Old 07-22-2004, 09:44 PM   #1
aznatama
Member#: 60316
2004 STi
Default +20mm track on front only?
I've heard of race cars running slightly wider front tires to compensate for FWD-like tendencies in AWD cars, so I'm wondering how a +20mm(10mm spacers on each side) track increase on the front of my STi will affect handling?? I have 235/45/17 tires...
aznatama is offline   Reply With Quote
Old 07-23-2004, 09:57 AM   #2
Tire Rack Moderator
Member#: 1215
ext. 4362
well ... the tires would most likely rub the fenders and the additional width would create a little quicker turn in but, in a steady state turn the alteration in the scrub radius would have an adverse effect
Old 07-23-2004, 12:00 PM   #3
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
95 993 C4, 71 911, 04 STI
What?! Who said that increasing the scrub radius would do that? That's the exact opposite of what every manufacturer does to improve the driving of FWD cars. There's a reason that FWD cars have the brakes pushed way out into the wheel, with as small a scrub radius as possible.
Jon Bogert is offline   Reply With Quote
Old 07-23-2004, 07:41 PM   #4
aznatama
Member#: 60316
2004 STi
scrub radius? you mean the contact patch width relative to the centerline of the car right?
anyways, I don't ahve any rubbing issues, and doesn't a wider trak give better handing/traction in the corners? hmmm... I guess I'll see how it handles b4 I bother myself with lathing another pair of spacers...
Also, I was referring to FWD racecars running wider front tires, not increasing trak.
Old 07-23-2004, 11:00 PM   #5
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
Please Google on "scrub radius" and learn more about it before you add spacers. Specifically with respect to FWD cars, since the torque steer effects will be similar to an AWD car under power. RWD cars can get away with positive scrub and it's all good. Once you start putting power through the front wheels, though, the rules are different.
pics of 03 wagon with Eibachs on front only phantom309 Brakes, Steering & Suspension 4 05-28-2013 08:54 PM
WTB aftermarket front/rear endlinks, 20mm rear sway, front/rear strut bar lookitsawagon NWIC Private Classifieds 5 03-07-2007 06:44 AM
KYB AGX on front only is this ok? weezirx Brakes, Steering & Suspension 5 05-08-2005 11:10 AM
sti mounts on the front only? Mgardenier Brakes, Steering & Suspension 0 04-02-2003 10:21 AM
Why not Coil-overs on the front only? pagel Brakes, Steering & Suspension 1 04-20-2002 12:13 PM
