Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Suspension/Brakes/Handling
Old 07-22-2004, 12:10 PM   #1
WorxTuning
NASIOC Manufacturer
Vendor Sales Rating: (0)
Member#: 42684
Default Íhlins Coilovers on sale & WRX or STi S.S. Brake Lines-$89.99
Íhlins Suspension kit for the WRX and STi is a bolt-on, out-of-the-box kit with everything needed to up-grade your suspension to a racing-style coil-over system. This kit is the latest release in the Íhlins Road and Track series of shock absorbers and suspension kits for street use. The external damping adjustment features a wide range that can easily take you from the road to the race track. The adjustable spring platforms allow the owner to set the ride height that best suits their needs-from standard to race track lowered.
Feel the difference a quality suspension kit can make in improved traction, handling, comfort and safety.
MSRP $2550.00
WorxTuning Introductory Price $2399.99
WorxTuning Stainless Steel brake lines feature the highest quality PTFE lined hose covered by stainless steel braid. A clear protective covering is also applied for increased abraision resistance and long term cosmetic durability. Installation of these lines will give you a more responsive brake system with a firmer pedal feel. No more spongy performance due to the expansion of the factory rubber lines. Our lines are D.O.T. approved and carry a lifetime warranty against manufacturers defects. They are also a factory match meaning that they retain all factory fitting and mounting tab styles. Available in WRX or STi specific fitments.
MSRP $119.99
Sale price $ 89.99
To purchace or for more information on our specials, visit
http://www.worxtuning.com/specials/specials.htm
WorxTuning is offline   Reply With Quote
Old 07-22-2004, 03:09 PM   #2
WorxTuning
NASIOC Manufacturer
Member#: 42684
Default Our feed back on the suspension
We just installed the Íhlins system on our STi project car last week and the improvement in the suspension is very impressive. The first thing you notice when taking them out of the box is the massive 45mm pistons. They feature an inverted design like the factory STi suspension. You can see them in the photo in the link- www.WorxTuning.com/specials/specials.htm.
When installing any coilover in general, you will have some sacrifices in daily drivability, in exchange for increased suspension performance. In nearly 1000 miles since installation, we would have to say the only sacrifice is a slight increase in road noise transmitted into the cabin. Beyond that, the system overall is far superior in every aspect. Keep in mind that our STi is daily driven nearly 100 miles. Gone is the slight harshness of the factory suspension when encountering bumps and slight imperfections in the road. The Íhlins system is much more compliant, but much more capable of keeping the vehicle stable during hard cornering. There are 16 positions of dampening adjustment which allow you to take the vehicle from more road friendly, to more track friendly in a matter of seconds. In testing the settings, we found that we could comfortably take one of our favorite curves (a sharp 90 to the left) considerably faster than we ever would have before with the stock setup. The vehicle stays much flatter and is more controlled and predictable. The rates on the springs are 230 lbs/in front and 171 lbs/in rear. The fronts are stiffer than stock and the rears are a happy medium in the middle of the factory progressive rate.
Íhlins has truly lived up to every one of our expectations. When a company is so deeply rooted in professional racing suspension such as they are, you would not expect any less. We can see why their systems are the choice of so many of the leaders in racing, including numerous competition Subarus. We have yet to see what they will do on the track, but anxiously await the chance (yes, we are drooling at the mere thought )
Old 07-22-2004, 03:42 PM   #3
jmott
Member#: 6713
2007 Prius
brown
Originally Posted by WorxTuning
comfortably take one of our favorite curves (a sharp 90 to the left) nearly 20 miles per hour faster than we ever would have before with the stock setup.
You might want to rethink that claim there.
jmott is offline   Reply With Quote
Old 07-22-2004, 03:55 PM   #4
WorxTuning
NASIOC Manufacturer
Member#: 42684
What is to rethink? We are not endorsing that people should drive agressively on the street, we are merely stating our experience since installation.
I will change it and see if that helps anyhow. We dont want anyone going out and doing anything that would cause harm to themselves or others..
Thanks for the reply
Mike
Old 07-22-2004, 04:37 PM   #5
jmott
Member#: 6713
2007 Prius
brown
Mike
No its just that actually gaining 20mph of grip in a 20degree turn from merely suspension changes is probably impossible. Maybe the 'comfort' level allowed you to push the car that much faster without being afraid, but the difference between even a Scion XA and a corvette in a 90 degree turn isn't 20mph. (ask me how I know! hehe)
Old 07-22-2004, 04:56 PM   #6
WorxTuning
NASIOC Manufacturer
Member#: 42684
You are correct. That is why we said comfortably. Sorry if my statement could have been misconstrued. I was only trying to say that the improved characteristics of the suspension over stock made the car feel that much more capable in the turn. Due to this, I was able to push it much harder than I would have before.
Old 07-22-2004, 09:17 PM   #7
Jon-RIWRX
Member#: 38789
2008 Jeep Liberty
Red
Wow, those look pretty cool. You happen to have a pic of them installed on the car with wheels and everything so I can check out the drop?
- Jon
Jon-RIWRX is offline   Reply With Quote
Old 07-23-2004, 02:53 PM   #8
WorxTuning
NASIOC Manufacturer
Member#: 42684
Jon- here is a picture. keep in mind that there is an additional 12mm that it can be lowered if you want it to eliminate all of the wheel well gap. Pics of before and after, along with some stock vs new pics and install pics can be seen here- http://www.worxtuning.com/specials/ohlins%20pics.htm
Old 07-29-2004, 04:39 AM   #9
STiLL WILL
Member#: 37581
2004 SZ55'd STi
375whp on 91/404whp on 95
Nice car and great set up! Your intro price for these is decent, but I think Myles at RaceComp still has you guys beat though @ $2299.00.
-Matt
STiLL WILL is offline   Reply With Quote
Old 08-09-2004, 08:08 PM   #10
WorxTuning
NASIOC Manufacturer
Member#: 42684
We can price match on the coilovers.
Thanks
Mike
FS - VA: Odds & Ends for WRX, STi & Legacy Ferret13 MAIC Private Classifieds 36 08-20-2009 05:13 PM
FS: 2004 Subaru WRX STi brakes: brembo calipers, rotors, brake lines, pads 06WhiteWRX MAIC Private Classifieds 11 05-16-2009 07:52 PM
Tein S-tech/H-tech Springs and Coilovers for WRX, STi In Stock! GNV Motorsports Suspension/Brakes/Handling 30 09-12-2005 03:47 AM
FS NY: D2 Coilovers for WRX/STI SonicJLee Private 'For Sale' Classifieds 18 07-02-2005 07:28 PM
