07-22-2004, 11:51 AM | #1 |
Member#: 2604
NESIC
Vehicle:1999 2.5RSt RBP |
Emanage + J&S wiring opinions
Both the emanage and the J&S modify timing after the ECU.
does anyone have any idea if there would be any impact in installing the J&S before or after the emanage? I am redoing all my ECU wiring because I want to make everything plug and play so I can put the J&S wherever on the way to the coil. Todd
07-22-2004, 11:03 PM | #2 |
Member#: 33445
Vehicle:2005 Chevy Silverado Cherry Red |
Well, its a matter of is the E has knock protection. the J&S is just a knock guard. so, if you run a link you don't need one. i plan on a haltech which doesn't have any knock protection so i need one. sorry, but i haven't diversed myself very much into the piggyback world since i learned it wouldn't work for me. but let some others add their plunk plunk, 2 cents unless i answered it already. look and see if E has knock protection. Peace.
-Eli |
07-23-2004, 09:41 AM | #3 |
Moderator Member#: 922
Vehicle:16 WRX (white) 04 FXT (red) |
Realistically, there should not be any difference since the eManage just modifys the signal a few degrees, and will do it whether it's already altered by the J&S or not.
07-24-2004, 01:06 AM | #4 |
Member#: 49087
RMIC
Vehicle:1998 RST V8 STi swap '05 R6 '95 BMW V8 hotness |
The J&S has to be installed after the e-manage otherwise the e-manage will see a timing signal way off of what it thinks it should be seeing and will try and advance the timing in order to maintain the timing map it has.
07-24-2004, 12:31 PM | #5 |
Member#: 23359
NESIC
Vehicle:2002 BMW M Coupe Steel Gray |
Nope, the e-manage only changes relative to its input, it doesn't expect any signal it just changes what it gets. It doesn't matter which order they are connected.
Greddy Emanage Ultimate Wiring Harness Plug And Play | double07 | Engine/Power/Exhaust | 4 | 04-17-2007 05:30 PM |
ok guys im still getting alot of knock according to j&s emanage question | GregBolby | Normally Aspirated with bolt-on Forced Induction Powertrain | 1 | 04-10-2005 10:01 PM |
My00 rs-t running 4psi, have emanage should i sell and get j&s | GregBolby | Normally Aspirated with bolt-on Forced Induction Powertrain | 4 | 09-17-2004 02:33 PM |
Emanage+J&S? | LVSUBARU | Engine Management & Tuning | 4 | 01-23-2004 10:09 PM |
J&S Wiring for 99RS, help!!! | Delicious Tuning | Normally Aspirated with bolt-on Forced Induction Powertrain | 10 | 08-26-2001 08:53 PM |
