22-2004, 12:55 PM   #6
mav1c
Hoodbridge!
Member#: 560
2006 STi, '11 A4
The STi wheels have a very friendly +53 (I think) offset, so you're less likely to rub with those wheels. If the Technomagnesio rims are +48 offset or lower, you're more likely to rub.
Old 07-22-2004, 01:11 PM   #7
KC
Member#: 442
13 Crosstrek XV
00 S2000
When I read 'takeoffs' I think wheels, not tires... if it is wheels...
Any wheel that fit's on/made for an EVO is the wrong offset for a WRX. I would stongly suggest against using these wheels as the offset is wayyy off and can cause premature wear to the bearings. (Stock evo is around 30-32ish, right?) Stock Subaru wheels offset is 55-52 and wider (7.5") wheels made for Subaru specific offset are around 48 offset.
That said, just tires, you may get some rubbing in the rear against the strut or lip, especially if the car has passengers in the rear.
--kC
KC is online now   Reply With Quote
Old 07-22-2004, 02:05 PM   #8
subieworx
Member#: 47769
Not to mention the Evo wheels are 5x114.3 bolt pattern. I believe the offset on them is 35.
FS: one 05+ BBS wheel, 235/45/17 tire, BBS caps, WRX caps ten80 Wheels/Tires 1 02-27-2008 07:23 PM
235/45/17 tires on a BE Legacy? rougeben83 Legacy Forum 11 11-27-2007 12:17 AM
235/45/17 tires on 17x7.5 rims cinemaster Tire & Wheel 2 05-01-2006 08:57 PM
235/45/17 tires on lowered car? Axan Brakes, Steering & Suspension 6 08-21-2003 11:56 AM
235/45/17 tires on 17" wheels? Axan Brakes, Steering & Suspension 3 07-25-2002 04:48 PM
