Old 07-22-2004, 07:07 PM   #1
nils
Member#: 350
2015 STI
Question T/O Bearing + Wear on input shaft collar (T/O bearing surface)?
Question 1 - New throw-out bearing for my ACT street disk is not centered within the outer race/collar. The old one wasn't either. Is this a problem or intentional?
Question 1A - T/O bearing retainer clips (to fork)- really neccessary? The shop that did my 1st ACT install (@~80K) didn't re-install them. ..which might have caused Q#2?
Question 2 - The shaft/sleeve (surrounding input shaft) that the T/O bearing rides on has some low spots (12 to 4+ region) and has a step where the T/O bearing "parks". Additionally there is a step in the face of the collar. Problem or non-issue?
Clutch works (worked?) smoothly with above and tranny has 155K and with the exception of 3->4 shift above 4K (shift slowly or it grinds slightly), seems to be in good shape. (I have put 151K of the 155K on the car.)
TIA,
nils
nils is offline   Reply With Quote
Grease on input shaft w/ out tranny removal? k22addict Transmission (AT/MT) & Driveline 1 05-26-2010 12:09 PM
throwout bearing, pressure plate, or input shaft bearing? mattwho Transmission (AT/MT) & Driveline 7 09-19-2009 07:11 PM
Pilot bearing / Input shaft I.D./O.D.? n2xlr8n Transmission (AT/MT) & Driveline 6 10-24-2005 08:13 PM
Clutch disk loose on input shaft splines? Bird61780 Transmission (AT/MT) & Driveline 0 04-18-2005 10:34 PM
Allowable radial movement on input shaft? svx_commuter Transmission (AT/MT) & Driveline 1 08-12-2003 02:19 PM
