Old 07-22-2004, 10:09 PM   #1
B-85
Member#: 60628
1994 Sti.94,Sold 96.
Default 16" Wheels
What is the biggest tire that I can run on a 16"x7" by 50 offset wheel?
The wheels are off my 1996 Sti from Japan.
Thanks,Randy
The tires were 205x50x16 and are 23.25" tall.
B-85 is offline   Reply With Quote
Old 07-23-2004, 01:43 AM   #2
saar
Member#: 43770
2013 Impreza WRX
RNN14 GTiR
Thats the same size as Stock 2.5rs ....try a search ...i'v seen a thread about this..
saar is offline   Reply With Quote
Old 07-23-2004, 01:49 AM   #3
ScoobyB
Member#: 63040
2003 Impreza WRX
Here is a partial answer, ...
It would help to have a specific model tire in mind, you can then refer to it's spec sheet and solve this yourself. (example tire is a Toyo Proxes T1-S)
see: http://www.toyo.com/tires/tire_specsheet.cfm?id=2
for that diameter, going up no more than 0.65", the answer is a 225/45 x 16.
this is an ~8.9" wide tire (note, limited to your 16" rim, measured rim 7.5", not adjusted for)
for that rim, the answer is a 245/55 x 16. however it is 26.6" in diam. and 9.8" in width. Probably won't fit.
(above specific to toyo only!)
If you are not sure how to measure the available space in your wheel wells,
the best answer is to see if anyone here can answer the following...
What is the widest tire (model) anyone has actually fitted without problems....
ScoobyB is offline   Reply With Quote
Old 07-23-2004, 03:23 AM   #4
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Thanks,Randy
Got a pic? Are they oems?
ss
subysouth is offline   Reply With Quote
WTT: 17x7 LGT Wheels for 16" wheels drees SCIC Private Classifieds 20 05-19-2006 05:48 PM
17" wheels with good tires or 16" wheels with great ones? The Deliverator Tire & Wheel 1 02-13-2006 12:14 AM
What 1/4 mile time difference on 17" wheels vs stock 16" wheels and RE-92s? rex n effect Proven Power Bragging 11 02-12-2004 06:49 PM
Trade: my MY99 16" wheels for TS 15" wheels Keiho Vancouver Impreza Club Forum -- VIC 14 01-30-2002 05:15 PM
Trade: my MY99 16" wheels for TS 15" wheels Keiho Canada Region Forum 2 01-29-2002 11:12 PM
