Old 07-22-2004, 11:11 PM   #1
NeaD
Member#: 43371
1998 Impreza 2.5RS-T
Hydra User, Blue
Default sr20 370cc injectors install question.
I ended up moding the sr20 injectors today after finding out my yellow top injectors would not be a straght drop in. So I moded the injector plugs but the stock rs plug would not go straght on, I had to turn the plug upside down. Here is a pic:
I haven't started it up because I need a new starter. Do you think this would be a problem. People that have the sr20 370cc injectors please reply.. I really need some feedback.
NeaD is offline   Reply With Quote
Old 07-22-2004, 11:51 PM   #2
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
Where your yellow top injectors the 440cc JDM injectors? Please pm or IM me about them.
subiekid is offline   Reply With Quote
Old 07-23-2004, 12:31 AM   #3
NeaD
Member#: 43371
Hydra User, Blue
Someone has to know someone with them in their car.
Old 07-23-2004, 12:36 AM   #4
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
the injectors are just a switch arent they? so i dont think it will matter which way you have them hooked up but i am not positive, hopefully someone more educated can chime in.
Ben
Old 07-23-2004, 12:40 AM   #5
subiekid
Member#: 25516
Ha, I didnt even read the post, I just saw that you had yellow top injectors that might be up for grabs.
And no, it will not matter. You can wire the injectors either way and they will work. As long as you have your 12v and ground it should be fine.
Old 07-23-2004, 01:28 AM   #6
NeaD
Member#: 43371
Hydra User, Blue
tight
Old 07-23-2004, 11:29 PM   #7
sime
Member#: 45275
2007 wrx
98 2.5rs,89 & 95 240sx's
the impedence of the injector does matter but I don't know what sr's are and the stock rs's are. I see them for sale on ebay alot with resistors to change voltage
sime is offline   Reply With Quote
Old 07-24-2004, 12:31 AM   #8
Andursun0013
Member#: 11616
1998 2.35RS-T
2006 Baja 2007 Leg. Wagon
I just tested a set of JDM silvia injectors I have and they tested the same as my stock RS ones...~11.4 ohms can anyone else verify this for me?
Kyle
Andursun0013 is offline   Reply With Quote
Old 07-24-2004, 06:42 AM   #9
SteveS
Member#: 6
2007 BMW Z4 M Coupe
Interlagos Blue
The JDM Silvia injectors will work as a drop-in replacement.
SteveS is offline   Reply With Quote
Old 07-24-2004, 10:53 PM   #10
subiekid
Member#: 25516
So they have the same minimum turn on as the stock injectors? 120ms? What cc sizes do they come in?
Old 07-25-2004, 04:15 AM   #11
NeaD
Member#: 43371
Hydra User, Blue
are you using them?
Old 07-25-2004, 04:24 AM   #12
sick1.8t
Member#: 22345
2003 RSX
black
the s13/s14 silvia had 370cc injectors, and the s15 had 440's. you can get 570's, 660's etc from places like nismo and other nissan places. the silvia is the civic of japan, so they're made by everyone in pretty much every size.
sick1.8t is offline   Reply With Quote
Old 07-25-2004, 03:02 PM   #13
NeaD
Member#: 43371
Hydra User, Blue
I'm still looking for someone that's actually running theses injectors in there 98rs.
Old 07-26-2004, 11:09 AM   #14
SteveS
Member#: 6
2007 BMW Z4 M Coupe
Interlagos Blue
I had them in my car years ago. I used them in conjunction with the Apexi S-AFC and had to lean them out at idle and off-boost conditions. I wouldn't try to run them with only the stock ECU. Also, the connectors will not accept the stock harness plugs and I made some adapters using some GM harness fittings I found at Pep Boys. They do, however, plug right into the fuel rail.
Old 07-28-2004, 02:16 AM   #15
NeaD
Member#: 43371
Hydra User, Blue
Do you happen to know anyone that fliped the plugs like me?
Old 07-28-2004, 08:49 AM   #16
SteveS
Member#: 6
2007 BMW Z4 M Coupe
Interlagos Blue
I'm sure I tried, but I remember that the harness adapter wouldn't fit over the 370cc adapter. Are you worried? The injectors do not care which wire carries the load - as stated earlier in this thread, they are simply a switch. If it's working, great.
Old 07-30-2004, 02:49 AM   #17
NeaD
Member#: 43371
Hydra User, Blue
Update.... The injectors are still not shooting fuel. So, I'm going to cut off the rest of the plug. This is so the stock harness with fit right on to the injector with nothing blocking it.
I'm doing this to avoid cutting the stock harness and soildering new plugs on.
Old 07-30-2004, 08:11 AM   #18
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
I have them in my car, I went to the salvage yard and got Sentra injector harness so that I could do a clean install. The salvage yard even gave it to me for free, just cut the four connectors off for me. I then dissassembled the subaru ones removing the wires from the connectors still with the pins sodered on. I then disassembled the Nissan ones and stuck the subaru wires and their pins in. Worked great for me, no cutting and can go back to stock easy while having a factory look.
Joshua
yebokmj is offline   Reply With Quote
Old 07-31-2004, 02:21 AM   #19
NeaD
Member#: 43371
Hydra User, Blue
hummm... I have some plugs, I'll go try that right now.
SR20DET 370CC injectors installed for Supercharger reddevil Normally Aspirated with bolt-on Forced Induction Powertrain 10 12-26-2004 11:09 PM
Injector install question- please help jmaiken Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-30-2003 04:06 PM
PE 650 injector install question. IA Performance Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-27-2002 03:38 PM
Injector Install question Suby Bay Area Impreza Club Forum -- BAIC 5 11-21-2002 10:37 PM
injector install question suprasingle Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-22-2002 03:46 AM
