Welcome to the North American Subaru Impreza Owners Club Tuesday April 21, 2015
Old 07-23-2004, 08:52 AM   #1
ituner
Member#: 34476
88 civic
subyless for now
Default odd boost noises
Ok, I have a SOHC 2.5RS motor with a wrx turbo kit on it. I am running 5 psi and when I engauge boost, right around 3 or 4 psi I start to hear a crinkle type noise. I think it may be boost escaping into the atmosphere but not sure. I hope its not serious and I just wanted to see if anyone knew what it might be. Any suggestions would be appreciated.
ituner is offline   Reply With Quote
Old 07-23-2004, 09:51 AM   #2
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Crinkle? Like beebees in a coffee can?
Wedge is offline   Reply With Quote
Old 07-23-2004, 10:00 AM   #3
Aphex
Member#: 146
'05 Genesis Sedan
yes, if it's beebees in a coffee can, or a loud crackeling sound..... GET OFF THE GAS!!!!!! that would be pre-detonation, and it will destroy your motor.
Aphex is offline   Reply With Quote
Old 07-23-2004, 03:49 PM   #4
ituner
Member#: 34476
88 civic
subyless for now
Your NASIOC Administrator
I am running pig rich though and I have wrx injectors. But yes it does sound like beebee's in a coffee can now that I think about it. I have the motor running on my 1.8 ecu and harness in MY95 L so I wasn't able to hook up the knock sensor so I can't tell if it is knocking on my safcII. Pre-detonation though huh. Wow I had no idea, thanks ALOT for the input Aphex, I really appreciate it.
Old 07-23-2004, 07:56 PM   #5
ituner
Member#: 34476
88 civic
subyless for now
Out of curiousity, what is pre detonation exactly?
Old 07-23-2004, 07:58 PM   #6
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Engine Knock... http://zhome.com/ZCMnL/PICS/detonation/detonation.html
Either your timing is screwed up, or your fuel is insufficient, either way, if you continue on it you will blow up the engine.
Then it'll look like this -> http://forums.nasioc.com/forums/showthread.php?t=528857
Yet another Odd wheel noise cvalle-sd Service & Maintenance 0 05-25-2005 06:04 AM
Odd engine noise... ScubaruImpreza05 Normally Aspirated Powertrain 0 01-22-2005 09:28 AM
05 WRX with ODD tranny noise - need info about driveline Craig02WRX Transmission (AT/MT) & Driveline 2 10-16-2004 02:37 AM
More odd suspension noises Bionic Brakes, Steering & Suspension 4 03-18-2003 11:05 PM
odd brake noises Suladed Brakes, Steering & Suspension 2 05-18-2001 06:43 AM
