Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 07-22-2004, 03:11 PM   #1
mjalex007
Member#: 66022
2005 Baja Turbo
Default Removing the CD Player
I've searched high and low and can't find any info on how to remove the CD player. I need to get behind it to hard wire my XM Radio unit with FM modulator.
I've read some instructs on getting the unit it out in an WRX starting with taking out the cup holder and unscrewing a couple of screws. As Baja-nicks know, there's no cup holder on the dash.
mjalex007 is offline   Reply With Quote
Old 07-22-2004, 06:57 PM   #2
juvefan
Member#: 61578
2003 Baja
I would like to know also.
juvefan is offline   Reply With Quote
Old 07-22-2004, 09:26 PM   #3
BajaNut
Member#: 36905
2014 Outback SAP
leggtnut on lgt.com
I have taken mine off a couple of times and here is a short write up. Don't have picteres thouth:
- the plastic around the shifter will pop up with some vertical pressure and the pull out.
- Take the coin (and i guess some use it for ashes as well) out
- there are 2 screws that hold the rest of the face and the guides for the coin tray that need to be removed, this area is extreamly tight so a 90 degree screw driver is needed.
- There are 2 screws to remove the tray under that
- The face will then "pop" off after that. Just takes some leverage.
that is it
Ben
BajaNut is offline   Reply With Quote
Old 07-23-2004, 10:30 AM   #4
braveit1
Member#: 44810
2003 Baja w/Snuglid
Black & Silver
From subaruparts web page look at the installation guide for the alarm system. The CD/CC module has to be removed to install the alarm system. Just stop after the module is removed. Look here .
braveit1 is offline   Reply With Quote
Old 07-23-2004, 03:15 PM   #5
mjalex007
Member#: 66022
2005 Baja Turbo
That's excellent! Much appreciated for the tip. Now why didn't think of that?
Old 08-03-2004, 03:43 PM   #6
fliggil
Member#: 57514
2005 WRX
I'm confused, I have an 05 as well and have no clue how to take off the center piece as I want to replace the radio. Anyone?
fliggil is offline   Reply With Quote
Old 08-03-2004, 05:41 PM   #7
mjalex007
Member#: 66022
2005 Baja Turbo
Follow the link in the message above and all will be clear.
Old 08-04-2004, 01:35 AM   #8
2003Baja
Member#: 52985
PULL HARD LOL. If you have to use a screw driver put some cloth around it.
Eventually you'll have it spilling its guts like mine did.
2003Baja is offline   Reply With Quote
How do you remove the CD player from a 2000 2.5RS xteejaayx Car Audio, Video & Security 4 03-12-2010 10:10 PM
i left my cd in the cd player dontgiva Interior & Exterior Modification 20 12-14-2007 05:39 PM
Alpine calls time on CDs "Is this the swansong for the CD player?" NYCshopper Non-Subaru News & Rumors 46 04-12-2007 12:40 PM
Removing bezel around the CD player..... Jesperss Car Audio, Video & Security 1 12-31-2002 04:42 PM
Bottom plate after removing factory CD player and radio wcbjr Car Audio, Video & Security 2 03-09-2001 08:18 AM
