Old 07-23-2004, 09:02 PM   #1
DoodieHead
Member#: 10236
2001 GC8 [622.4WHP]
SOHC / GT35r 25psi
Default Slight problem diagnosing head color. Need Help.
I have a few pics of my heads after disassembling my block. One head came out with pretty much black valves and the other on came out with an orange rust looking color. I was hoping one of you 'Gurus' out there could let me know what the problem is. Thanks.
Setup
I have a VF22, JE 8.5 compression pistons, pauter rods, modified 565cc STI pinks, Aeromotive RRFPR, and an Autronic ECU.
Head pics
Mikey
DoodieHead is offline   Reply With Quote
Old 07-23-2004, 09:19 PM   #2
kaos200
Member#: 2692
that is very odd, did you blow out a headgasket? did the car sit for a prolonged amount of time?
kaos200 is offline   Reply With Quote
Old 07-23-2004, 10:23 PM   #3
DoodieHead
Member#: 10236
2001 GC8 [622.4WHP]
SOHC / GT35r 25psi
This is after 1300 miles of being freshly installed and cleaned up. The head gaskets check out 'OK' and I compression tested and all cylinders came out to 130. I was having a serious problem with oil burning, but have no idea where that was going. No external leaks and always smoke out the exhaust under load.
I just took the pictures this evening, but the heads look exactly the same as they did the day I pulled the motor. I need to figure out what is making that strange color.
Also, my car was running excellent before I had to tear it down. I busted a snapring on cylinder 2 tuning 18lbs and the wristpin was hitting the cylinder bore.
M|key
Old 07-23-2004, 11:35 PM   #4
kaos200
Member#: 2692
hmm, odd, oil doesnt cause that color. But the oil out the exhaust would have to do with the scored cylinder walls, unless it was happening before that?
Problem in drivetrain/mounts...need help diagnosing blueturbo2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 03-09-2009 02:04 PM
Got a little problem with the speakers, needs help to pinpoint the problem. SilentShadow Car Audio, Video & Security 4 12-03-2006 09:34 PM
Prodrive PFF7 Colors, need help Killian Maynard Tire & Wheel 14 07-11-2005 05:11 PM
Slight problem with my Turbo timer - help! djerickd Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-26-2001 12:06 PM
front badge color-- need help you photo gurus bahboy20 Interior & Exterior Modification 0 08-20-2001 10:52 AM
