Closed Thread
Old 07-22-2004, 11:43 AM   #1
kheff46
Member#: 66739
2002 WRX wagon
Default 2.2l to 22b conversion.. sort of
i got a 98 outback sport, i traded a '91 s13 for a wrx wheel set and turbo/intercooler set. this is from a '02-'03 wrx, and i'm unsure of the actual turbo model (tdo4?). i want to make this work with as little fuss as possible. is the ej22 basically a bored out/stroked ej20? what weird parts will i need. i have plumbing, but no header yet. i would like some help if you can find time anybody. would this qualify as a backyard mechanics 22b? also i need to swap out the crap drum brakes in back, is that costly, is there an easy conversion? under $200? thanks anyone!
kheff46 is offline
Old 07-22-2004, 12:23 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
sure would be nice if we had a moderator in this forum .. this thread belongs in aftermarked forced induction
Jaxx is offline
Old 07-22-2004, 12:25 PM   #3
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
I would vote for you, I think you spend about as much time in this forum as I spend in the Legacy forum. And we are in need of Moderators that visit the forum over there too.
subiekid is offline
Old 07-24-2004, 09:42 AM   #4
kheff46
Member#: 66739
2002 WRX wagon
hey i asked a question. you had no answer. shut the f up. i see retarded questions in the wrong columns all the time, dirtbag. if you can't help(which is what it looks like to me) then blow me. it's a simple conversion, and you failed, if this was my forum... poof you're a goner! boy wouldn't that be great!
now, if anyone intelligent has any options please list them or email me please. dirtbags not welcome! this will be a turbo engine, and it is a conversion, anything helps. thanks!
kheff46 is offline
Old 07-24-2004, 09:43 AM   #5
kheff46
Member#: 66739
2002 WRX wagon
and there is nothing aftermarket about it. all factory, all stock ,it belongs here!
kheff46 is offline
Old 07-25-2004, 12:06 AM   #6
mykrrrr
Member#: 733
'16 Fiesta ST
Platinum white metallic
An EJ22 N/A block is an open deck design. The EJ22T is a closed deck block making it better for forced induction.
You'll need to get a Legacy turbo crossmember to make WRX headers work properly.
It's not a straight forward swap but it's not impossible. You'll need other stuff like injectors, fuel pump, engine management, etc. to make it work safely.
There's alot of information on swaps like this; just search around a bit.
Good luck.
-mykr.
mykrrrr is offline
Old 07-25-2004, 09:41 AM   #7
kheff46
Member#: 66739
2002 WRX wagon
thanks mykr! i've seen the crossmember deal in mags and elsewhere. so bigger injectors, and a fuel pump to fill 'em. i'm still unsure of engine mangement pieces that aren't overkill $ wise. i got a free turbo timer from a friend, but i'll still need a piggyback ecu deal for remapping, right? are there good adjustable ones that won't require a computer program for changes? i'm new to subys, but i've seen sr20det injector ideas on this forum, that's more in my field(s13,s14,skyline) of knowledge. i've tried searches off the forum sites and found nada.
the ej22t, is that the legacy or the jdm 22b impreza style motor? so on my weakly built stock motor, low boost from a stock wrx turbo should be best? i'm wondering if this turbo(although not huge) can shatter my motor at full boost. i want to swap a new sti motor if this blows up too soon. one more question, will gas mileage actually get better while on the highway(low boost)? again thanks for the info!
kheff46 is offline
Old 07-25-2004, 11:05 AM   #8
linsavy
Member#: 11620
1997 GF4-STiV3 clone
Kheff46,
All your questions are covering the "aftermarket forced induction forum" Go and look there like Jaxx said.
I have reported your post to the moderators.
Have a nice day.
linsavy is offline
Old 07-25-2004, 01:33 PM   #9
imprezzakc
Member#: 22462
2001 AutoFozzyFTW
SilvernBlack
cant we all just get along ? i thought we all loved subaru's regardless of induction ....
imprezzakc is offline
Old 07-25-2004, 02:09 PM   #10
mykrrrr
Member#: 733
'16 Fiesta ST
If you don't get into boost that much on the e-way you'll be like a normal 2.2L motor on fuel economy.
It's not as easy as just bolting up a turbo and getting some engine management and thinking you're good to go. You don't need a turbo timer for now. I'd say do alot of research in AFI forum and then see if you want to go that route. It's not cheap to do it safely.
That's one BIG reason I didn't go that route when I had my GC6. I wanted a more factory reliable set up so I got an STi swap from a friend. She's down for now because of a couple blown bearings but I'm rebuilding her w/factory parts and she'll be fastAr than before.
Again...good luck and don't start think about "false economies" as my boss (eX-Prodrive engineer) told me when I jumped into my rebuild.
-mykr.
mykrrrr is offline
Old 07-25-2004, 02:59 PM   #11
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
Douchebag.
/Urself
You just joined the no help list.
Have a good day.
Hondaslayer is offline
Old 07-26-2004, 04:38 AM   #12
mykrrrr
Member#: 733
'16 Fiesta ST
Originally Posted by hondaslayer
Douchebag.
/Urself
Have a good day.
Man Ben...yer on a rampage against dumb n00bs.
-mykr.
mykrrrr is offline
Old 07-26-2004, 09:24 AM   #13
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
Ok... ill shut the **** up too.
totoherbs is offline
Old 07-26-2004, 11:36 AM   #14
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
This IS AFI. I just never ventured into the thread, sorry. Subaru conversions deals with the conversion of factory pieces to factory pieces to resemble a factory state of assembly. You are talking about building a turbo kit for your EJ22.
-Jon
stimpy is offline
Closed Thread
'99 2.2l to RS conversion Panops145 Interior & Exterior Modification 2 11-02-2009 10:40 PM
the bottom line on a 99 OBS 2.2l to 2.5l conversion opious Subaru Conversions 13 01-19-2006 02:12 PM
2.2L to 2.5L will this work ? PumpsGOTAWD Normally Aspirated Powertrain 6 04-24-2005 11:49 PM
How much to mod 2.2L to =2.5L hp OSUBeaver Normally Aspirated Powertrain 27 03-26-2003 11:21 PM
99 2.5RS to 22B Tranny/Diff Conversion? Nick Transmission (AT/MT) & Driveline 8 10-06-2001 07:46 AM
